Home > Technical Chat > Lets talk Brakes!
Chalkie
Member #: 9764
Northamptonshire.
Right been looking around at buying brakes for my Mini, Loads and loads to choose from and different prices! want to try break down what is good and what is bad!
I've personal been looking at Mini sports Alloy calipers,
http://www.minisport.com/mini-sport-7-5-st...y-calipers.html
And Mini spares Alloy Calipers
http://minispares.com/product/Classic/Brak...ack%20to%20shop
IMO the Mini sport ones look the part, come in alot of different colors and are CHEAPER But are they an better?
Thanks
Stephen
mini spares come in many different colours as well. general info on tm says mini spares are better.
I would generally go for a minispares product; however I do have an early set of the minisport callipers on the turbo and haven't had any issues yet
Im on mini sport 7.9 vented 4pots no issues with the brakes
The mini spares calipers are better as they have a pair of bleed nipples per caliper.
Chalkie
Member #: 9764
Northamptonshire.
Seen minispares have two bleed nipples are they better other than that?
sim_ou_nao
Member #: 114
Porto/Portugal
for a little more you can buy Tarox B20-4 FTL
Edited by sim_ou_nao on 16th Dec, 2013.
Pedro Silva
wolfie29177
Member #: 476
The Black Countraaaaay
brakes r overrated
Masturbation is not a crime its a hobby
WRLondon
Member #: 8636
Surrey
Drums seem to be doing my mini fine......
On 16th Dec, 2013 wolfie29177 said:
brakes r overrated
Reading up on RTS Clutches
lee.pb
Member #: 9199
Lancashire
I second bretts comment, have a set of 7.9 vented on mini with no issues.
7.9 vented only clear certain 10's though.
To date they clear:
Wellers (bretts)
Revolutions
JBW Mamba's (mine)
Mini 1100 specials (mine)
Do we know what will fit inside 10" rose-petals?
To date they clear:
Wellers (bretts)
Revolutions
JBW Mamba's (mine)
actually this is a good point, i want a set of carls at some point must find out if they fit
welshdan
Member #: 1111
s wales
they will not fit under your wheels, but I use rebuilt metty vented four pots. they work very well, as long as the caliper is in good order any brake will be ok
the real difference I have found is the pads. use mintex1144. avoid greenstuff at all costs
dan
Shauna
Member #: 10424
Swansea boyo!
I think I have these and they are very screechy, leave a lot of brake dust too :(! The pads that came with my disks from minispares weren't as good as the mintex ones so they do make a difference. I almost give myself whiplash if I've been driving the mini for a few days then get into my work van haha.
dan
Edited by Shauna on 16th Dec, 2013.
welshdan
Member #: 1111
s wales
they have a very slight squeal, but are by far the best pads I have tried. not stupidly expensive either
The thing I find with the mintex pads is they stop better without locking up the wheels, and will continue to work well under spirited driving. Blackstuff pads tend to not do much then lock up, not giving much modulation, and then greenstuff don't really do anything.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
been using the mini sport vented 8.4 drive hub setup with no trouble had quite a lot of hard use
Shauna
Member #: 10424
Swansea boyo!
Except for that time at mitp when I tried stopping for the birds *tongue*
Chalkie
Member #: 9764
Northamptonshire.
I would like to know if 7.9's fit under rose petals as well, Rather have a bit more surface to brake on. I want to keep 10's
Then am I being a bit stupid in thinking that 7.9 have more surface area?
Amp
Member #: 7856
I have the Minisport 7.5" 4 pots, the only issue I have had is the bleed nipple shearing off in both of the calipers which is supposedly not uncommon, but the larger insert is removable and available from Minisport.
They also fouled on my adjustable tie bars, but there were "tickled" with a grinder to suit.
*Having said the above, I am happy with them!*
Edited by Amp on 16th Dec, 2013.
Tupers
Member #: 9441
South Devon
The Mini Sport 7.9" 4 pots I had just touched the weights on the inside of my Eleco Falcons. I don't have the brakes anymore but I can measure the internal diameter to see how they'd compare you your Rosepetals is you like?
I'll see if i can borrow a rosepetal off a good friend and try it on mine if it helps
Chalkie
Member #: 9764
Northamptonshire.
I haven't brought my rose petals yet but be great as buying them soon and knowing what i can fit under means brakes be off the list
Going smaller with brake discs keeping with the fashion to use a smaller wheel limits the performance of the brakes considerably. My first advice would be to use the Mintex 1144 or comparable pads and vented discs if you really really want to have 10" wheels. I would otherwise recommend at the very least keeping with the 8.4" disc, better still increase its diameter..
Keeping the required brake torque, master cylinder, pedal ratio, and caliper piston area the same for a fair comparison, the effect of upgrading to the Mintex 1144 pad from a standard pad, and also increasing disc diameter, the difference in hydraulic pressure and required pedal effort can easily be seen.
Running a few numbers..........
Hydraulic Pressure
Brake Torque / Coefficient * Piston Area * Effective Radius
Disc, Coefficient, Pressure
7.5", ( 0.32n) 1005psi, ( 0.45n) 714psi.
7.9", ( 0.32n) 941psi, ( 0.45n) 669psi.
8.4", ( 0.32n) 924psi, ( 0.45n) 657psi.
10.25", ( 0.45n) 480psi.
Pedal Force
Master Cylinder Force / Pedal Ratio
7.5", ( 0.32n) 97 lb ( 44.0 kg), ( 0.45n) 69 lb ( 31.3 kg).
7.9", ( 0.32n) 91 lb ( 41.3 kg), ( 0.45n) 65 lb ( 29.5 kg).
8.4", ( 0.32n) 89 lb ( 40.4 kg), ( 0.45n) 63 lb ( 28.6 kg).
10.25", ( 0.45n) 46 lb ( 20.9 kg).
As can be seen here, using a 10.25" disc with the 1144 pad material halves the pedal effort compared to a 7.9" disc and standard pad material.
Ok so its not just the pedal effort you need to consider, but also how the combination of parts handle the heat they generate. The smaller the disk, the greater the applied force required for the same braking torque results in more heat. You may reach the temperature limits of the setup as a whole, this being the limiting factor.
Also, four pot calipers do nothing to increase the brake efficiency, they simply handle the heat better and decrease the wear rate.
Food for thought
Edited by Sprocket on 16th Dec, 2013.
I guess it might also depend who's make of rose petals that you buy?
Users viewing this thread: none. (+ 2 Guests)   Next ->
