Home > For Sale > Clear out. Updated, prices dropped.
jonny f
Member #: 9894
Dorking
Clearing out a load of bits I don't need.
DSN door handles like new. Yet to remove the other one. £35
Column bracket £4
Handbrake cable to floor seal £4
Coil bracket to bolt to clutch housing £4
Smithys stainless top engine steady could do with a new bush but works as is £14
Dipped dim resistor £4
unknown engine steady bracket £5
OBP reservoir as new £15
Good alternator, removed due to getting a lightweight one £25
Pre-engaged standard starter motor £30
Not sure what to call these, quick catches for eye bolts on 3 inch harnesses. £4 each.
Mini minus spreader plates for front subframe £7.50
Special tuning style leather bonnet strap £13
Cheap bonnet straps x2 £6 each
OMP adjustable steering wheel spacer, for omp momo etc. £85
http://www.demon-tweeks.co.uk/Product.do?m...CFSXKtAodGCwAOw
Inlet manifold vacuum bolt £3
Floor dipped/main switch, blasted and painted. Continuity check but not tested under load. £13
x3 wilwood remote reservior kits. £20 each.
Kent vernier duplex timing chain. Bottom end was sold as never ran, I presume and by the looks of the chain that chain/gears have never been run on either. £120 £5 to post.
Revotec fan with fitting kit to mount to standard rad on opposite side for additional cooling or total removal of mechanical fan. £80
Sub £10
Universal mud flaps £15
All in Dorking Surrey. Most things i can post for £5.
Edited by jonny f on 21st Nov, 2014.
alaskanow0
Member #: 8466
Mansfield
I'll take the steering column switches, and how much for the adjustable gearbox bracket?
evad1980
Member #: 10165
Stansted, Essex
How much for the rug?
wng691s clubby
Member #: 9252
Cleethorpes
il take t bars if pos posted pm me
Done now needs redoing lol
maccamcvey
Member #: 6673
Worral Sheffield
Hi, I am intrested in the larger battery box, could I have a pic and size please
jonny f
Member #: 9894
Dorking
I'll sort everything out for you when I'm back from holiday on the 10th.
The adjustable steady is made from a Ti bar with two rose joints, I want £20 for it.
philc
Member #: 1346
bromsgrove
hi, interested in the bottom arm £20 incpp
jonny f
Member #: 9894
Dorking
I don't have a bottom arm for sale ?
philc
Member #: 1346
bromsgrove
sorry engine steady
jonny f
Member #: 9894
Dorking
Pictures added
jonny f
Member #: 9894
Dorking
rad added
wng691s clubby
Member #: 9252
Cleethorpes
cheers for the t bars jonny
garethlloyd
Member #: 616
Birmingham
Do you still have the hand brake? If so, i'll take it if you're happy to post?
Many thanks,
Gareth
jonny f
Member #: 9894
Dorking
Many thanks,
Gareth
Yea I do.
Can post for £5 on top
garethlloyd
Member #: 616
Birmingham
Cool,
What's your paypal address and I'll send the money over
Thanks.
garethlloyd
Member #: 616
Birmingham
Pm'd *smiley*
jonny f
Member #: 9894
Dorking
Few bits sold and lots more added.
dev 11
Member #: 9393
stoke on trent
What size inlets on the catch can? I need 19mm lol
adcyork
Member #: 6807
York
I'll take the number plate light please. PM'd
jonny f
Member #: 9894
Dorking
10mm dude.
uk boy
Member #: 10074
new Zealand
Any chance in sending rocker cover to nz lol
Oli
Member #: 1910
Wilts
Pm'd about the mk1 column bits
Nick
Member #: 154
Midlands
I'll take the 7" springs and the front subframe locking plates dude. Fire us a PM with your bank stuff.
jonny f
Member #: 9894
Dorking
Some more added. Few bits sold.
Will except offers.
jonny f
Member #: 9894
Dorking
Updated again.
Users viewing this thread: none. (+ 2 Guests)   Next ->
