Home > 998cc > 998cc moke (1979) plan for full elec engine management and Turbo
s900t8v
Member #: 11485
Hey guys
I am an aussie in vic and I have just bought a 1979 998cc moke that I have not yet picked up, its missing numerous engine ancilleries like distributor coil etc, which I feel would probably cost me a lot to source and I would likely need to spend time rebuilding these bits...
but to skip the whole frustrating stage of screwing around with distributors etc I have a complete Trionic 5.5 engine management system in my shed that I could use for this project, basically its an all in one EFI system that allows you to live laptop tune Ignition, Injection and Boost control really easily. Its Saab made, and I run the system on an earlier model Saab I own - it originally came out on saab 9000s.
It consists of
injectors, fuel rail, fuel pressure reg, intake temp sensor, coolant temp sensor, idle air control valve, throttle position, manifold air pressure sensor, ignition cassette, crank position sensor, and o2 sensor to run the system
the ignition cassette uses ionisation current detection to synchronise or determine what stroke each cylinder is on, it also detects detonation or the precursors of detonation before it occurs (by measuring voltage across the cylinder) it then has a few ways of preventing detonation by reducing ignition timing, adding fuel, and then finally reducing boost. its a very elegant and sophistciated system, with far more capabilites than megasquirt etc etc.
Basically from what I've read the big issue with fuel injection is the Siamese ports - I know everyone says semi sequential or TBI is the way to go for siamese ports
- Trionic has the ability to individually adjust each injectors fuel volume (via a correction factor) and also each cylinders ignition timing, as well as being able to change from fully to semi sequential if desired. This means I could theoretically add more fuel to the inside cylinders. it also has complete ability to alter injection angle (crankshaft degrees) etc to improve efficiency etc.
I have a wideband innovate MTX-L I use for live tuning.
so questions >
has anyone ever welded dividers into the ports - because I am going to go turbo I dont feel the slight restriction would be too harmful, it would also reduce the risk of the inner cyls leaning out.
whats a good turbo (and what cars do they come on second hand) no problem for me to build my own inlet and exhaust manifolds ive read people talking about G15?s? I'm thinking cheap/2nd hand, and if turbo needs a rebuild thats no problem.
in terms of making oil feed and return are there any threads on where these lines are usually plumbed in on 998cc engines?
what sort of engine mods do you need to do to make the engine turbo ready - like do you need different valves, rockers,. different head gaskets, etc??? - I should mention that the engine management system resolves knock before it occurs or takes drastic steps to protect the engine in the event of knock... with this system I've found I dont normally need to worry about reducing compression ratio, and I imagine on 998cc engines from the 80s probably fairly low already?
any other major considerations, other than space/location for turbo, I have seen people run the turbo off to the side to allow room and with a tig and some time dont see that being a particular problem,
thanks for any thoughts or questions or hints.
cheers
Ed
I'll only cover the EFI issues and leave the other questions to the rest..
Not everyone says semi sequential or TBI is the way to go for siamese ports - sure TBI, normally referred to as wet manifold or electronic carb on this forum, is the easiest but doesn't actually deal with the issue of charge robbing on a siamese port engine, it just makes it easier to tune than filing needles on an SU carb. And that in itself is not a bad thing at all.
However, there are a small number of us who are running timed sequential port injection on turbo A series 5 port engines and I know of at least two (including one in Aus) running the same setup on N/A B series engines.
The key word being timed injection, not just sequential.
The thing you have to bear in mind if considering the Saab ECU is, despite all the bits you mention (which are fairly well known) I would be 99% certain that its fundamental design will be like virtually every other OEM system, whether batch, semi-sequential or fully sequential in that it will run relatively small injectors at relatively high duty cycles, as high as 85% at full load.
If it works like the majority, what 85% duty cycle means is most of the fuel is injected onto the back of a closed valve and only part through the valve when it is open.
That is why batch and semi are not a lot worse than fully sequential, it doesn't really matter when you inject the fuel so long as you inject the right amount during a single engine cycle (720 degrees) onto the back of the right valve(s).
BUT, of course that only applies if there is one injector per cylinder feeding only one port/runner per cylinder so the fuel can only sit on the correct cylinder's valve(s).
