Home > Help Needed / General Tech Chat > Bleed valve
Yoda74
Member #: 11728
Uden, Holland
Hi guys,
I’m running a MG Metro Turbo engine in my Clubman Estate with the Ecu and boost Solenoid still fitted.
As I’m looking for a bit more performance I’m thinking about taking out both and fitting a bleed valve to upgrade the boost mainly in lower revs and maybe a tiny bit in high revs.
Question one is what bleed valve to go for? Are they all ball and spring?
I see a few different ones, which one gives a good solid boost and can be locked so it won’t wander or vary.
Turbosmart, Grimmspeed, GFB, QSP, H-gear, or different?
Are there good or bad ones around?
Does in car add any value? Or dual stage?
What is a max boost for a pretty standard healthy Metro Turbo engine?
if you want boost to do something different at different times, then no mechanical bleed valve will do that.
You will need some form of electronic control.
And if it's cheap you want, a simple fish tank bleed valve will allow you to dial on some degree of leak in the system for negligible cost.
Yoda74
Member #: 11728
Uden, Holland
Cheap is not what I'm after, I want a bleedvalve that once it's set, I lock it and have no worries about it, always works well and wont malfunction, just simple and reliable.
A bleed valve will not allow you different boost, at different times.
And a lot of the expensive ones....really are no better than a cheap plastic one. Some may have some form of boost blocking feature to try and assist spool, although I would probably suggest against that on a Mini
But if you want "quality", stick with the usual brand names like Turbosmart etc.
Certainly not "All" as he claims, but not a terrible video, just lacking in all.
https://www.youtube.com/watch?v=hYIL_XvlYTE
Yoda74
Member #: 11728
Uden, Holland
Adjustable boost is not what I want, just set it once at lets say 8psi, and leave it like that.
The only kind of adjustment that I would consider is the dual stage from turbosmart. 2 locked positions, say one at 5 psi for cruising and one at 9 psi for trashing it around.
On 18th May, 2022 Yoda74 said:
Hi guys,
This suggested you wanted boost to vary at different rpm's. Which cannot be achieved with a simple mechanical valve.
Some EBC's are quite cheap, and with adjustability in-car.....they do make a lot of sense for the user when used sensibly.
Especially if it is one you can dial boost in vs say rpm, road speed etc.
Yoda74
Member #: 11728
Uden, Holland
Ah, not translated that well, what I meant was that by fitting a bleed valve and set it to let’s say 9psi, the boost will be higher than with my ecu fitted. The ecu keeps the boost at 4psi in lower revs, 7 in higher, so the power will be better mainly in low revs and a bit in high. My Dutch To English translation sometimes is not perfect… *wink*
Mr Joshua
Member #: 1954
Luton Bedfordshire
first things first if your running with the T3 as originally fitted to the Metro turbo that puppy can boost over 2 bar thats 28psi. you don't want that.
In order to do what you want you need to add a bleed valve to your already fitted boost control. The bleed valve needs to be fitted in the boost sense line into the ecu.
This way when you open the bleed valve you are reducing the boost pressure the ecu sees and forcing it to control the boost to a higher pressure. Thus the turbo needs to produce more pressure to overcome the leak you have introduced. now you can control what your max boost will be. How much boost a standard engine can take i can not say.
Own the day
e5tus
Member #: 10128
Dorset
Does in car add any value? Cheers
I've always avoided having any adjustment within reach, the devil makes work for idle thumbs and all that. If you can reach it, you'll fiddle. Expense awaits!
Yoda74
Member #: 11728
Uden, Holland
I think you may be right e5tus. Under the bonnet Will be safer.
@Joshua: why keep the ECU and solenoid? Why not loose them Both ?
if you retain the OEM control as well, you could still try and achieve a rising boost. But say instead of the 4psi/7psi, it might be 7psi/11psi as you would be tricking the ecu into thinking there is less boost overall, but it would still behave in a similar manner
Running less boost in the mid range, your gearbox will be happier and live a little longer, so maybe not a bad thing.
Although you then have a couple of boost control items in there which is a little messy. I'd far sooner prefer a single boost controller.
With a suitable EBC, you could ramp boost with rpm, throttle, and/or road speed or gears ( as long as you can give this information to the unit )
But that's maybe a little less simple than just a cheap bleed valve.
Mr Joshua
Member #: 1954
Luton Bedfordshire
If you only had the bleed valve then max boost will only be achieved at max revs. the ecu is reading intake pressure and maintains the programmed in max pressure by controlling the waste gate via the solenoid valve.
by introducing a controlled leak into the sense line off the ecu you can lower the sense line pressure, from the 7psi down to say 2psi. This would cause the ecu to stop operating the solenoid valve closing the waste gate and causing the boost pressure to climb until there is enough flow of boosted air to overcome the leak. To achieve this the turbo might have to spool up to produce say 12 psi before the ecu registers 7psi and starts operating the solenoid valve to open the waste gate. So now the ecu is seeing 7psi but the intake is at 12 psi.
