Page: |
Home > Beginners Tech > Clutch - have I put it together wrongly? | |||||||
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
30th Jul, 2017 at 03:44:55pm
Hi Guys. I've spent the last hour searching without luck, I'm hoping someone on here can help me with a clutch problem.
31st Jul, 2017 at 09:45:29am
Looks like you need to loosen the throw out stop nut (2 big nuts lol) Edited by JT on 31st Jul, 2017. My build thread..
31st Jul, 2017 at 10:29:36am
is it pre vert?
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
31st Jul, 2017 at 10:40:44am
I'm going to assume it's Verto from the year and the operating arm/slave cylinder.
31st Jul, 2017 at 11:30:58am
looks like either the end has snapped off the arm, or youve missed the top hat out of the assy, On 28th Aug, 2011 Kean said:
31st Jul, 2017 at 12:38:00pm
Is the plunger 180 deg out of orientation to the release arm? I've made this mistake before now.
5th Aug, 2017 at 06:07:12am
Thanks for the suggestions guys.
5th Aug, 2017 at 03:44:14pm
Be careful of winding the nuts back too far.
6th Aug, 2017 at 08:01:39am
Thanks Rod. I've taken the clutch cover off but unfortunately there isn't enough room to get this totally out.
Edited by Cooper1999 on 6th Aug, 2017. |
6th Aug, 2017 at 09:13:23am
On 6th Aug, 2017 Cooper1999 said:
It was loose (wobbly) on the end of the shaft: Providing you mean the whole assembly as per your photo, that is fine because it is designed to self centre and align itself on the end of the top hat. However the photo of that bit is very indistinct. There should be a four-legged attachment cage which I think I see intact but the actual bearing is inside that. The cage should not rotate (provided the release arm is fitted) it should only have a little bit of rotational movement as there is clearance between the operating arm and the hole in the plunger, but the arm stops it spinning. However, for the bearing itself you should be able to see the inner race which rotates freely inside the cage bit. This is where your photo isn't clear. That inner bit should be slightly above the retaining cage, spin freely and have a matching shiny mark to the end of the top hat (which it presses against). If you can do this in situ, first remove the two throwout nuts completely, then remove the clevis pin and operating arm and the whole plunger will pull out inwards. Do not rotate it as you do so and then you will see if the correct end of the hole - the bit Tom was talking about - as you pull it out (the bigger end of the hole is what the operating arm should go into). Then you can have a good look at the bearing. EDIT - photo to follow in a minute Edited by Rod S on 6th Aug, 2017. Schrödinger's cat - so which one am I ??? |
6th Aug, 2017 at 09:34:09am
6th Aug, 2017 at 09:59:33am
On 6th Aug, 2017 Rod S said:
In fact, looking again at your photo, and comparing it to the MiniSpares photo which is the reverse side of the bearing, I think you have your release bearing on backwards........ Agreed
6th Aug, 2017 at 11:07:31am
Thanks for the quick response guys - having looked at the car again this morning I'm sure with the aid of lots of swearing I'll be able to take the arm apart/swap the release bearing through 180 degrees.
6th Aug, 2017 at 03:11:37pm
If you haven't already, go ahead and notch the bottom four holes in the clutch cover to make it easier for next time! On 17th Nov, 2014 Tom Fenton said:
6th Aug, 2017 at 04:33:06pm
Hi Dave - notching the clutch cover, can you explain this a bit more please? (No = I haven't done this)
6th Aug, 2017 at 04:53:08pm
Release bearing is now correct.
7th Aug, 2017 at 06:00:11am
Dave means open up the bottom four holes in the wok so that they are slotted. Then you can just loosen the bolts and lift it out rather than having to completely remove the bolts. In the 13's at last!.. Just |
9th Aug, 2017 at 12:11:26pm
Ah - I see. That makes sense.
9th Aug, 2017 at 12:56:21pm
9th Aug, 2017 at 01:50:39pm
On 9th Aug, 2017 Joe C said:
um but youve got that bit off already, From an earlier comment Joe, I don't think it is out, just off but still trapped in the engine bay of the car (whatever an MM is) On 5th Aug, 2017 Cooper1999 said:
But it looks like its time to start stripping this down now then. There's a little more space in the MM than in a mini (less of an inner wing) so hopefully I'll be able to strip this in situ. Schrödinger's cat - so which one am I ??? |
9th Aug, 2017 at 03:17:35pm
Ah, ok,
10th Aug, 2017 at 06:20:55pm
Sorry, was being lazy. It's a Marcos - bonnet opening'so too small to get much out of (engine needs to go in from below). |
10th Aug, 2017 at 08:18:34pm
Cool! always wanted a marcos
14th Aug, 2017 at 07:25:03pm
IT WORKS!!!
14th Aug, 2017 at 08:27:41pm
That looks nice. Lovely paint job! My build thread..
Page: |