Once you have two cylinders fed by the same port/runner, it doesn't matter whether you put two injectors side by side and run them from the standard ECU or connect the outputs together (if the ECU internals allow it) and use a single injector, when the fuel goes down the runner on two 85% duty cycles, apart from about 1/4 of it which will go through the outer cylinder inlet valve when it is open for it's 1/4 of the cycle, the rest will sit on the backs of the two closed valves and virtually all of it will get sucked (or blown by a turbo) into the inner cylinder because that valve always opens first. No amount of trimming will change that, the only way to change it to have an ECU that uses much larger injectors - that can run a much lower duty cycle - and can time the injection pulses so the fuel goes through the correct valves only when they are open (or just before in the case of the inner one as the first shot can only go into the inner anyway).
So if the Saab ECU can be re-programmed to run much smaller pulse widths and you can programme in the injection timing (not just the injection trim), and that injection timing will need to vary at different RPMs because the transit time of fuel is different to air due to different densities, then you might make it work.
But to set it up you need to monitor the inner and outer cylinder AFRs independently and, if you want any form of closed loop control, the ECU would need the ability to read two widebands and know which to apply to which injection pulse and so on. In other words it's not easy.
Rover achieved it with the MPI Mini, they doubled up the output channels of their basic MEMs unit to feed two large injectors and ran a sequential timing injection regime which was of a mixture of either two short pulses when the respective valves were actually open or one longer pulse over the period the two valves were open, timed so the correct amount went in each cylinder.
And, as I said at the beginning, a few of us do the same with aftermarket ECUs capable of varying the injection timing in a user specified manner and either very large injectors or staged injection (or both).
The reasons most OEMs use small injectors with large duty cycles are manyfold but the main one (apart from cost) is long pulsewidths are much more accurate than short because the dead time (the open/close time) of the injector becomes a much smaller percentage of the pulse and dead time is inaccurate and certainly not linear so if you want accuracy for emissions control you want a nice long pulsewidth compared to the dead time.
But trying to run a high duty cycle regime on a siamese port is, IMHO, doomed to failure.
I hope that all made sense.
s900t8v
Member #: 11485
Hey rod
thanks for the fantastic information.
well you can put any size injectors you like in the trionic system, it has a fuel injector constant that you can use which scales all the related fuel maps, and then you can modify the main fuel map or scale it down to reduce the duty with larger injectors.
the stock saab injectors put out about 345cc/min they're designed for a 2L engine. what flow rate injectors are people normally using?
the injection timing symboltable is based on rpm and load and allows you to be pretty precise in that regard.
I just thought i'd ask a dumb question but the engine inlet valve timing it is completely symmetrical right?
does anyone have the standard inlet valve timing in crankshaft degrees written down? it would help me get my head around how I am going to map it out.
s900t8v
Member #: 11485
but seriously, to remove all these problems could I just divide up the ports in the head by welding dividers in? has anyone done this?
seems it would resolve a lot of the tuning issues.
s900t8v
Member #: 11485
here is the crankshaft delay map
and here is my duty cycle calc lol - definitely need bigger injectors ha!
s900t8v
Member #: 11485
for my saab
s900t8v
Member #: 11485
so the two main things I wonder
- what duty cycle do I want to aim for
- what size injectors should I start with (thought maybe these saab ones could be a good starting point at 345cc/min
now i've never had to mess with the crankshaft delay map, so I am not sure about how to interpret it, I know that its referring to crankshaft degrees, and its obvious the delay reduces as RPM and Boost increase... ???
I suppose lets talk about my saab for example
if this is the cam timing (8 valve)
Inlet opens: 12deg BTDC closes 40deg ABDC duration 232
Exhaust opens: 62deg BBDC closes 2deg ATDC 244
I want the injection to be happening with the inlet valve open riiiight,
so how does that correlate back?
it seems like the delay map is telling it to inject onto closed inlet valves - ?would this be to reduce emissions when cold?
Edited by s900t8v on 18th Dec, 2016.
Assumeg a 7-port head is out of the question, then diverds are your best bet if you want to use the ECU. I doubt it can be made to do anything close to what the the siamese MS3 code is doing.
I toyed with the idea of dividing the ports, but ended up buying the SC 7-port head. There was a company called Manx that used to make a 7-port head out of a 5-port by enlarging the inlets. I've seen one and it was a LOT of work, and actiually the one I saw was not divided in the head, it just had large ports with twin 40 bolted on with special inlet naifolds (which were a lot of work also).
