Home > Show Us Yours! > 95' Sprite T3 to GT17 project...
1293 sprite
Member #: 5449
Melton Mowbray
Hi
Thought I'd start a proper project thread now things are well on their way :).
So I've had a gt17 sat in my garage for about 4 years, along with a matty manifold, and a couple of other bits and bobs... I realised at the time it was a lot of work, so decided to go T3 for a while, then to upgrade to the 17 at a later date.
I sourced all the bits, built the engine with cast omegas, straight cut drops, x pin diff, turbo phil head, med T3 cam, vernier etc, and a standard T3 + intercooler. Had it on the road for a few months, covered around 1k miles, then had a nasty engine failure, so decided to do it again properly and go down the gt route.
So I sent the head to turbo phil for some repair work, which he did a fantastic job of, thanks phil :).
Decided to get the gearbox rebuilt with a straight cut gearset as this was my previous worry before. So a trip to the Benross HQ left me with a few options, in which I decided to have steve fully rebuild the gearbox, and build a descent spec 1293 short engine capable of pushing some nice power :).
Only a couple of weeks later I was collecting the built engine and gearbox, which looks fantastic, thanks Steve!
Things really started coming together then. Matty did a great job of the downpipe, which also arrived in super quick time, thanks Matt!
In the meantime I started mocking up the turbo and manifolds etc, sorting coolant feeds etc etc.
It's now sat in the garage with the head slotted on while I sort a few issues with the oil drain and coolant pipes etc.
Anyway enough talking, here are a few pics of the last few weeks...
Uprated the fuel pump and rewired it.
Repainted the head to match the block. Thanks for the paint steve!
Bought and fitted an aem wideband kit and new boost gauge. Liked the boost gauge so much I decided to rip out the other gauges and buy all new matching :)
New matching gauges. Peak recall feature and programmable warnings etc.
Mocking up etc...
Heat shield made up
Just waiting for the engine pics to upload to photobucket :)
Edited by 1293 sprite on 8th Jun, 2014.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
1293 sprite
Member #: 5449
Melton Mowbray
The clutch is currently with Sprocket being RTS'd :)
Will upload some pics of inside the engine when I get them off the disc onto my phone :)
The car looking sorry for itself
17.3 1/4 @ 78 mph
That's looking great! It doesn't look like you have much left to do now?
It's been a while since I've seen on of the high flow manifolds!
1293 sprite
Member #: 5449
Melton Mowbray
Thanks :). Not much at all. Waiting for a few bits to arrive (speedo drive, throttle cable, clutch, couple of gaskets etc), and got to sort the oil drain which I'm struggling with a bit.
Did you have any clearance issues with the high flow manifolds? The turbo is fouling on the block above the fuel pump blank. Can't clock the housing as much as I want due to it touching the block. May need to grind the block and turbo a bit. Manifold is great though, love it!
17.3 1/4 @ 78 mph
sim_ou_nao
Member #: 114
Porto/Portugal
it this right?
Pedro Silva
1293 sprite
Member #: 5449
Melton Mowbray
No just popped it on there to keep it out of the way, but thanks for noticing :)
17.3 1/4 @ 78 mph
Shauna
Member #: 10424
Swansea boyo!
I WISH MY ENGINE WAS SO SHINEEEEYYYYY! Looks good!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I like those gauges, is that the type that light up red if things go out of range?
On 7th Nov, 2008 Nic said:
naeJ
m
rattydriver
Member #: 10808
leicester
about time you put a new thread up.... looking good bud.... not long till we'll be dumping together
madonminis
Member #: 9371
East Yorkshire
Looking good
1293 sprite
Member #: 5449
Melton Mowbray
How long it stays shiny for is a different matter haha.
Yes flash red and beep at you haha.
Yes carl, can't wait! They'll love us at the club meet haha. Wonder if we'll be allowed to attend :p
17.3 1/4 @ 78 mph
They stay clean for a couple of weeks if they actually get used haha. Nice to look at for a while though!
1293 sprite
Member #: 5449
Melton Mowbray
Yes definitely, I'll have to get plenty of pics when it first goes in!
17.3 1/4 @ 78 mph
sealy1991
Member #: 5814
Kidderminster
Nice mate looks good!
More Boost, More FUN!
1293 sprite
Member #: 5449
Melton Mowbray
Thanks sealy :)
17.3 1/4 @ 78 mph
tadge44
Member #: 2500
Buckinghamshire
Lovely tidy job, but is that water feed and return for the turbo going to work, do you think ?
It looks as if the feed is coming off the back of the head which is probably a pretty hot area - and I suspect the flow will not be great.
BronkoMini
Member #: 10610
Wow this is one nice build, I like the way you've hidden the inter cooler infront of the grill
I wouldn't call it hidden haha
rattydriver
Member #: 10808
leicester
Those intercooler brackets look the dogs.... what genius made them ?!!!!!
Looks good, other than the horrid intercooler position. Is there no way of getting it under the bonnet?
rattydriver
Member #: 10808
leicester
Think the cooler looks like it means business there..... may be two on the road like it...😜
1293 sprite
Member #: 5449
Melton Mowbray
Horrid position? It's my mini and that's how I like it, hence why it's there. I don't want it under the bonnet.
17.3 1/4 @ 78 mph
1293 sprite
Member #: 5449
Melton Mowbray
Tadge, as for the cooling, I know others have plumbed them in this way, so I'm going to give it a go :)
17.3 1/4 @ 78 mph
Tupers
Member #: 9441
South Devon
What pistons are you running?
1293 sprite
Member #: 5449
Melton Mowbray
Omega +020 10cc cast :)
17.3 1/4 @ 78 mph
Users viewing this thread: none. (+ 2 Guests)   Next ->
