Home > A-Series EFI / Injection > Microsquirt V3 usage
Coolmini
Member #: 10920
West of Ireland
Hello all
i am new here to turbo minis and have searched and searched regarding the microsquirt module.
there is only 3 post regarding this with very limited info and most are very old posts too.
Can the microsquirt v3 ecu do sequencial injection with staging.
i have done injection using canems semi sequencial ecu and did actually get to 7500 rpm with even AFRs on NA engine. (Have logs too from that).
i don't see why one couldn't use the microsquirt for sequencial injection on 5 port mini.
could anyone shed some light on it. or point me in the right direction.
Mini => Money Is Not Important
or more like if you get the mini speed virus you'll have none
Basically no.
The Microsquirt as it stands only has two injector chanels so, by definition you can't have both sequential and staged as that requires 4 chanels.
We can do it with an MS2 (which in normal form is also only 2 chanels) because there is a well documented modification to the daughterboard, supported by the MS2-Extra code, to make it 4 chanels and the siamese sequential part of that code allows staged sequential, and we add all the extra hardware to support 4 chanels.
It "may" be that the CPU inside the Microsquirt case has an additional 2 chanels available as it is the same processor and very similar firmware to the MS2 - hopefully Jean will see this thread and answer - but it most definately isn't intended to be that way as the assembled MicroSquirt isn't meant to be DIY to add extra hardware inside the case like the MS2, it is built/sold "complete" to avoid DIY.
See page 42 of the manual http://www.msextra.com/doc/pdf/Microsquirt...e_Guide-3.3.pdf
EDIT - grammer and link added
Edited by Rod S on 7th Aug, 2014.
jbelanger
Member #: 831
Montreal, Canada
You mention the Microsquirt V3 and you also mention the Microsquirt module. I don't know if you're aware of this but these are 2 different products with different purpose and slightly different possibilities.
You should look at the MS documentation to see all the differences: http://www.msextra.com/doc/general/whatmegasquirt.html. But basically, the Microsquirt is a cased unit with no provision for modifications while the Microsquirt module is an ECU module intended to be used on a custom board.
And the Microsquirt has 2 injector outputs and you can't change that. The Microsquirt module has 2 injector drivers on the module and also has 2 outputs that can be used as injector outputs if you add the needed external drivers (on the custom board). I have made such a custom board that uses the module and add many features and fits inside a completely weather and waterproof case.
So to do sequential and staged injection you either use a modified MS2 as Rod mentioned or some other custom board based on the Microsquirt module.
Jean
Edited by jbelanger on 7th Aug, 2014.
http://www.jbperf.com/
Coolmini
Member #: 10920
West of Ireland
thank you all for quick reply,
yes i did mention both the megasquirt cased unit and the module.
As i got confused and seen that the module has a possiblility to drive 4 injection drivers using additional circuits.
does it not mean that one could open the case and do the same mod on the cased unit??
To recap. then
the micorsquirt cased out of the box unit can:
1. run sequential injection on 5 port but no staging?
or
2. run semisequencial with staging?
Thank you again.
jbelanger
Member #: 831
Montreal, Canada
The module is not the same board as the cased version of the Microsquirt; the module has additional pads that give access to more CPU pins and doesn't connect multiple pins to the same output (look at the schematics). The cased version cannot have more than 2 injector channels even if you open the case. You would need to make destructive modifications to the board (i.e. cut traces and/or CPU pins) and solder directly to the CPU pins to achieve this.
But yes, you can run either sequential injection without staging or staged semi-sequential.
Jean
Coolmini
Member #: 10920
West of Ireland
Thank you Jean for clearing that up for me.
you said you have a board + case solution for the microsquirt module?
any pics or a link to were one could see such a marvel.
Sascha
jbelanger
Member #: 831
Montreal, Canada
Here you go: http://forum.jbperf.com/viewtopic.php?f=14...&start=20#p3693
Coolmini
Member #: 10920
West of Ireland
Thank you again Jean,
but i'd say this is a bit costly for what i had in mind.
Eventhough you have made an excellent piece of kit there is it still at the 600 mark?
at what stage of power is staged injection required.
I got to about 96 HP with the semisequencial injection without staging. 630 cc injectors at the time NA
so i wonder on a 5 port turbo were the limit is.
So i could still use the microsquirt on a turbo with say 150 hp.
and full sequential injection.
problem here is at the moment information overload and a lot of rubbish on the internet these days too.
Coolmini
Member #: 10920
West of Ireland
Coolmini
Member #: 10920
West of Ireland
Coolmini
Member #: 10920
West of Ireland
hmm whats going on with the website here?
click once and 3 posts lol
Coolmini
Member #: 10920
West of Ireland
Coolmini
Member #: 10920
West of Ireland
Coolmini
Member #: 10920
West of Ireland
The multiple posts seem common when people post from a phone or other mobile device.
