Home > Track, Drag & Race > RR and RWYB day? 17-18th October - Northampton and Avon Park - Taking money for RR on the 17th
wicked *happy*
Hope I'll be ready for this, I still need to fix my fan belt
Sounds like a plan then.
**crawls back under metro van to continue fitting fuel pump etc**
MarkGTT
Member #: 1194
Shropshire.
is anyone driving their mini to this? debating getting a towbar and renting a trailer..
im driving in the mini aslong as its still driving then im nursing it along at the minute its ok in 4th that'll doo me :)
Are you daring the dyno and the 1/4 mile brett?
Nick
Member #: 154
Midlands
i'll be driving to it...bloody trailer queens, lol.
why not it only like me driving off at the lights*happy* jk
the dyno probably if there is time n space, i dont mind being low in the pecking order or not go at all if there is enough turboes cars there
1/4 i chickened out at mitp for this reason i have 1500miles since then no probs ill see how im feeling*happy*
Get it on the dyno & the strip then!
no trailer for me.
I'll be putting the mini in the van
i think i might come and spectate in the new daily.
I won't be able to bring mine along now.
Would be good to get a new power figure for it, but house move has stopped any progress being made for months. :(
that sucks matt,
what else needs to be done?
tadge44
Member #: 2500
Buckinghamshire
Did a demo hillclimb on Sat/Sun, for the first time and had a lot of fun, so thinking about turning up at Santa Pod on the Sunday just to see how slow I am.
If its a tenner for a day out that cant be bad .
just hope the weather stays good...
turbominivanman
Member #: 1504
Westbury, Wiltshire
Driving up from Bath in the van - must be at least 100 miles to get to Northants from where I live !
Might have to dip out on the strip depending on whether I can convince the wife. Got shit loads of DIY to do.
RoB H - do you want a lift up on the Sat - I promise not to pop the head gasket this time ?
Should give the van a full workout before I even get there.
Got to change the actuator tonight - I want more control at lower boost than the current 9 lb spring will allow with the boost controller so I'm re-fitting the std actuator. The controller will then be able to a better job from 4 psi on instead of the base being 9 lbs.
Also re-torquing the head down tonight after 250 miles post gasket change, and changing out the metty alternator for one of Matt's ND jobs.
Really looking forward to it.
Richard.
Im out im afraid
I keep blowing head gaskets in the same place and i dont want to bolt it together just to not last a RR day.
I was contemplating putting it together, but i found out last night im not able to get a tow car for next weekend
Crud
Highly likely I'm out now too owing to exploding tyres (in another thread)......
I'll still try but, after today, motivation is low....
someone will no doubt lend you a set of wheels *happy*
nic, poor effort old chap!
MarkGTT
Member #: 1194
Shropshire.
boo - no more drop outs please!
Err. The van is most probably out. Bottom end is shafted. But we will be there anyway.
wheres it going nic?
what gasket are you using?
Until I find out why a brand new performance tyre failed catasrophically while being fitted to one of my wheels, the other three will not be used by me.
The chances of getting an answer in two weeks time (or another set of wheels and safe tyres) is rather low, but I'm afraid my life is worth a bit more than £200 (the cost of the tyres), well it is to me anyway !!!
My RR fee (already paid) goes to the rest of you for a few more runs.
My project is abandoned until I get an answer over the tyre failure.
Its a bk450, its not damaging the firing ring, but its separating the black laminate area into the water way around no 1 into the coolant hole
Ill get some pics up in another thread.
Its done it on 2 now and i think it did it on the gasket last year too.
It needs a freshen up anyway so ill get the block and head skimmed but I havent got the money to spend on it on lasting a couple of hours as i need to do the oil now too
BOOOOO
You never know...
We might do a Jimster and get it built in the eleventh hour.
That said, all new bearings in the bottom end on top of the rest is pushing it.
