Page: |
Home > Show Us Yours! > Exhaust Manifold - Update#4 | |||||||
1425 Posts Member #: 690 Post Whore Norfolk |
9th May, 2007 at 09:15:24pm
Axel - looking good - I think the gasflow is going to be pretty good out of there without dividers.
If Carling made Mini engines
171 Posts Member #: 621 Advanced Member nsw austalia |
10th May, 2007 at 08:11:37am
axel, great job there the angle into the collector is prety much the same as mine and i didnt use any dividers . Are you aiming to fit this without firewall mods?
1152cc turboed mini clubman, most powerful 1.1L a-series?
10th May, 2007 at 08:34:13am
On 10th of May, 2007 at 08:11am benjamin said:
axel, great job there the angle into the collector is prety much the same as mine and i didnt use any dividers . Are you aiming to fit this without firewall mods? anway keep the pictures coming its looking great :) Benjamin, You must take some credit for the shape as I think the centre section is identical to yours. Mine is different because the side branches drop down to make room for my injection manifold. Yes, I plan to fit the turbo without firewall mods. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th May, 2007 at 12:56:03pm
Getting there:
Edited by Paul S on 20th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7765 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
20th May, 2007 at 06:18:38pm
Mirage-dude, make your EVO2 manifolds like this one with the banana-outer pipes! PLease :) On 13th Jul, 2012 Ben H said:
6745 Posts Member #: 828 Post Whore uranus |
20th May, 2007 at 09:13:35pm
better strong than pretty axel ,good for you ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
21st May, 2007 at 08:31:54am
being tig welded you can take away some of the weld without making it weak if the weld pentration is good, i gorund the welds and then used a flappy wheel to give it a nice finish, although cant really be seen from engine bay.
3rd Jun, 2007 at 01:40:39pm
On 29th of Apr, 2007 at 05:12pm Axel said:
It's starting to come together: Cut and machined the flanges from some 316 stainless, 50 by 10 bar. Axel, what did you use to make the square manifold holes? I have just cut these flanges from 316 (with a hacksaw) and have drilled the exhaust holes to 20mm, the aim was to drill them to 28mm and then square them out with a file, but thats gonna take ages... i'll give them a go on the mill at work tomorow, but i don't think that will like it. LOL. On 28th Aug, 2011 Kean said:
3rd Jun, 2007 at 01:48:48pm
I used an 8mm solid carbide end mill.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
3rd Jun, 2007 at 01:52:07pm
Its looking good, are you going to mill the turbo flange flat again after you have finished welding, it looks like it has "pulled" slightly where you have welded it, although that may just be the picture?
3rd Jun, 2007 at 01:57:56pm
No, you are right, the welding has pulled the flanges banana shaped, but the central area around the ports is still reasonably flat.
3rd Jun, 2007 at 02:29:38pm
Bummer, although remember that as you pull the turbo studs up it will tend to pull the edges to the turbo flange and may well seal OK??
10th Jun, 2007 at 04:58:03pm
Nearly finished. Bit of weld dressing to do.
16th Jun, 2007 at 06:44:04pm
Decided to mill the flanges:
4360 Posts Member #: 1459 En-suite user Braintree, Essex |
16th Jun, 2007 at 07:57:21pm
Fairplay...doing well there Axel! :)
Edited by Jason G on 16th Jun, 2007. On 19th Jan, 2010 wil_h said:
16th Jun, 2007 at 09:24:52pm
really appreciate the pics axel , its great to see it taking shape . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Jun, 2007 at 12:48:53pm
It just occured to me Axel,
17th Jun, 2007 at 03:05:02pm
Thats looking good.
17th Jun, 2007 at 03:18:33pm
Ah, righto.
17th Jun, 2007 at 03:31:51pm
I honestly do not think that it is a good idea to meddle with the turbine housing, although I know Robert has done what you suggest successfully.
17th Jun, 2007 at 03:40:15pm
mmm,
17th Jun, 2007 at 03:49:42pm
On 17th of Jun, 2007 at 03:40pm mini13 said:
mmm, I was wondering where the A/R taper actually started from, I was asuming as long as it was done before the internal wastegate vent it'd be ok. I think you may be right. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Jun, 2007 at 01:18:07pm
Axel,
19th Jun, 2007 at 03:50:19pm
No, I didn't.
20th Jun, 2007 at 06:56:28am
Good advice axel. Every day is a school day ...........
Page: |
