Page: |
Home > How To > Blocking the poppet valve | |||||||
5th Sep, 2008 at 07:40:20am
if you dont block the hole you wont make boost.
![]() 530 Posts Member #: 1192 Post Whore In the garage......again!! |
5th Sep, 2008 at 04:58:32pm
so in theory its just a crude dump valve? i'm just wondering if this is causing my engine to draw in too much air, can they corrode or leak? tbh i never gave the plenumn any thought when i bolted it on, i thought the only poppets where in the butterfly. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
5th Sep, 2008 at 05:37:50pm
and what does the valve in the butterfly do then?? On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
5th Sep, 2008 at 05:41:50pm
so as that when the butterfly closes the popet opens and a small amount of air can still go through on over-run to reduce compressor stall.
5th Sep, 2008 at 05:55:12pm
The poppet valve in the butterfly is to reduce hydrocarbon emissions on overrun, and was fitted to NASP HIF carbs as well. |
5th Sep, 2008 at 06:03:36pm
so it can come off then?
![]() 2370 Posts Member #: 719 Post Whore Horndean - Near Portsmouth |
5th Sep, 2008 at 06:13:48pm
I've not heard of having to do this before?!
5th Sep, 2008 at 06:21:38pm
the turbo carb rebuild kit has a butterfly without the valve thing, most people have rebuilt there carb and used the new one, my engine works fine with the new butterfly and it must be less of a restriction |
5th Sep, 2008 at 06:28:26pm
Ahh fair enough, ill be rebuilding mine soon anyway. |
5th Sep, 2008 at 06:56:45pm
it cant cause too much restriction can it?
5th Sep, 2008 at 10:23:35pm
I have had the butterfly, without the poppet, on the carb for four years without a problem. IIRC Burlen don't make the butterfly with the poppet valve, so all you can get is the plain butterfly. |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
16th Apr, 2009 at 10:50:01am
On 5th Sep, 2008 Turbo Shed said:
if you change the spring for the montego turbo spring you will be able to run up to about 11psi. Does anybody know the spring rate of this Montego Turbo spring ? Thanks in advance Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
16th Apr, 2009 at 04:37:35pm
avonbar used to sell the montego spring |
Page: |
