Page: |
Home > Show Us Yours! > Project part 2, new jdm route. | |||||||
1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
13th Aug, 2013 at 09:40:39pm
Byebye honda rubbish. Dta here we come.
I popped my first one out the other day... |
13th Aug, 2013 at 10:04:11pm
Nice one dude! comon your too close! |
13th Aug, 2013 at 10:39:06pm
I know... So very close... The dta will take it to being 98% done. On 17th Feb, 2011 apbellamy said:
5th Sep, 2013 at 09:37:16pm
Booked in for the mot
5th Sep, 2013 at 10:11:47pm
Looks sick dude!! |
1st Dec, 2013 at 07:55:27pm
Well ill update it i suppose. Not many piccies tho.
1st Dec, 2013 at 07:56:27pm
Poked away for the night...
1st Dec, 2013 at 10:07:28pm
Getting on with it still!!
2nd Dec, 2013 at 01:12:10am
Yes mate, clutch de-blead due to the copper having no give, re-flared the pipe was ok for it and then the same problem, so got a goodridge flexi hose arriving this week to solve it once and got all. On 17th Feb, 2011 apbellamy said:
2nd Dec, 2013 at 07:37:57am
Move that air filter! Love the car dude Drives
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
2nd Dec, 2013 at 08:12:08am
I do like that.
In the 13's at last!.. Just |
2nd Dec, 2013 at 09:19:45am
The air filter will be gone altogether when the itbs arrive, so not too much of a worry .
2nd Dec, 2013 at 09:59:53am
looks grate!
2nd Dec, 2013 at 06:40:43pm
I am missing a turbo! initially i thought a turbo vtec would be amazing, but i realise now its just too much power, and you can go past a point of it being fun and into the realms of un-usable (fwd), and not safe unless i built a brand new roll caged shell from the ground up. On 17th Feb, 2011 apbellamy said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
2nd Dec, 2013 at 06:54:42pm
wise words-sometimes you need to just take a reality check!
On 2nd Dec, 2013 Rick.SPI said:
I am missing a turbo! initially i thought a turbo vtec would be amazing, but i realise now its just too much power, and you can go past a point of it being fun and into the realms of un-usable (fwd), and not safe unless i built a brand new roll caged shell from the ground up. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
2nd Dec, 2013 at 06:57:16pm
i do like this build, i have been sneeking my eye on it lol
Yes i moved to the darkside
2nd Dec, 2013 at 08:50:04pm
Cheers oli...
2nd Dec, 2013 at 09:24:30pm
Cheers oli... I can take a piccy next time im out for you brett if itl help... Please mate i have a whopping great turbo im gonna try to squeeze in ( i know it wont fit ) my frame is built to get the engine as low and far back as it can go, but i dont know how much difference that gives vs a build such as yours Yes i moved to the darkside
2nd Dec, 2013 at 09:31:06pm
This may help a little, but ill get some proper ones for you mate.
10th Dec, 2013 at 07:56:05pm
This cars gonna get scrapped at this rate!!! Definitly less relaible than an a series at the moment!!! Had a misfire at around 4k (vtec area) cleaned all the vtec system out, check the solenoid, got a brand new coil on it. And on top of the 4k misfire it wont start 9/10 times (not starting now)
4304 Posts Member #: 1321 Post Whore Wiltshire |
10th Dec, 2013 at 08:17:24pm
Distributor issues? On 7th Oct, 2010 5haneJ said:
10th Dec, 2013 at 11:40:40pm
Nope running a coil pack (brand new) with brand new leads (magnecor) and plugs (bosch) so cant see any of this being the issue. On 17th Feb, 2011 apbellamy said:
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
11th Dec, 2013 at 10:41:44am
Might be worth a plug change - I don,t rate Bosch |
11th Dec, 2013 at 10:50:57am
On 10th Dec, 2013 Rick.SPI said:
it wont start 9/10 times (not starting now) Good compression on all cylinders, intermittent spark and fuel, earths are good, all fuses and relays are good. What ECU is it on at the moment ? But irrespective of which ECU, intermittent spark/fuel are classic symptoms of a key sensor not being read properly - the key sensors vary with makes of ECU but crank and cam pickups are always a good place to start looking. Does the ECU software have any diagnostics ? (ie, a tooth logger to confirm the crank/cam sensors are reading right, and anything else for that matter). EDIT - spelling. Edited by Rod S on 11th Dec, 2013. Schrödinger's cat - so which one am I ??? |
11th Dec, 2013 at 06:50:42pm
Am currently searchin for an old laptop with a com port (used a friend before but dosnt work now) just cant get mine to connect, and havnt got any old computers to hand. But yes think the dta does note any faults and record them... On 17th Feb, 2011 apbellamy said:
Page: |
