Page: |
Home > Show Us Yours! > Electric waterpump project | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
3rd Nov, 2013 at 04:53:59pm
On 3rd Nov, 2013 Joe C said:
LOL looks a bit heavy duty Paul, you going to drive the alternator off it too? LOL - perpetual motion Eh ? It's actually a starter motor from a Toyota and identical to the motor on the Mini high torque starter, bottom left of picture. Plenty of revs and wattage :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 270 Posts Member #: 69 Senior Member Coventry |
3rd Nov, 2013 at 10:58:30pm
Very interesting thread. It isnt unussual to find lumps of sand casting crap in the waterways and 30 years of crude build up. The Hi Torque Starter does indeed look exactly like a Toyota one, which is a Denso starter, a separate thread might be useful to find out or work out which one and whats required to make which ever is the best Denso Starter onto a mini. If you could pick up a used Toyota Starter and someone did a alloy adaptor plate and drive gear that could be a cracking little MOD. So Evans is basically snake oil...
4th Nov, 2013 at 06:42:33am
has anyone ever done what paul has taken a pic of
4th Nov, 2013 at 04:20:06pm
On 23rd Oct, 2013 Turbo Phil said:
I did this years ago when I had a front mounted rad, though I never dyno'd the engine it made a noticeable difference to engine response. Phil. I agree. I removed the fan (not pump) and think I could feel the difference.... On 13th Jul, 2012 Ben H said:
4th Nov, 2013 at 05:46:52pm
On 4th Nov, 2013 Turbo This.. said:
has anyone ever done what paul has taken a pic of that is drive the std mini pump with an electric motor via the correct size pulleys and or a viable speed motor? I'd have thought it'd actually be an easy way of determining the power used by the waterpump (and fan); either with the motor current consumed, or by some kind of load-cell applied to a torque-arm on the motor mount or idler... But I imagine Paul is already one step ahead. On 17th Nov, 2014 Tom Fenton said:
5th Nov, 2013 at 12:08:42am
http://www.shengineering.co.uk/sh/sites/de...ts/DSCF0571.JPG From SH website, huge water pump pulley and Crank Pulley... Reason? perhaps by increasing pulley diameter the amount of surface area of belt in contact with pulleys will stop it slipping?? or is there other thoughts? |
5th Nov, 2013 at 02:16:51am
I'd have thought they have some new crank damper with a large diameter housing needing a big pulley, but didn't want the water pump turning at 12000 RPM. It does look odd though.
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
5th Nov, 2013 at 05:10:58am
I think only 2 bolts have been tightend. If i have more toys than you when i die, I WIN |
336 Posts Member #: 9941 Senior Member Derby |
5th Nov, 2013 at 07:54:53am
The idea of that pulley must be for the likes of 16v minis that are revving to 10k I'd have thought |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
5th Nov, 2013 at 10:04:56am
Utterly non-scientific, but the two engines I've fitted Dowty fans to felt like they revved up and down faster than with a std fan.
Metric is for people who can't do fractions. |
5th Nov, 2013 at 04:56:18pm
On 5th Nov, 2013 jamiestevenbell said:
The idea of that pulley must be for the likes of 16v minis that are revving to 10k I'd have thought Why design it to clear the 5 port head then? ![]() On 26th Oct, 2004 TurboDave16v said:
6th Nov, 2013 at 08:58:50am
my thinking is that that ratio of pulleys for engines spending there life at like 7-10K and thats slowing the fan and pump to the point where they come back into there efficiency range |
6th Nov, 2013 at 10:47:01pm
what about using the smaller impellor pump instead of the larger one?
7th Nov, 2013 at 05:26:05pm
I don't think that the choice of pump would help much other than to limit the maximum flow.
326 Posts Member #: 1323 Senior Member |
7th Nov, 2013 at 08:58:01pm
I used a Corley Conversion pump on my KAD engine in the early 90's
224 Posts Member #: 9987 Senior Member Amsterdam |
5th May, 2014 at 04:10:37pm
So....I got taken over by work the past few months therefore it has taken me a while to get back with any significant updates.
![]() 324 Posts Member #: 9441 Senior Member South Devon |
5th May, 2014 at 06:10:25pm
Sorry if it's already been mentioned but does the pump controller also switch on the fan or is that on it's own thermostat? |
5th May, 2014 at 06:19:25pm
i like that rocker cover :) Yes i moved to the darkside |
5th May, 2014 at 06:20:37pm
The controller activates both pump and fan, it is able to modulate pump voltage between zero (completely off) and anywhere between 6volt and 13volt.
Edited by Evoderby on 5th May, 2014. |
27th Jan, 2017 at 10:22:49pm
Old post revival!
My build thread..
![]() 36 Posts Member #: 262 Member Netherlands |
9th Mar, 2017 at 09:12:42am
And did you ever dyno it to see how many ponies you saved? Op de bank beleef je geen avonturen |
7th Feb, 2018 at 03:30:56pm
On 1st Nov, 2013 Paul S said:
A 2-core radiator is really struggling with over 30kW of heat. I've got datalogs from a 100mph cruise on our test track. Engine sat at around 94 Deg C on a cool day in October 2010 on the way back from the RR day. Plugging that into the calcs and allowing for a top end performance from the rad, then it just about copes with 35kW. It would not be happy on a hot day. On 28th Aug, 2011 Kean said:
7th Feb, 2018 at 06:06:06pm
From the sims, I was seeing heat given off by the intercooler equivalent to about 10% of brake power. That's based on 20 DegC ambient, 85% Efficiency cooler.
7th Feb, 2018 at 06:23:03pm
Cool, so about 15-20 kW ball park, that should work. On 28th Aug, 2011 Kean said:
Page: |