My idea was to put a 'tongue' on the inlet manifold that split the port when you bolted it on. I was going to machine slots in the head to hold it in place.
Looks like your ECU will allow you to map injection timing. As long as it is a fully sequential system, then this is all you need. Forget dividing the runner as it will seriously restrict the breathing of the port.
It is very difficult to calculate the injection timing as there are so many variables. If you use 2 widebands then you will quickly find out what settings you need.
s900t8v
Member #: 11485
thanks paul, I will keep the forum updated! I reckon I can makei it work well, the fact I can control individual fuel and ignition timing means that even if I ran it sequential without any sort of care or provision for the siamese ports the system will adapt and compensate for different intake lengths very easily... had simialr problems converting my 8 valve saab to trionic - everyone said it coudlnt be done, just needed a bit of brains!
looking forward to cracking on with it, thanks for the information!
s900t8v
Member #: 11485
found a post on the mustang forums who did a really good write up
http://www.stangnet.com/mustang-forums/thr...process.736061/
so based on the above
looking at the injection delay map (in crankshaft degrees)
a full cycle is 720 degrees. I think 360 degrees is top dead center and the start of the intake phase. OR its possible that for this map 0 is the start of the intake phase - either way the map is obviously injecting onto a closed valve for a significant portion of the map,
means that in the scale of the map the intake valve is open from 348 degrees to 580 degrees. (for my saab)
now my thought would be because this is start of injection timing that the best thing to do would be just to set the delay to 348 degrees (or calculated just a little earlier to compensate for the delay from injector opening and for mixture to travel from injector to cylinder) on every single cell because the valve will not be open until that time irrespective of RPM or load.
the experimentation would be seeing how much earlier you could set it (as rpm/load increases) before it started to cause uneven fuelling the cylinders.
now I finally understand it!
the other big variable is if I can set my ECU which is fully sequential to run 4 squirts through 2 injectors, providing I use big enough injectors I wont have the problem of pulse overlap, but again this would be hard to measure and probably needs experimentation.
I am thinking of how to best create a manifold that would accomodate (all 4 injectors) 2 injectors per runner in such a limited space with a realistic fuel rail.
Edited by s900t8v on 20th Dec, 2016.
Depending on where you put the injectors, you will need to allow as much as 120-150 degrees of crank rotation for port travel time.
s900t8v
Member #: 11485
wow that is a lot of time!
thanks for the info!
Trying to cover some of your previous questions...
All the normal cams are symettrical, it's only the so called "scatter" cams that aren't, they used different timings between inner and outer cylinders to try to minimise the charge robbing effect.
Given what you have said about the ECU, this does look possible but it's not clear if you can vary the injection timing (advance as you describe it) with load and/or RPM.
EDIT - just re-read your previous posts and you say it can, but can you alter it on a "per cylinder" basis ? end EDIT.
The travel time that Paul mentions above varies with RPM and you get all sorts of wall wetting issues at different loads and ideally you want to be able to vary the inner and outer cylinder pulses seperately (or run what we call merged pulse).
If you are going for large injectors and through open valves you want to aim for a duty cycle of less than 25%. Otherwise you will be hitting closed valves. Whilst that is quite normal on an engine with seperate ports, for all the reasons I mentioned earlier you don't want to hit the outer valves when they are closed (as it will just get sucked/blown into the inner next time around) although inners early is OK as they open first.
But that is <25% per injection pulse.
So if you use only two injectors and they inject twice, ie cylinder 2 followed by cylinder 1 (firing order being 1,3,4,2,1,3,4,2,1, etc) they only need to be sized for 25% whereas if you use four in the manner you suggest, all four would still need to be sized for 25%.
Providing the ECU uses common Mosfets for the output drivers switching to ground (which is the most common setup) you can simply connect connect the cylinder one and two output (and three and four) together to drive a single injector on each runner. This is exactly what Rover did with the standard four cylinder MEMS ECU on the MPI Mini. Just look at the wiring diagram for the MPI. You would then obviously have to ensure the timing figures you use don't overlap or, if they do (which is a valid way of working, the merged pulse I mentioned earlier) you have the pulse widths set to take into account only one injector is being commanded open rather than two at the same time.
This is all assuming NON-staged injection (staging is what some of us use (with a suitable ECU) to overcome the dis-advantages of large injectors at idle although my current setup idles fine (better than any carb) with two X 1000cc injectors).
