Home > General Chat > Youtube - Mighty Car Mods - Supercharging the Mini
JPA
Member #: 10036
Finland
These Mighty Car Mods videos are quite entertaning.
Here is part one... already waiting for the next part.
https://youtu.be/evBxi9EPhDc
75' Mini special deluxe.
1275 A+ engine with turbo on the way...
Jay#2
Member #: 648
Northern Ireland (ex AUS)
They went all the way to England to see Stuart Gurr, they don't seem to mind traveling.
On 7th Nov, 2008 Nic said:
naeJ
m
Considering Ben does a kit in Aus
scoop-face
Member #: 11122
Scottish Borders.
Looking forward to part 2..
Hopefully they show the tollong road results!
JPA
Member #: 10036
Finland
Seems so that part 2 is out...
https://youtu.be/digPqCURH8U
Jay#2
Member #: 648
Watch the one where they chucked a WRX engine in a beetle. That probably one of their best project cars.
naeJ
m
Does anyone else remove the rad like that?
smokestack-lightning.
Member #: 10557
...nope joys of scamp ownership ...undo top mount swing rad and cover 45 degrees out undo bottom bolt lift assembly out....done...
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
Jay#2
Member #: 648
I laughed at that too, plus all the grumbling over access to things. Is it not a pretty rare car to be modifying? All be it I suppose there is no hacking up involved.
naeJ
m
SadamPl
Member #: 10924
Wroclaw/Poland
I'm sure Moog will take a different aproach removing the rad next time. Episode 3 now out and I'm concerned about few things 0 removing timing cover breather and not fitting a second breather somewhere else, no mention on reducing CR and the engine is probably Cooper version so 10:1 CR? No bung to fit lambda sensor which they'll realize in a second I guess but it was easier to welded it while the manifold was out.
Made in Poland build thread:
http://www.turbominis.co.uk/forums/index.p...tid=570363&fr=0
JPA
Member #: 10036
Finland
Hi there...
Link to Pt 3.
https://youtu.be/Xx2juohU6h4
And also PT 4. is out now...
https://youtu.be/EeNc89t4vyA
BR
Juha
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
most interesting thing for me will be seeing what the E85 will do as im giving it a go aswell
Nick warwick
Member #: 8926
Sheffield
Part 5 is out
https://www.youtube.com/watch?v=aoTsgrwDujY
Anthony30
Member #: 10828
Rainhill, Merseyside.
On 7th Dec, 2015 Nick warwick said:
Part 5 is out
*Clapping*
On 18th Nov, 2014 D4VE said:
went down to my local hydraulics place and he gave me a suitable replacement larger nipple *smiley*
Nick warwick
Member #: 8926
Sheffield
Part 6
https://www.youtube.com/watch?v=3gXgTU0rz2Y
TurboDave16V
Am I the only one who actually tries to watch it, but gives up simply due to the characters in the video?
Member #: 10557
I generally watch them for the cars and the professionals they get to help them....just tune out the two main guys.
The AM auto guys they often get to help them do some interesting stuff as does the Haltech guy they use.
AWDmoke
Member #: 713
Western Australia
Yes.
They are a bit childish, but sometimes so am I.
On 24th Dec, 2008 Nic said:
I think your just a grumpy old fart Dave
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
didnt know there was a cooling passage way inside the charge cooler of the bmw minis
Gomme
Member #: 10528
Denmark
Episode 7
https://www.youtube.com/watch?v=aGQLUJ9YPSY
nosaj
Member #: 10176
I am pretty sure the cooling is built into the manifold not the SC itself.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
like that steel pipe thats in the metro manifold? surely that whont do much?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
part 8 is out 110-120 hp on 8-10 pound stock mpi internals from what i gather
they say 54% increase from the base run
to bad they carry on so much id like to see em do it with out the pros help
Edited by Turbo This.. on 23rd Dec, 2015.
Jay#2
Member #: 648
I could be completely wrong but I think the cooling system connects to the outer case of the charger, it looks like there is something bonded to the case. Seems like pretty good power, they ditched the decompression plate pretty quickly anyway.
naeJ
m
Users viewing this thread: none. (+ 2 Guests)   Next ->