Own the day
The OEM system is a very crude simple open/closed solenoid with an rpm trigger ( 4500rpm ) which opens the solenoid to allow a higher boost level.
It does not have any means of closed loop control to actually control or target any boost setting
Really though the best thing is just get rid of the OEM stuff and just run either a bleed valve or proper EBC.
If it's still a low boost setup, the extra boost low down will make it feel a lot faster.
Having used many forms of boost control over the last few decades....I would absolutely use a decent electronic boost controller.
They just give you more flexibility and options even if a simple mechanical valve can work too.
Plus whilst there are caveats with in car adjustability....it also makes setting up a lot easier than driving, getting out, bonnet open, messing, back in, drive about...repeat etc.
Same with carbs vs EFI.....both can work, the former usually very annoying when tuning, the latter a little less so.
Mr Joshua
Member #: 1954
Luton Bedfordshire
The OEM ecu as fitted to the metro turbo has a boost reference line from the plenum chamber into the ecu. As stated above in standard trim above 4500 rpm the ecu ramps up the boost by means of rapidly opening and closing a solenoid valve bleeding pressure of the back of the waste gate actuator. The ecu carries out this function in order to raise the boost pressure from 4psi up uoto 7psi in some cases I have heard of 10psi. In order to hold this higher pressure it reads the pressure in the plenum chamber and when the the higher pressure is reached it regulates the solenoid valve to maintain this pressure. So above 4500 by the the introduction of a bled valve you can increase your maximum boost from 7psi to what ever you wish knowing that even at a mind bending 9000rpm your only developing the boost you want. The ecu cannot control to a boost pressure unless it knows what the boost pressure is.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
Double post deleted
Edited by Mr Joshua on 28th May, 2022.
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
This is the line I am referring to. Note I'm guessing most people only pulled this to the fuel pressure regulator. In the metro turbo this line has a tee to feed pressure into the ecu.
Own the day
Steve220
Member #: 11017
Shropshire
Bin the ecu completely, fit a EBC (i recommend the AEM one) and enjoy!
EBC's make a lot of sense.
The factory thing....not so much lol
Yoda74
Member #: 11728
Uden, Holland
Do you mean this one?
https://www.aemelectronics.com/products/boo...ontroller-gauge
Isn’t the harness much to extensive?
How do you plumb it in?
The AEM is a very very basic EBC with few options for control.
At the budget end, even this offers more including boost by rpm which can be useful.
https://ldperformance.co.uk/product/electro...ost-controller/
And you plumb the solenoid in exactly the same way you plumb a bleed valve in. ( wel..as per instructions for the controller )
Wiring can be as minimal as you want to make it, depending on features needed.
Or for multiple control options ( maybe too many )
https://sirhclabs.com/
Edited by stevieturbo on 19th Jun, 2022.
Yoda74
Member #: 11728
Uden, Holland
Just bought a GFB Atomic bleed valve.
Is this the way to go now: ?
Disconnect the ecu, lose the boost solenoid, block the tube that goes to the ecu, block th tube that goes to the solenoid?
Place the bleed valve in the tube that comes from the wastegate and start with it shut?
Than open it up gradually untill the wanted boost is reached. (9psi or now)
Am I missing something or doing something wrong?
Mr Joshua
Member #: 1954
Luton Bedfordshire
The waste gate actuator and solenoid valve lines are the same line
Own the day
Depends what you want to do.
Either connect as per manufacturers instructions, or as described earlier in the thread retaining the basic factory electronic controls.
Yoda74
Member #: 11728
Uden, Holland
But the line from the wastegate actuator goes to the solenoid now and stops there?
The line from the plenum to the fuelpressure regulator, has now 2 tees, one to the ecu and one to the boost gauge. Should I use the T that now goes to the ecu as line from to the Bleed valve?
Yoda74
Member #: 11728
Uden, Holland
Dived a bit deeper into the bleed valve knowhow.
I ran into this picture in a different bleed valve topic.
Sorry for lending your pic, but it’s for a good cause.
My enginebay is quite full it seems that I have not been looking well enough.
I thought the t-piece on this pic was the inlet on the wastegate actuator, but it’s actually the t-piece on the turbo right? And the inlet on the actuator is somewhere hidden under it.
I will have to block the line that went to the solenoid (top of the t-piece) and put the bleed valve between the t-piece and the wastegate actuator?
I really wonder how I’m gonna reach there…. *frown*
Edited by Yoda74 on 8th Aug, 2022.