Anyway, it sounds an interesting project.
Edited by Rod S on 21st Dec, 2016.
s900t8v
Member #: 11485
hey thanks for taking the time to reply
ok thanks that makes sense about the cams I didnt think they would be asymm just off the bat.
ok sounds good about the injector info, so I could just run 2 injectors by bridging two pairs of injector trigger wires together.
I have the ability to individually control fuel on each injector via a correction factor which would also help me to get the fuelling right
this is what the injection timing map looks like - the X axis is Manifold pressure and the Y is RPM. - its 'start of injection' timing.
what injectors are you using?
what manifold are you using - did you make your own?
do you have a build thread or any pics?
not planning on doing staged - I think I could with the earlier batch fire software and I could adjust each pair of injectors - but that seems to complicated for me at this stage.
hey a random thought, we all worry about charge stealing, but if you got rid of the divider wouldnt the open valve just suck the mixture down?
so the issue is I am stuck with a 998cc, there are not many 1275cc motors in aus anymore and the ones that are very expensive like 2.5k each! I do a lot of work with 2 strokes so maybe I can embrace some cylinder porting and get a cheap cam to give it a bit more kick!
the project itself is in parts, I am not 100% whats missing but there is a lot of work in it (at least its a moke not a mini right) but I am figuring the main plan will be to half assemble it, figure out what is missing, and make a decision re the level of restoration, but I think to pass roadworthy it will need a lot of money !
Provided the ECU uses common Mosfet (transistor) drivers that switch low (injectors fed with 12V and ECU grounds them to open) then it should be no problem, it's what Rover did for the MPI. That assumes high z injectors, the most common now, but if the ECU was/is designed for low z injectors it may well not be possible as the outputs may be PWM (pulse width modulation to control current) or P&H (peak and hold to open them then drop current) in which case I'm not sure if the low z options would take kindly to pairing them up. A schematic (circuit diagram) of the ECU, if it's available, would confirm.
Honda racing ones but I use low z (I'm the exception on this forum, everyone else is high z) which is a personal choice because I prefer the consistency of the dead time which allows me to have a perfectly stable idle with 1000cc injectors running less than 1mS after deducting the dead time.
Home made manifold, TIG welded aluminium.
The second (staged injector) manifold, yet to be finished, is the same home welded alumimium.
There is a build thread but 99% of the photos have gone owing to photobucket throwing a hissy fit about 4 years ago and deleted pretty much everything.
I've been to Aus a few times but only ever seen three Minis (two clubman, one van, never a Moke) but that's still more than you see in the UK on an average week.... I didn't realise parts were so expensive down under (although it's going that way here too, esp. 1275 stuff).
My build thread:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=559956
998 with worked crank, lightened rods, Minispares Evo pistons, scatter cam, Turbo Phil 12G295 head, 1.3 roller rockers, straight cut box and drops.
Gt1752 on remote manifold. Tuned length inlet manifold - 400mm runner length. Impact of charge robbing eliminated (according to simulations).
MS3 driving 4 injectors, 2 primary and 2 secondary staged in on boost. LS logic level coils. Boost control, traction control, water injection control. Triple widebands.
Edited by Paul S on 21st Dec, 2016.
s900t8v
Member #: 11485
the mosfets x4 driving the injectors (ecu grounds) MTD3055VL N-channel MOSFET DPAK SMD
the injectors I have
345 cc/min @ 3 bar fuel pressure
Static Flow Rate: 31.6 lb/hr @ 43.5PSI = 239.4 g/min = 349 cc/min (+/-4%) Dynamic Flow Rate 2.5ms pulse width @ 100Hz: 6.68 mg/pulse (+/-6%) Coil Resistance: 16.2 Ohms (+/-0.35 Ohms)
Physical Dimensions: EV1 Body Type
Connector: Minitimer (Bosch EV6)
most of the tuning I am seeing done here in aus is NA, whereas I come from turbo land and think its a waste of time spending thousands on cams when you can just go forced induction. if you know how to tune it and can make your own manifolds it wont cost you thousands.
Edited by s900t8v on 22nd Dec, 2016.
You will need bigger injectors.
