Home > Show Us Yours! > Rear Engine Focus RS Build
phh now that is a nice plenum
Edited by Brett on 22nd May, 2014.
steve w
Member #: 1917
AKA chargedzetec
Spent a bit of time finishing porting the adaptor, making a gasket, and fitting to the engine.
Also got hold of some k-nuts and fitted the itb's.
Hoping I don't have to do this bit again any time soon. Access for doing up the fixings is very tight, took ages!
More gaskets to make, then plenum is going on.
Also stripped down the front end bodywork, as it transpires that one of the rad mounts has snapped!
Edited by steve w on 25th May, 2014.
steve w
Member #: 1917
AKA chargedzetec
Progress.
Getting there slowly.
steve w
Member #: 1917
AKA chargedzetec
Finally finished a couple of my side projects, and got out in the garage. It's murder working in an asbestos garage in this weather though, it's like an oven!
I've had remove then refit the gearbox, clutch and flywheel as it turns out the cps boss wasn't fitted to the block when I built it all up. All done now, everything just needs tightening up before trying to fire it up for the first time.
Also made new rad mounts, as the old ones have snapped.
Modded some NAS bolts to mount my front brake calipers
Made an adjustable stay for the alternator.
Brake system to plumb in next. Trying to get as much done as I can while I'm off for the next 10 days.
steve w
Member #: 1917
AKA chargedzetec
Stuart (turbocox) came over today, as I got scared plugging the ecu in!!
Long story short (after a huge fuel leak) car wont start.
We've messed with fuel pressure, checked for spark, changed plug gap, added 'easy start'. It won't fire. The more I think about it, I'm not sure I've set the Cambelt timing correctly.
Either that, or the super clever itb's don't work!!!???!!?
Hopefully video to follow after I've digested the Haynes manual and reset the timing.
Edited by steve w on 10th Aug, 2014.
oh pooh ! stick at it steve , it Will fire into life.. oh yes.
wng691s clubby
Member #: 9252
Cleethorpes
youl get it sorted
Done now needs redoing lol
turbocox
Member #: 2722
Milk an Beanz
patience
noun:
1.
the capacity to accept or tolerate delay, problems, or suffering without becoming annoyed or anxious.
*Yes*
Edited by turbocox on 11th Aug, 2014.
The distance between insanity and genius is measured only by success
steve w
Member #: 1917
AKA chargedzetec
Turns out the issue was with the injectors
750cc/min 12 ohm injectors are currently en route from Australia. Should solve the issue.
A couple of other developments that I will add shortly.
Sounds exciting
Can't wait to hear this running.
steve w
Member #: 1917
AKA chargedzetec
Had to modify this bulkhead fitting to allow me to connect the clutch mastercylinder to the ford hose.
Looks like it will work better than the copper line I had bodged together before.
steve w
Member #: 1917
AKA chargedzetec
Have just fitted the rad mounts and refitted the rad.
steve w
Member #: 1917
AKA chargedzetec
Nearly finished my new throttle pedal
Currently 56grams with the mounting bracket to add
steve w
Member #: 1917
AKA chargedzetec
Also, injectors arrived today from Australia.
I've had stuff from UK take longer to arrive!
stuff like this i always buy from us / aus / nz
price for big high impedance injectors in the uk is rediculous
infact my skyline injectors came from spain aswell
what do they flow steve?
steve w
Member #: 1917
AKA chargedzetec
750cc/min. Should be enough for now.
I agree Brett, did ALOT of research and it a no brainer to buy from abroad.
thanks steve , i have had 8 of those knocking about for the tvr for ages .may be a bit big .
steve w
Member #: 1917
AKA chargedzetec
Added the bracket to the pedal today. At 63grams, with some glue and a weld to add.
In the process of making the injector wiring looms.
would it be possible for someone like you or Stuart to make CF pedals for brake and clutch.
steve w
Member #: 1917
AKA chargedzetec
steve w
Member #: 1917
AKA chargedzetec
Possible, yes.
Do I want it on my conscience if a brake pedal breaks? No
Sorry mate, but I see how much development goes into the ones at work. It's just not worth the effort vs. the risk in my opinion.
I made billet pedals, a bit on the heavy side, but one thing I don't want to fail
steve w
Member #: 1917
AKA chargedzetec
It runs........
