Home > For Sale > another selling up post! pistons reduced again
charlieb150
Member #: 9931
brighton
hi all selling all bits from my engines after gear box issue and thought to my self i use the car daily and figured turbo a series cant hack the everyday abuse and 250 miles a week at least / also cant afford the fuel :( so first off
2)a+ 1293 11 stud block worn oval still able to go +40 also has centre main machined but missing top strap-£120 posted ono
3)998 flywheel housing + wok but no arm breather included i have drilled out the blanked breather-£50 plus postage ono
4)metro turbo flywheel housing big bearing type-£45 posted ono
6)std metro cam £20 posted provisionally sold
8)mini spares 1.5 roller tip rockers £80 posted need new bushes ideally provissinaly sold
10)1275 cam6232 crankshaft x2 one is std needs regrind other is .10 and needs a regrind £100 each posted
11)set of damaged turbo pistons and good conrods -£40 posted
13)mini speed duplex timing gear and chain kit £20 posted
photos to come ,,,,,,,,,,,,,,,,,,oval one,,,,,
Edited by charlieb150 on 16th Sep, 2013.
Is no1 a short eng? If so i could be interested mate.
minispeed turbo cam £20 posted
If this is in useable condition I'll take it please.
charlieb150
Member #: 9931
brighton
mad mk1 nope its not just block and main caps not 100 % on prices so yeah. phil yeah its usable its done maybe 600miles
PM me about payment mate.
charlieb150
Member #: 9931
brighton
pmd
Do you have pics of the damaged turbo pistons?
charlieb150
Member #: 9931
brighton
yeah its the photo above the crankshafts thanks charlie
WRLondon
Member #: 8636
Surrey
rockers
pm'd
Reading up on RTS Clutches
They don't look like turbo pistons to me.
charlieb150
Member #: 9931
brighton
Oh really the what came in my metro turbo engine plus have the fatter oil control ring
What's the part number under the crown?
If you pop out an oil control ring, I reckon you'll find a massive slot.
charlieb150
Member #: 9931
brighton
ill have a look tonight
baker_boy
Member #: 9226
Rushden
as regards the T3 is it useable? as youve mentioned slight play, as the one i bought said 'slight play' and when i got it it was f****d ha.
i got nothing but time..
hazpalmer
Member #: 9038
Carlisle, Cumbria
is that the na mg metro cam?
charlieb150
Member #: 9931
brighton
Turbo I rebuilt it 3500miles ago but im only selling due to gear,box going so has been working fine ive,been running 10ish psi boost I can put a video up of how much there is, haz its a turbo one sorry thanks charlie
CraigB
Member #: 10262
Stourbridge
I'll have the metro cam if it's still available please
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Are all the pistons buggared?
charlieb150
Member #: 9931
brighton
hi what ones
hazpalmer
Member #: 9038
Carlisle, Cumbria
Is the 998 flywheel housing include the wok+timing cover?
charlieb150
Member #: 9931
brighton
Haz I will pm you
charlieb150
Member #: 9931
brighton
Haz I will pm you
eaton_mini
Member #: 1649
11) damaged pistons. Are they all buggared or just 2 or 3? Std bore size?
charlieb150
Member #: 9931
brighton
All fairly fecked
Users viewing this thread: none. (+ 2 Guests)   Next ->