Assuming by sequential you mean the MS2-E siamese sequential code and port injection you have to bear in mind it doesn't work like semi-sequential so the correlation between injector sizes and power output is different.
The principal behind the MS2-E sequential code (it also has a semi-sequential option but let's ignore that for the moment) is to put the required fuel through an open inlet valve, not send it down the port after a valve has shut and wait for it next to open.
To further confuse you there are two ways of doing this, two discrete pulses timed in sequence of valves openning or one long pulse timed at exactly the right moment when the first valve opens such that the right amount goes in both the first and second valve.
What this all means, apart from timing is critical, is that the injector(s) have to be very large to be able to deliver the fuel in the "window" of open valves because the pulse widths will be tiny compared to a normal 8 port engine. In duty cycle terms a conventional engine will run injectors at 80-85%, to hit an open valve you are looking at less than 25%, more like 20% if using the discrete pulse mode because the valve opennings overlap.
A while ago, Paul S and myself wrote a document describing this all in detail (search and you will find it) but to give you an idea of size vs BHP Paul got a dyno'd 115-120BHP on 880cc injection capacity and I think I have about 130BHP from 1000cc injectors (my car still isn't MOT'd yet to see a dyno so testing has been limited).
Paul has moved on to MS3, I haven't built my staged injection manifold yet and Graham hasn't quite finished putting his (staged injection) engine together yet but is using 875cc for both the primary and secondary.
The issue with large injectors is controlling their incredibly short pulse widths at idle, although all three of us have achieved it I would say anything larger than 1000cc (in an attempt to achieve more power without staging) would be pushing your luck. I think my idle is as good as it is is down to my 1000cc injectors being low z with a very fast open time (the others use high z but a bit smaller).
EDIT - typo.
Edited by Rod S on 10th Aug, 2014.
Coolmini
Member #: 10920
West of Ireland
Ok Thank you again,
right then, is there a semi sequential mix with sequential version.
Let me explain what i mean.
1 pulse per revolution, which would hit one open valve and on next rotation 1 closed valve. and so on.
However dependent on which cylinder it is have a fuel trim to account fro different Ve.
i hope i explained that ok.
I think so - I assume what you are thinking of is putting both primaries on the uS injector 1 output and both secondaries on the uS injector 2 output, then running siamese semi-sequential staged ???
Hopefully again, Jean will see this and give a definitive answer, my best answer is "possibly"....
I have never used the siamese semi-sequential mode.
Historically only Paul tried it (but not with staging) and with mixed results. Jean wrote the code, Paul tried it, I came in later and suggested maybe we need a cam sensor (ie, fully sequential) and Jean re-wrote the code to accomodate fully sequential with a siamese version (I think fully sequential for MS2 had always been intended, the siamese version was just the icing on the cake). That was developed into what we have now with all the individual pulse/merged pulse, timing tables, etc, everything that makes it work.
The reason I say "possibly" is I've just setup a temporary project in TunerStudio on my spare MS2 in siamese semi-sequential mode and I can set staged injection, it works as expected, I still have two VE tables so presumably that will be the open valve vs closed valve difference but I only get one injector timing table (presumably open valve) so reasonably expected and the second pulse is at a fixed value. Now that probably isn't an issue as that would be the closed valve but I can't alter the fixed value and it isn't working right for my test, the grey'd out values in the setup menu don't agree with what TS shows when running. It maybe something I've done wrong, it may be a bug - bear in mind the siamese semi-sequental was never persued once Jean had added the fully sequential code - or it just may not be an issue as the value I'm getting would probably still work even though it doesn't match what the menu says.
Hopefully Jean will clarify.
On the point you made earlier about the cost of Jean's uS module based system compared to a plain cased uS V3, one thing I would point out is, if you go any way down the siamese sequential route, you will need additional I/O to see what the hell is going on to be able to set it up and tune it.
Trust me on that, an MS2 or uS alone is not enough.
Those of us following this route use Jean's IOx or IOx-OEM.
Those are DIY (very DIY in the case of the IOx-OEM I use).
Unless you already have something in mind particularly for data collection, or are very DIY yourself (if so you should be looking at the MS2, not the uS) Jean's package gives you pretty much everything you need rather than having to add things to the uS later.
And, as I already said, Paul didn't have too much success with semi-sequential on a turbo engine, Jean's version would give you fully sequential.
EDIT - typos
Edited by Rod S on 11th Aug, 2014.
jbelanger
Member #: 831
Montreal, Canada
The semi-sequential code is done such that it doesn't use the cam signal whether or not it is there. Since that also means the MS doesn't know which injector channel correspond to the open and closed valve, there is no trim for open and closed valve but only for channel 1 and 2 (I think, it's been a loooong time and haven't gone back to check).
