Page: |
Home > Technical Chat > RTS clutch | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
8th Dec, 2013 at 04:02:12pm
Looking at fitting an RTS clutch in the turbo mini, already done the relevant search and found the build trend and even connected sporcket.
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
8th Dec, 2013 at 04:09:00pm
Ap have a circular metal ring which the bolts go through to hold the spring in place.
In the 13's at last!.. Just |
8th Dec, 2013 at 04:32:08pm
Looks like i may have 2 AP's
8th Dec, 2013 at 04:51:51pm
AP clutch removed from mini:
882 Posts Member #: 9774 Post Whore Buckinghamshire |
8th Dec, 2013 at 05:01:17pm
I'm looking at putting one of these together as well, where are you planning to get the spacers, bolts and washers from? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
489 Posts Member #: 9159 Senior Member Devon |
8th Dec, 2013 at 05:07:25pm
This is on my to-do list too! |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
8th Dec, 2013 at 05:50:15pm
there the dadys!! 2 APs right there lee Yes i moved to the darkside
8th Dec, 2013 at 08:37:20pm
coolio thank god i dont need a reality check
On 8th Dec, 2013 Brett said:
there the dadys!! 2 APs right there lee What the mind can conceive the mini can achieve
9th Dec, 2013 at 10:23:51am
The blue spot on the 1st pictures indicates that that may be a high-torque version that usually sells for over £100.
Edited by Paul S on 9th Dec, 2013. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Dec, 2013 at 11:28:29am
WOW, i'll have to check the thickness of the fingers.
On 9th Dec, 2013 Paul S said:
The blue spot on the 1st pictures indicates that that may be a high-torque version that usually sells for over £100. http://www.minispares.com/product/Classic/...ack%20to%20shop You can't go on the spot alone though. If the fingers measure around 2.8mm thick, then it is. You may wish to sell that and find another 998 clutch. What the mind can conceive the mini can achieve
9th Dec, 2013 at 11:45:26am
MED £125
9th Dec, 2013 at 03:04:56pm
2 998 springs got the turbo skip into the 13s
308 Posts Member #: 10369 Senior Member Pickering, North Yorkshire |
9th Dec, 2013 at 03:11:09pm
Can you fit two mismatched springs? I.e a 1275 and a 998? www.apsbikes.co.uk
9th Dec, 2013 at 03:15:24pm
On 9th Dec, 2013 APS said:
Can you fit two mismatched springs? I.e a 1275 and a 998? yes aslong as there both AP clutch springs, ( or valeo with valeo) mine was a turbo and a 1275 iirc Edited by Brett on 9th Dec, 2013. Yes i moved to the darkside
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
9th Dec, 2013 at 03:19:40pm
My next one will be 2 x turbo springs. hope its man enough! lol If something is worth doing, it's worth doing half of. |
9th Dec, 2013 at 03:25:56pm
Can you fit two mismatched springs? I.e a 1275 and a 998? yes aslong as there both AP clutch springs, ( or valeo with valeo) mine was a turbo and a 1275 iirc I'm presuming Brett, the choice of springs determines the force needed on the clutch pedal? So 2 1275 springs will bind stronger, but require more pedal force than a 1275 and a 998 spring etc etc....? www.apsbikes.co.uk
9th Dec, 2013 at 03:48:38pm
Yes,
9th Dec, 2013 at 03:59:48pm
That would be awesome, thanks Joe.
www.apsbikes.co.uk
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
9th Dec, 2013 at 04:20:18pm
I keep getting tempted to rts my own build, but i already have an ultralight pre verto flywheel i bought off here a while back. Decisions decisions! :/ On 26th Jan, 2012 Tom Fenton said:
9th Dec, 2013 at 04:21:34pm
no worries, just need to source another pressure plate now.
That would be awesome, thanks Joe. Sorry to have tapped your thread Lee! Edited by lee.pb on 9th Dec, 2013. What the mind can conceive the mini can achieve
6729 Posts Member #: 618 Post Whore Glasgow |
9th Dec, 2013 at 04:22:50pm
Carl, I had the same thing; now got a brand new ultra-light flywheel and back plate sitting on the shelf going nowhere! |
9th Dec, 2013 at 07:28:16pm
try this attachment,
9th Dec, 2013 at 07:36:50pm
I suppose I could fit it to Shauna's 998T when she does it! As it's already preverto, now there's a thought. Edited by Carlzilla on 9th Dec, 2013. On 26th Jan, 2012 Tom Fenton said:
9th Dec, 2013 at 11:59:53pm
On 9th Dec, 2013 Joe C said:
try this attachment, failing that PM me your email address and I'll send it over. No attachment Joe? I'll pm you anyway. www.apsbikes.co.uk
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
10th Dec, 2013 at 08:44:52am
2 998 springs got the turbo skip into the 13s And thats now sat in my engine going no where lol |
Page: |
