Home > Show Us Yours! > 1380 Turbo Mini project
claymad
Member #: 2560
Turku, Finland
Here is the screen shot of what I finished today.
Now I know what wire goes where if I have so troubles with the electonics... I also plannet to print cable stickers so i can mark the cables with same names as the table. Then I think its PRO...
miniallsort
Member #: 1131
wow great build man love the paint job and the engine looks the dogs
turbonutter
Member #: 7848
South London
keep up the good work mate nice one rob.
claymad
Member #: 2560
Turku, Finland
Here is some more pictures of the tube project. Everything seems to fit nicely now when I removed fan and moved radiator a bit. Next I have make aluminium brackets for the rad.
miniallsort
Member #: 1131
looks fab!!
spaceframemini
Member #: 7472
stockton on tees
Looks good
Andy
claymad
Member #: 2560
Turku, Finland
Some progress here. I got all the tubings fitted and new brackets for coolers. It seems that everything sits under the bonnet nicely 8-)
philc
Member #: 1346
bromsgrove
well done very clean and tidy
That is well set out mate.
claymad
Member #: 2560
Turku, Finland
At last I got the mini out.
Next weekend there is mini meeting so it will be 400km drive. Any ideas what I should check before this run?
jimmy
Member #: 829
essex
it looks the nuts mate
1293 Turbo mini
claymad
Member #: 2560
Turku, Finland
Summers is gone here in finland and suprisingly it went quite well with the mini. Next update will be FIA approved roll gage...
And after that there is some minor sheet metal work with this.... Sorry guys it's not mini...
wng691s clubby
Member #: 9252
Cleethorpes
what a great mini top class work all round looks amazing hope mine goes this well. and the camper couldnt get a better second project unless it was another mini of corse *hehe!*
Done now needs redoing lol
pim1275cc16v
Member #: 9557
South region of the Netherlands
Impressive work, props for the engine bay.
There ain't no milling machine like the one at home !!!
Dont be shy, am sure most of us on here would like to see the rebuild on the split
rick
pieter
Member #: 7577
belgium
nice split project you've got yourself, some minor panelwork is an understatement i believe...
claymad
Member #: 2560
Turku, Finland
Yes there is a lot of panelwork, for example whole floor and floor rails, doors, bottom side panels... must be renewed. And of course there is no engine or steering wheel... In fact this car has layed in the forrest since 1982 and now stupid me saved this 50 years old bus.
Here is picture of where it was forgot...
claymad
Member #: 2560
Turku, Finland
Not much done for Mini exept the breather oil reservoir. There is two 19mm hoses from timing cover and gearbox and one 12mm hose from valve cover. Next operation is that I'll move the air filter to front below the water intercooler... Then I can move the window wiper back to original place to right side.
I like it, it looks great
claymad
Member #: 2560
Turku, Finland
Last weekend we got finnish mini club dyno day here is video of slipping clutch...
http://youtu.be/YaZMvI8gT3M
What clutch are you using? Time for RTS?
claymad
Member #: 2560
Turku, Finland
I'm using AP racing Road/Rally plate with grey diaphragm. I think that the reason for clutch slip is polished flywheel and backblate surfaces. This is because I used sintered plate and by then the clutch get a bit warm...
btw. despite the clutch it produced 172hp/233Nm corrected engine power so I'm pleased with that. And the labda was between 11-12.5 trough whole area.
Very nice. What boost was that at?
claymad
Member #: 2560
Turku, Finland
0.8bar was boost, but it hardly reach that because the throttle must lift up to prevent clutch slip...
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
im a bit of an air cooled fan mate
looked sweet with the moss on it haha
2332cc turbo charged sleeper?
ive got a baja XD plan is to 2332cc it some day
the mini is frekin awesome mate well done! found it whilst hunting for water to air intercoolers haha nice!
Users viewing this thread: none. (+ 2 Guests) <- Prev   Next ->