The only way to trim the fuel per cylinder is full sequential and if you need staging, you also need 4 injector channels. Which would eliminate the cased Microsquirt.
I also would like to add that one of the issue with pricing is that B&G price their cased Microsquirt very aggressively but the module is almost the same price without a case and connector. And look at DIYAutotune Microsquirt module-based ECUs (who have the volume to get the lowest possible prices) and you'll be able to better compare with mine.
Jean
Coolmini
Member #: 10920
West of Ireland
Hi Jean,
i think you have made a fabulous piece of kit there. And i do understand that there are by far more features using your system. Is it still about 600$?
the only problem i see with using semi sequencial using the ms code is that there isn't enough resolution in the table for the injection timing.
When i tuned my setup with canems they had a table of 14(Load) * 18 (Speed).
And i did require that to compensate for pulse reversion / air speed change vs load and speed.
i will try and post a pic of both the injection timing and a log with AFR's
as i do think it is possible with semi sequential.
Coolmini
Member #: 10920
West of Ireland
There's a build thread over at irishminis from my mini.
http://www.irishminis.ie/forum/viewtopic.php?f=6&t=9044
I don't disagree that semi-sequential can work in principle but the basic history with the MS2/uS is it was tried by Paul with little success and then Jean added the cam signal for us so we didn't persue it any more.
The point is, for the short time it was tried, it was never tried in staged mode.
I had a quick look this afternoon and thought it might be possible but after Jean reminding me how the trim works (and it has been a looong time) I also have my doubts.
Presumably Canems (I only know the principal behind it, never used it) also only has two chanel drivers hence why you can't use it in a staged format (if you could, presumably you wouldn't be here *oh well* )
I'll put the scope on my spare setup tommorow and see how it responds to staged but I now think the trim is, as Jean says, going to be between the staged output and the primary output, not the cylinders.
EDIT - I don't think table resolution for the injection timing is relevant between the two ECUs, well not in fully sequential mode anyway, MS2/uS interpolate between the cells and the velocity of fuel/air down the runners is a fairly straightforward relationship to speed (RPM) and density (load) especially on a turbo engine.
If you have a uS or an MS2 set it up on a JimStim and try the permutations. That's all I've done to look at your question. I just don't have my scope connected at the moment.
jbelanger
Member #: 831
Montreal, Canada
If by semi-sequential you mean that you inject once per rev and that you don't have a cam signal then you can't compensate for the different VE between the inner and outer cylinders because you don't know which channel is injecting for the inner and which for the outer.
If you mean that you have a cam signal but still inject once per rev then you could in theory inject a different pulse width per channel according on whether it's for the inner or the outer.
Staging will have no effect on this.
And if you have a cam signal, you would be able to duplicate this pseudo-semi-sequential (2nd one above) with the full sequential siamese code by using 2 timing values and adding 180 degrees to the second one. That would likely not be the most efficient timing but it could be done. But it would still not really be semi-sequential because you'd be using phase information.
And yes that is still $600 but since I moved recently, I would need to check some of my unpacked boxes to make sure that I still have one available (actually all the components to assemble one because they are assembled on a per order basis).
Coolmini
Member #: 10920
West of Ireland
Here's the pic of canems.
The Throttle didn't open more than 80% as it was shown on the dyno that a reduction in power was the case. jenvey 45 dcoe throttles which where way too big for this project. anyways it goes to show that it does work however it took a lot of time to get it to that tune. This is a setup without a cam sensor.
Jean, regarding my question earlier i was curious about injection with cam sensor in seami style mode. this would mean that one could still use smaller injectors ?
or am i just going in circles here.
jbelanger
Member #: 831
Montreal, Canada
The injector size and pulse width will remain about the same whether you are running semi-sequential or sequential. In both cases, each channel will fire twice per cycle. In the case of semi-sequential, each injector will fire once per rev without knowing which cylinder is being fueled while in sequential, each injector is being fired twice but with the timing and fueling set for the cylinder being fueled.
There is another sequential mode where each injector is fired only once per cycle during the intake overlap period. In this case the injector channels are fired 360 degrees apart. And the pulse width will basically be doubled so again you don't have an impact on injector size. There is a small impact on duty cycle due to having one less open-close cycle.
The only thing that has a significant impact on the needed injector size is the number of injectors used. Other than that, you are limited by the open valve injection window of the outer cylinders.
Jean
Coolmini
Member #: 10920
West of Ireland
All Angles covered there then.
is there any way of getting more resolution in the injection angle table in ms.
as i found that even 2 degrees out at wot has a huge impact on the balance. maybe the injectors that i was using were just on the limit.
Am glad i joined this site as i was kind of on my own in Ireland doing this publicly.
have gotten more info here in the few post then in searching the web over the past years. i must be searching for the wrong contents or google ireland is just not displaying the things i want.
