Home > Show Us Yours! > 1293 supercharged blow through clubby
jameswildcooper
Member #: 1355
Leicester
bit more done on the car today having done nothing since thursday lol.
gear linkages on, starter motor in and drivers seat properly bolted in.
decided im only going to run 1 seat for a bit just for a laugh
ive just got to make some brake pipes now and clip down the braided fuel hose you can see in the back ground.
got two weeks today to get the car finished ready for slark....
eden7842
Member #: 8852
leicestershire
Dw mate I got moaned at for working too quickly too *tongue*
jameswildcooper
Member #: 1355
Leicester
lmao well its actually come to a halt :(
im waiting on parts and also the exhaust to turn up.
havnt touched it since tuesday because of the rain :(
waiting on some bits so i can fit brake pipes.
waiting on exhaust so can fit that.
and also waiting on new megajolt loom so can fit that :S lol
got a weekish to get the car done ready for slark....
cant see it happening myself but we shall see lol
jameswildcooper
Member #: 1355
Leicester
i did get the fuel line in properly though although i might use P clips in the not so far future....
Edited by jameswildcooper on 1st Jun, 2012.
jameswildcooper
Member #: 1355
Leicester
gone and bought a new dash will be here next week.
the car doesn't look like it will be ready for the 11th but it is going to be close!
hopefully have it running by this weekend coming when my megajolt bits turn up and some other goodies.
kelvg
Member #: 3277
whetstone, leicester
How much that cost you then James ? Looks nice !!!
Craigie-B
Member #: 9468
Wootton Bassett
should of gone vtec
jameswildcooper
Member #: 1355
Leicester
kelv i didnt pay for it i did a swap for some wheels i had which i dont use.....
and craig....VTEC is for girls *tongue*
kelvg
Member #: 3277
That's good then you can't really grumble with that buddy. I got my dash off eBay and had to cut loads off to get it to fit but i think it's worth it now.
jameswildcooper
Member #: 1355
Leicester
what dash do you have?
kelvg
Member #: 3277
Not sure what it's called just was on as a race dash if I remember right. But it's on my show us yours as in the middle of putting it in so in primer till tomoz as going to spray when I finish work.
jameswildcooper
Member #: 1355
Leicester
got a link to your thread kelv?
new exhaust system turned up today *happy*
jameswildcooper
Member #: 1355
Leicester
ive got the exhaust sitting how it should be (ish)
and looks like i need to modify the rear beam for it to sit about half an inch higher which im sure will make all the difference as its extremely stupidly low lol
i can safely say ive never owned a car this low before *indifferent*
gunna be scrubbing on cats eyes at this rate lol
pics coming shortly when it stops raining.....
jameswildcooper
Member #: 1355
Leicester
exhaust should sit just over half an inch higher once ive modified the beam
Looking good, could you put a slight bend in to have them through the valance?
jameswildcooper
Member #: 1355
Leicester
paul im getting the back end of the car sprayed and where the standard cut out is for the exhaust to come out normally is being smoothed off, i was thinking of putting cut outs in the center for the miglias, ill have to see how much higher it can come up once its bolted up
kelvg
Member #: 3277
If you put in search my 1293 mini should come up mate
mw3
Member #: 9590
Derby
Thats ridiculous, you cant drive it on the road like that surely!?
The back end needs raising up and itll give you a bit more clearance, When i mounted mine i didnt have any problems with it being too low but i think thats because i dont run a beam.
Matt W
On 14th Mar, 2012 mw3 said:
jameswildcooper
Member #: 1355
Leicester
mw3 it isnt staying like that....
thats the highest i could get it before it hit the beam but im having the beam modified so it can sit higher up and snug under the valance, maybe even cut outs in the valance and a touch higher than the bottom of the valance
Edited by jameswildcooper on 7th Jun, 2012.
You need to mdify that beam as they are shite! This is how I did mine.
jameswildcooper
Member #: 1355
Leicester
yes matty thats very similar what im doing to mine!
except my beam is on the car now so its a little harder :(
looks like your running the same beam as me!
Yeah same beam, make sure you triangulate the L brackets and they are VERY flimsy and you can easily bend them by hand. *oh well*
Im going to either chop that 10mm square section off completely, or if I get time make a new one. Im not convinced it has any use apart from getting in the way.
jameswildcooper
Member #: 1355
Leicester
cheers for the advice :)
i would have thought the box section makes it a little more rigid being there and stops the beam flexing in the center?
I assume thats what its there for too, but it could just be overkill as no other beams have them that ive seen. Ive left mine on to be on the safe side for now, but it is a pain still, the handbrake cable used to rub on mine too untill I filed some channels into the box section.
jameswildcooper
Member #: 1355
Leicester
hmmm your tempting me to just cut mine out lol
