Page: |
Home > General Chat > top arm angle on very low cars | |||||||
218 Posts Member #: 9213 Senior Member Scotland |
20th Dec, 2016 at 11:48:12am
Hi guys,
20th Dec, 2016 at 11:59:29am
The quickest fix is to put hydro top arms on. These have the knuckle joint further out and do help. Geometry is the same, but the pickup point increases the effective spring rate.
20th Dec, 2016 at 12:08:21pm
Standard Bump stops went long ago . I mean the metal of the arm hitting the metal of the subframe! yeah, ive added these to the dampers as well as raising the top pickups.
20th Dec, 2016 at 12:34:57pm
Yeah, I meant the metal bit. I cut mine back a couple of inches.
224 Posts Member #: 9987 Senior Member Amsterdam |
20th Dec, 2016 at 05:55:38pm
Just to be sure....did you already solid mount the subframe without spacers as the Miglia boys do? |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
21st Dec, 2016 at 03:00:27pm
No the car is solid mounted but with spacers. http://www.twin-turbo.co.uk
21st Dec, 2016 at 06:01:47pm
Ok, that would be a good start to restore suspension geometry / articulation. Just redo the engine mounting points so it drops down an equal amount as the subframe is raised....and than Bob's you mother's brother.
Forum Mod 4828 Posts Member #: 154 Post Whore Midlands |
21st Dec, 2016 at 06:54:27pm
If you're running it low then you'll probably want to look at raising the engine to keep the driveshafts at a sensible angle. That's the next job on my list. On 20th Oct, 2015 Tom Fenton said:
21st Dec, 2016 at 11:36:25pm
Not sure about the bottom arms, it's all in bits now. You can see in this picture how bad the lack of damper travel, driveshaft and top arm angles are though...
Edited by nky_84 on 21st Dec, 2016. |
22nd Dec, 2016 at 08:47:20am
Yeah, it's hard to tell on that photo, but keeping the bottom arm horizontal at rest is as sensibly low as you want to go. So that might be a tweak to start with.
243 Posts Member #: 1261 Senior Member Droitwich |
22nd Dec, 2016 at 09:46:36am
I'm in the same boat as nick, and the main reason for raising the engine was so the cv's sit properly in the pot joints. If you don't, then for 180 degrees the cv's ball bearings are outside the pot joint. Slide your cv boot back and check.. Only other way to fix it would be to get an extended driveshaft, but then ull never be able to have your driveshaft horizontal again because it'll bottom out in the joint.. If that makes sense |
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
22nd Dec, 2016 at 11:58:46am
Its not exactly a quick fix but raising the inner pivot of the top arm an inch or two will do wonders for the geometry. Combine it with a bottom ball joint spacer of the same length and switch to coil overs mounted as close to the wheel as you can get them and i should think you will see a massive improvement. |
22nd Dec, 2016 at 02:13:41pm
I tried the bottom ball joint spacer and it was terrible. It increase the scrub radius and made the car uncontrolable on exit of tight corners. I went slower at a number of events.
22nd Dec, 2016 at 03:05:37pm
22nd Dec, 2016 at 04:33:19pm
The problem I see is that: Now the bottom arm is above horizontal already at rest and the top arm is more horizontal that it would be normally (as the arm pivot is moved up) is that the wheel will have less camber compensation in compression. worst case it might go positive.
Edited by wil_h on 22nd Dec, 2016. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Dec, 2016 at 05:55:19pm
When i do the metro im planning to ditch the bottom ball joint and use a bush in the bottom arm instead. Then i can make an offset extender if needed to correct the KPI/Scrub radius issues. The only way i can see of doing it without making hubs to suit from scratch.. |
690 Posts Member #: 9962 Post Whore |
22nd Dec, 2016 at 05:59:30pm
Raising the upper inner joint alone will reduce the front roll centre height and will reduce camber compensation.
Edited by Aubrey_Boy on 24th Dec, 2016. |
22nd Dec, 2016 at 06:18:06pm
Absolutely Aubrey. What I said but better!
