Home > For Sale > Various Performance / Turbo bits
garethlloyd
Member #: 616
Birmingham
I’ve been collecting bits for my project for the best part of 10 years now. Recently I’ve come to the decision that I’m not going to build it so all the bits below are offered for sale. These items are located in B33 Birmingham and are priced as collection. I can look at postage but you would have to bear with me. I MAY be able to bring some of them to Himley Hall however I will need to confirm this later in the week
1 pair of carbon fibre bumpers. Generally good condition, one has gone a little bit milky (not much though) where the sun has got to it. These would polish up well. There is no damage to the lacquer etc.
Please note these do not have mounting points on the underside so you would have to work out how best to secure them
£100
Wizards of NOS nitrous oxide kit. Brand new and never used comes complete with;
1no. Fuel Solenoid
1no. Nitrous Solenoid
1no. 25bhp injector
Nitrous and fuel pipework
Bottle brackets
Mirco switch and various other sundry items
1no Bottle with some gas in it, I’ll have to dig this out as I’m not too sure where it is.
Kit is complete and very easy to install, you could have this on your car in a couple of hours.
£250
1 pair of FORCE RACING mini special split rim wheels. These were purchased directly off Carl when he had a clear out. They have never been used and are in brand new condition. I have only pictured one as the other is still wrapped up. They are painted metallic gold and the barrels are silver. They are complete with allen head bolts but no wheel nuts.
Size wise, they are measuring at 10x7 with just over 3 inches of dish.
£170.00
Lifeline 2000 2.25 litre plumbed in fire extinguisher. This was puchased off ebay and then serviced and refilled by lifeline in Coventry. This has then sat in the garage for 10 years. It’s still fully charged and the gauge is reading green but obviously out of date for motorsport. It comes complete with base and push fit aluminium pipe (circa 5m) and also 1no. nozzle only.
£150
1 pair of new old stock steering arms. Casting number is 896A
£20
1 pair of new old stock disc brake hubs. Still in wax paper and original packaging
£70
1 pair of new old stock steel headlamp bowls with rubber gaskets.
£20
Minispares aluminium beam axle, complete with all fixings, brackets and hand brake quadrants.
Brand new, shot blasted and powder coated black. Dry built and pushed around the garage for a while. Great condition with just some marks on the back of the brackets where they have been fitted
£175
KAD rear alloy suspension arms. Again, new and never used on the road. They have been machine polished and look really good. They need a light hand polish now to bring back the shine. They have been dry built and pushed around the garage. I’ve had these a while and they will need new rubber dust sheilds as they have perished.
PLEASE NOTE THESE HAVE BEEN MACHINED TO REMOVE THE TRUMPET SOCKET (IF THAT’S WHAT YOU CALL IT!) AND ARE ONLY SUITABLE FOR COILOVERS
£400
KAD rear disc brakes. Again, these are new and have only been on the car during dry build. One of the discs has a slight amount of very minor surface rust but other than this they are as new.
£625
Mirage Turbo manifold kit (to suit Garrett T2 turbo) complete with a metro turbo inlet manifold. The inlet is quite nice, it has been blasted and ported. The waterways have been plugged and there are 2 threaded take offs for boost pressure etc. Complete kit with inlet manifold, turbo manifold, turbo elbow and down pipe. If you don’t know, these allow you to fit a turbo without modifying your bulkhead
£300
Mini cooper injection throttle pedal, again new item still in packing.
£5
Stainless steel MK1 mini door check straps. 1 pair, never used
£15.00
Metro Turbo original fuel pump with P clip. Used and untested
£20
New old stock SU metro turbo carb rebuild kit. Box has got a bit damp but all is complete (inc. instructions and ok)
£45
Metro turbo fuel pressure regulator, second hand.
£35
Smiths Rev counter. Not in the best of condition and sold as untested. Will require a clean up at least.
£50
A used pair of original hi-lows. As these are originals, they are adjusted by a hex key down through the top of the subframe. The grease nipples seems to have also been replaced with grub screws. I assume to lock the thread off. Hex key available from minispares
£20
Filter King adjustable fuel pressure regulator with glass bowl and filter. Filter looks new
£35
New old stock indicator units. 1 pair complete with packaging (plastic lenses)
£15
A pair of adjustable bottom arms with rose joints complete with rose jointed tie bars. For whatever reason the tie bars and rose joints don’t match. Despite the difference these can be adjusted to matching lengths
£70
Stuff also for sale but not pictured. I’ll put these up separately so bear with me if you’re interested in these (I have to try and find them!!)
