Page: |
Home > Show Us Yours! > Efi Supercharged Blow Through | |||||||
76 Posts Member #: 8976 Advanced Member |
1st May, 2018 at 09:57:00pm
Hi all I've been registered for year but never posted a topic but now I think its time to show the progress and giving you an idea of how I'm converting from carburettor to multi point. So after hours searching on the forum trying to understand the problem in injecting an a-series engine and trying to find the best ecu that will work on a 5 port head, I came with a conclusion and bought a MS3X from Extraefi. As for injector I'm using siemense deka, two 480cc for primaries and two 875cc for secondary's.
Edited by turbominik on 1st May, 2018. |
1st May, 2018 at 10:26:45pm
This is the crank and cam sensor. |
2094 Posts Member #: 9894 Post Whore Dorking |
1st May, 2018 at 10:40:00pm
Sounds like a nice setup.
1st May, 2018 at 11:05:57pm
Its a steel round nose flip front but with 3 inch extra
Edited by turbominik on 2nd May, 2018. |
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
2nd May, 2018 at 08:45:10am
Interesting looking project. Did it work ok on the carb? |
2nd May, 2018 at 09:12:56am
Interesting cam sensor.
2nd May, 2018 at 01:44:29pm
Hi it worked well on carb but you now you always want to improve something
2nd May, 2018 at 02:59:08pm
On 2nd May, 2018 turbominik said:
I want to ask a question how can i host pictures from google photos because when I put Img in square brackets at the beginning and at the end of the url the photos are not displayed in the post? Lots of forums won't work with google's photo system - I'm not sure about this one - but have you added the forward slash to the second set of square brackets ??? [ IMG ] .... [ /IMG ] but without the spaces between the square brackets and IMG (if I omit the spaces in my example the forum expects an image in between where the ... is in my example....) Edited by Rod S on 2nd May, 2018. Schrödinger's cat - so which one am I ??? |
2nd May, 2018 at 07:38:14pm
I want to ask a question how can i host pictures from google photos because when I put Img in square brackets at the beginning and at the end of the url the photos are not displayed in the post? Lots of forums won't work with google's photo system - I'm not sure about this one - but have you added the forward slash to the second set of square brackets ??? [ IMG ] .... [ /IMG ] but without the spaces between the square brackets and IMG (if I omit the spaces in my example the forum expects an image in between where the ... is in my example....) Yes I added the forward slash without any spaces to the second set of square but it didn't work but when I post the url only the link works and the photo is opened in an other window. |
2nd May, 2018 at 09:50:14pm
So finally I got hold on how to host pictures from google photos and now I can show the progress on the intake manifold.
2nd May, 2018 at 09:58:25pm
Here is the custom fuel rail
Edited by turbominik on 3rd May, 2018. |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
2nd May, 2018 at 10:20:22pm
That's some nice DIY.
2nd May, 2018 at 10:57:04pm
Impressive!
3rd May, 2018 at 02:58:34pm
Someone stood at the mill a long time doing those pieces!
3rd May, 2018 at 03:47:55pm
this looks like the install that was in the mini that JohnySTI used to have, it wasa Vmax blowthrough prototype IIRC.
3rd May, 2018 at 07:32:24pm
On 3rd May, 2018 TurboDave16V said:
Someone stood at the mill a long time doing those pieces! Where are you located? I feel like I've seen this mini before? Hi I'm located in Malta and yes i stood a long time at mill i think for each runner it took more than 12 hours and also countless hour to design them on the cad, but I'me very pleased on how they came. |
3rd May, 2018 at 07:54:57pm
Hi a little bit more update, here are some pics of the runners in place and cardboard model of the plenum just to have an idea of the clearance between the bulkhead and plenum.
7th May, 2018 at 07:57:08pm
Hi a little bit more update I've started to build a part of the plenum which is this
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
8th May, 2018 at 05:29:43pm
Nice build In the 13's at last!.. Just |
8th May, 2018 at 07:29:42pm
Hi today's update. After a little bit of grinding, polishing and adding an end plate the part ended like this.
Edited by turbominik on 11th May, 2018. |
11th May, 2018 at 07:55:59pm
Hi today I thought that I should also show some photos of the interior.
17th May, 2018 at 08:51:11pm
Hi a little bit more update, today I've finished the throttle body flange, its made from 10mm aluminium flat bar. The throttle body is from a renault megane, it has a 4 wire stepper motor for idle control.
774 Posts Member #: 6724 Post Whore Wootton Bassett |
31st May, 2018 at 07:00:58pm
looking great so far! |
31st May, 2018 at 08:26:35pm
Is that mig welded alloy?
1st Jun, 2018 at 08:33:49pm
It's tig welded alloy
On 31st May, 2018 TurboDave16V said:
Is that mig welded alloy? |
Page: |
