Page: |
Home > Show Us Yours! > My City E, Now Running Turbo Short Motor And Box | |||||||
1424 Posts Member #: 2810 Formally spanner181187 Dublin, Ireland |
31st Jul, 2008 at 01:15:45pm
Thanks for the advice Retired. I will read that thread and decide what to do. Binning them and getting high grade replacements would be safest, so I'll probably do that On 12th Nov, 2009 Paul S said:
I think Gary OS has taken over my role as the forum smart arse On 30th Apr, 2010 Rod S said:
Gary's description is best |
3rd Aug, 2008 at 09:56:23pm
Well after having a crap day working on the engine build yesterday I decided to work on bodywork today.
4th Aug, 2008 at 06:43:22pm
Well my angle grinder shat itself today so I didn't make as much progress as I would have liked. I got the inner sill done. Just the front floor and seam welding everything left to do on the driver side. I'll get nothing else done this week though as I won't be able to afford a new grinder until Friday On 12th Nov, 2009 Paul S said:
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
4th Aug, 2008 at 07:06:12pm
Good work there dood looks good going to be some cracker when its all done I can feal some serious mini hooning coming on :) On 17th Feb, 2009 Rob H said:
9th Aug, 2008 at 01:16:21am
This week was better than xmas when I was a nipper. Look at all the money I spent!
9th Aug, 2008 at 01:18:01am
K&N universal cone filter
16th Aug, 2008 at 07:56:07pm
Paul and myself made some good progress today. We got the cam timed in aswell as a few other bits
6274 Posts Member #: 509 Post Whore Isle of Man |
17th Aug, 2008 at 11:35:49am
looking good
17th Aug, 2008 at 02:47:32pm
On 17th Aug, 2008 joeybaby83 said:
looking good just a quicky, as youll prob get to this bit soon the 'turbo' oil pump are 1275 based, and you might need to mod to get it to fit the 998 block besides that, its looking cracking I've prepared for that alright. I'll be making an aluminium plate to go between oil filter and block to account for the difference in drive length. Thanks for the complements On 12th Nov, 2009 Paul S said:
3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
17th Aug, 2008 at 03:50:32pm
how come you never went for a 1275cc head in the first place?
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
444 Posts Member #: 2885 Senior Member |
17th Aug, 2008 at 04:01:13pm
you mean oilpump and block..
17th Aug, 2008 at 04:13:02pm
On 17th Aug, 2008 rubicon said:
how come you never went for a 1275cc head in the first place? looking good tho! Because I'm a purist bastard to be honest. No other reason On 17th Aug, 2008 hario said:
you mean oilpump and block.. looking cool man in those pics up there ^^ is that grease round the bores to stop crap ingress? I did mean pump and block, sorry :$ Its just engine assembly lube sitting at the top of the bores. We were just in the middle of cleaning the bores Edited by GaryOS on 17th Aug, 2008. On 12th Nov, 2009 Paul S said:
17th Aug, 2008 at 07:04:04pm
With the crap weather I only managed to get some little jobs done. I painted my ther 2 wellers, sorted out some towing eyes and cut my bonnet for the intercooler
115 Posts Member #: 2830 Advanced Member Costa del Northern Ireland :) |
17th Aug, 2008 at 08:00:54pm
how tricks mate glad to see another small bore turbo from ireland
That mini is determined to Kill me!!!! |
17th Aug, 2008 at 08:08:57pm
On 17th Aug, 2008 bigmini998 said:
how tricks mate glad to see another small bore turbo from ireland ive just finished my 998 turbo with a sw5 cam but havnt had it on the road yet thats my next job this week... anyway this is wot the guys at swiftune said about their cam. <The SW5 has worked in Turbo/supercharged engines very well, it's very low duration and short duration helps with the exhaust pulses to spin the turbo at lower revs. This was a trick we learned from our association with Mountune and the Cossy engines in the past. The cam has also improved with the new SW5-07 profile and steel blank.> Thanks for that info. To be honest, I was a little worried about how the SW5 would behave in a small bore turbo motor. I had a standard 998 A+ cam ready just in case. You have settled my nerves now make sure you post some pics when you get your car running! On 12th Nov, 2009 Paul S said:
7th Sep, 2008 at 12:07:39am
We've made some progress with the build recently. The head will be bolted on during the week and we will start to make the manifolds.
10th Sep, 2008 at 12:25:58am
4 lates now made. Fuel pump blanker/oil return, plenum inlet, carb side of inlet manifold and turbo to exhaust manifold. I just have the turbo to front pipe one left which is by far the most complicated to make.
12th Sep, 2008 at 08:37:35pm
Turbo positioned. As you can probably guess, I decided not to try for an equal length manifold
3692 Posts Member #: 1833 Formally mini_majic Auckland, New Zealand |
12th Sep, 2008 at 09:07:42pm
what turbo is that? looks to have a sort of KKK type mounting flange.. |
12th Sep, 2008 at 09:17:41pm
James, it's a Garrett GT1544S. It's used on alot of small VAG TDIs like the polo/lupo 3 cylinder yokes. It's got super low ARs and its very small. It looks like it will suite my application well. It doesn't seem up to making big power but it should spool very quickly which is exactly what I want from this long stroker.
16th Sep, 2008 at 01:56:54am
The manifold has now been mocked up and tacked together. Next step is to get is welded up and cleaned with the grinder. Then we'll start on the inlet manifold.
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
16th Sep, 2008 at 02:49:02am
super job!
16th Sep, 2008 at 06:01:05pm
interested to see the inlet mani. this is giving me ideas! |
27th Sep, 2008 at 01:49:10am
Myself and Paul made some more progress on the engine. We made a sandwich plate to go behind the oil filter housing. It will be used for turbo oil supply. The turbo oil supply and return should get sorted next week.
27th Sep, 2008 at 09:05:50am
are you certain that the oil is filtered at that point?
Page: |