22nd Dec, 2016 at 06:45:42pm
If you do move the inner joints of the upper and lower arms to correct things and don't move the rack then the inboard steering rack ball joints are no longer in line with the upper and lower arm inner joints, when this happens the problem is bump steer correction.
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
22nd Dec, 2016 at 08:01:49pm
On 22nd Dec, 2016 wil_h said:
Absolutely Aubrey. What I said but better! Looking at Nicks car, as the cones are not used, why not just cut the subframe towers down and modify the lower mounts to bolt to the floor. Then you can have the suspension in a sensible position. The bump steer can just about be corrected with extended track rod ends connections to the steering arms. So simple! But what a brill idea!!? Anyone done this before?? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
22nd Dec, 2016 at 08:20:56pm
I've seen it done on a few cars, not just Mini's and as mentioned above it's and extension of what is done with Miglia's
Edited by Aubrey_Boy on 22nd Dec, 2016. |
23rd Dec, 2016 at 09:58:18am
What an amazing thread this has turned in to.
23rd Dec, 2016 at 10:39:29am
Absolutely Aubrey. What I said but better! Looking at Nicks car, as the cones are not used, why not just cut the subframe towers down and modify the lower mounts to bolt to the floor. Then you can have the suspension in a sensible position. The bump steer can just about be corrected with extended track rod ends connections to the steering arms. I tried this, the logic being, like you say, if your going to move all the pick-up points and the engine, why not just lift the whole subframe by cutting down the towers. The problem was the steering rack, specifically getting round the steering rack and back to the lower sub-frame mounts. Annoyingly you cant easily lift the steering rack on a mini. You'd basically have to either mount it inside the cockpit, or move the floor.. which both require moving all your pedals among other things. I got as far as cutting it down but trying to get back to the lower mounts whilst retaining some structural integrity defeated me. In the end I moved the pick up points. With regards bump steer my plan is to either hand a lot of money over to carl for his parallel plate front hubs, so I can move the joint lower, or cobble something together with hopes and dreams |
23rd Dec, 2016 at 02:01:39pm
I think im going to have a go at making a string computer / modeling things in one of the digital ones e.g http://www.racingaspirations.com/apps/susp...try-calculator/
489 Posts Member #: 9159 Senior Member Devon |
23rd Dec, 2016 at 07:50:14pm
On 22nd Dec, 2016 Aubrey_Boy said:
I've seen it done on a few cars, not just Mini's and as mentioned above it's and extension of what is done with Miglia's EDIT: The caveat I would make is that if you cut down a front subframe to move the suspension pick up points up (which is what I would do) that you really have to address the coil over issue: A rubber coned Mini has damping from both the rubber cones and the dampers, even in standard form the dampers on a Mini are near to falling rate which is understandable due to the 'added' damping from the rubber cones themselves. With coil overs all of your damping is from the dampers / coil overs themselves. Many people cite that rubber cones are rising rate, I have measured several, new and old in a 'static' form and they behave in a pretty linear rate in my opinion and others I know have found the same.... The rising rate mainly comes from the kinematics, these kinematics are not present when you fit coil overs to the standard damper pick up points.... You have to move the damper upper point inboard or the lower point outboard so that the coil over angle is always less than 90 degrees to the upper arm angle even at full bump, if you can't do that you will always have to run a much stiffer spring than is really necessary and will probably complain that coil overs are sh1t compared to rubber cones as seems to be the case in a lot of instances. There seems to be this philosophy that Mini's only handle well on rubber cones, in my opinion it's not just the rubber cone it's the installation ratio which makes it rising rate. Yes there are coil springs which replace cones.... Most I have tested are softer than a rubber cone when tested at what I will call a 'static' rate, steel springs are not sensitive to frequency, rubber is sensitive to frequency so rubber cones I have measured are not only stiffer but get stiffer with frequency compared to the steel springs I have tested. But a properly mounted coil over solves all of these issues. |
Page: |