New old stock carbon boot floor – purchased from Minispeed
New old stock carbon parcel shelf – purchased from Minispeed
2x Garret T2 Turbo chargers taken from Renault 5 GT Turbo for rebuild
1x 2WD Sierra Cosworth intercooler
MED 1430 engine and gearbox (I need to dig this out and check the spec first though)
2x 12g295 cylinder heads
A set of 4 powder coated 10x6 banded steel wheels
Edited by garethlloyd on 3rd May, 2017.
Dibs on that mirage settup + inlet 😂 pmed mate
Edited by Brett on 3rd May, 2017.
Edited by MikeRace on 5th May, 2017.
what condition are the 295 heads? have they been skimmed? complete etc?
seancv1
Member #: 10973
Pm sent
Oli
Member #: 1910
Wilts
interested in the 1430
Really like the look of that nitrous setup too *hehe!*
ppinno
Member #: 10088
West Sussex
Could be interested in the parcel shelf, how much?
05bwardl
Member #: 9991
lichfield ,staffordshire
if the rear beam can come with coil overs id be interested in that
First dibs on the Hi-Lo's
PM inbound
garethlloyd
Member #: 616
Birmingham
All PM's replied to.
Brett, if you want the nitrous kit too I'm sure we can negotiate on the price *smiley*
MikeRace, yes coilovers will be for sale. Again they haven't been used. I'll get some photos and price up in round two!
RobGavin, both stock deck height. One ported, one bone stock. I will have to find them and get some pics. I'll try and do that over the weekend
Oli, 1430 is currently complete with s/c gearbox. Was a runner but a long time ago, again I need to dig this out, picture and work out the spec. Give me a few weeks on this one.
Some items provisionally sold. will update list when ££ drops tomorrow.
Many thanks,
Gareth
Oli
Member #: 1910
Wilts
Gareth
Cheers Gareth, let me know when you get round to it, no rush at all.
ta
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
Interest in one of the 295, either one of them. What sort of price are you looking at, pm me if easier.
garethlloyd
Member #: 616
Birmingham
HI Mike,
Coilovers are rears. I'm afraid I don't have any front ones. I'll get some pics the weekend.
The_soon_to_be
I'll have a look over the weekend and come back to you.
Cheers.
Gareth
Adam_R
Member #: 1938
near Dundee
interested in the bumpers.
any idea if you could post them? and what it would cost?
edit: also the parcel shelf
Edited by Adam_R on 4th May, 2017.
tadge44
Member #: 2500
Buckinghamshire
Very tempted by the nitrous kit for my A35 - or is that a step too far ?
No its perfect, you buy it 😂😂
So i cant *hehe!* *hehe!*
slater
Member #: 1291
Suffolk / Birmingham
Would you do a deal on the wheels, brakes and kad arms? In Birmingham so easy to pop over and collect.
Ah bugger its fronts im after.
Ill leave them then, ill alter my post up top to save any confusion.
On 4th May, 2017 garethlloyd said:
HI Mike,
The_soon_to_be
Cheers.
Gareth
D4VE
Member #: 10749
lowestoft suffolk
U doing london 2 brighton? Or anywhere near london or brighton.?. depending on whats left after all the replys?
Nothing gets past Dave lol
garethlloyd
Member #: 616
Birmingham
HI Guys,
Apologies for the delay.
Slater, yes could do a deal drop me a PM and we can discuss.
I'm afraid I'm not going to any mini shows in the near future, I am going to Portsmouth in June if that's any good?
Bumpers are postable as is parcel shelf. Circa £10 for postage if interested?
ppinno
Member #: 10088
West Sussex
I'd be interested in the parcel shelf still. Could arrange to collect when you're in Portsmouth as I'm only 20 mins away. How much are you looking for it?
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
Hello Pinno, Is the nitrous still FS?
Clive1330
Member #: 10230
Do you still have the wheels