You need around 1000cc/min per port for 120hp as a guide figure.
s900t8v
Member #: 11485
right I get it now
so it doesnt matter if you have 4 injectors they still need to be able to deliver in a small injection window
how about siemens deka 850s
http://www.ebay.com.au/itm/Siemens-Deka-EV...q0AAOxykUZTjPL6
or bosch 1000cc? http://www.ebay.com.au/itm/1x-New-Genuine-...wEAAOSwstxVN4Ax
Thanks again paul!
I've used the Siemens Deka injectors on my last 2 builds, as much because you can sit them close together.
No real operating experience though.
Graham T
Member #: 1106
Hungerford, Berks
On 24th Dec, 2016 s900t8v said:
right I get it now
These 840cc/min injectors are what I am running on a 1310cc engine. (4 off staged)
Whilst they would be good to make reasonable power without staging, they might be too big for a 998cc engine at tick over?
Certainly on the 1310cc engine I am close to the limit of getting good tick over/ emissions with them. (the pulse widths being so small)
The 630cc/min version work well in an NA 998cc, but for turbo application, you may need to the consider that staging is necessary.
Injector selection will be a compromise between peak power and reasonable tick over/ emissions without the option of staging.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
right I get it now
If you are going to inject through open valves (esp. the outer which is the critical one), yes.
One large one, or two small ones side by side openning together doesn't matter but, as Graham says, once the capacity gets large the very low pulse widths become difficult to get good tickover and emissions control - the larger the capacity, the smaller the pulse width will be for a given amount of fuel. And once you are at very low pulse widths the distiction between actual open time and the "dead" time becomes blurred. There are other issues too like having to get your batteryvoltage correction spot on as battery voltage is likely to vary most at idle and mess around the dead time.
So that is where the benefit of having an ECU which can do staged injection comes in but from how you have described your Saab one it doesn't look like it can so you will just have to see how large you can go before idle is compromised.
s900t8v
Member #: 11485
hey thanks, ok I will look into trying the bosch injectors they are meant to be pretty well toleranced whereas the siemens have a rep of being fairly unreliable.
it's going to be interesting nonetheless!
what did you think of the idea of removing the port divider so the open valve can get access to the fuel sitting on the other valve? atomised mix will always take the shortest route, and technically fuel should never form on the back of a valve its too hot!?
Edited by s900t8v on 25th Dec, 2016.
s900t8v
Member #: 11485
hmm I am getting confused about this again
I need to keep the duty under 25% or just within the inlet valve open period right >
my question is
- is the need for huge injectors because at higher rpm if the injectors are not big enough they will overlap pulses which will result in loss of fuelling? or is it purely because they need to be big so to be able to inject enough fuel in the short period of inlet valve open.
Thinking about this more I am going to use a DIY flowbench when I get the car and test the head in its current setup, I have other figures of stock 998cc flowbenched to check my setup against. I am then going to with clay and some sheet metal install a full length intake divider and test the flow with full length dividers, if flow loss isnt catastrophic then I will use full length cylinder head intake dividers to remove the problem of
1) charge stealing
2) having to go to rather large injectors, worry about injection angle, and issues of poor idle because of dead time and inaccuracy with low duty cycles on large injectors. - meaning i can inject onto closed valve which will improve atomisation and reduce fuel consumption whilst maintaining power output.
my thoughts are
1) the limitation on power gains with EFI on siamese ports is injector sizing which ends up wiping out idle / low speed driveability and emissions right (so the fix is to go to staged which means more money)
2) I think that sometimes when dividers are done properly they help laminar air flow and increase velocity improving torque, because these cars are not insanely high revving in their natural state the potential loss doesnt strike me as being that great but it has to be tested. its like using a smaller carb throat on a particular engine and I think all the worry is in regards to NA vehicles - mine will be turbo.
3) if the cfm flow loss with dividers was minimal or able to be compensated with careful port modifications then the benefit could be better all round driveability on EFI and removal of the power output ceiling, without having to buy a 7 port head.
because I am turboing I feel the restriction on the inlet side to be less worrisome. the issue will be installing a reliable divider that is not affected by 10-12PSI of boost. I'd probably braze in a 2mm thick divider, and port the outer walls to improve flow. I guess the point is that the choke point is at the valve and not in the inlet tract (although the intake manifold is a restriction), hence why porting the inlet and not around the valves doesnt really do much except for race porting, this combined with a proper flowing manifold i think would potentially work...
