Home > For Sale > Complete Group 'A' Turbo Engine and SCCR gearbox - Sold
Graham Marlow
Member #: 7262
West Midlands
MED 1293 cc Group “A” Forced Induction Special short engine
• Crank ground, ni-tempered, x/drilled, wedged etc.
• Ultralight Flywheel, Paddle Clutch/Grey Plate
• MED T5 Turbo cam and duplex chain with vernier timing
• lightened and polished con rods with ARP bolts
• 4 bolt centre strap
• OMEGA FIS Forged Pistons 18cc dish (for low compression)
• MED ‘S” Dampers c.w. engine management pickup
• Etc.
Ported, “11 bolt” Metro turbo head
4 speed Straight cut, close ratio JKnight Gearbox, 4-pin diff & 3.1 CWP
JKnight Straight cut drops
Silicon hoses throughout, including SfS Performance 63mm Intercooler hoses and murray clips
New radiator and 16row oil cooler c.w. braided oil cooler hoses
Red Dump Valve
Mega jolt c.w. EDIS & coil pack etc.
Stainless Plenum
Turbo-minis T3 Enlarged and flowed exhaust elbow and exhaust manifold
New High Pressure Turbo fuel pump
Large aluminium Intercooler
Overhauled HIF 44 turbo carb
Also included are various standard Metro Turbo components such as plenum, turbo exhaust elbow, exhaust manifold, dizzy and a complete gearbox
Engine was built in 2010, has covered less than 4500 miles and not seen more than 0.8 bar boost.
Engine can be tested in car, currently in a 1988 MG Metro Turbo, taxed and MOT until Nov 13.
I have receipts for over £4600. I am not willing to break. Engine can be driven home in the Metro!
Looking for £2,400 o.n.o.
Edited by Graham Marlow on 7th Sep, 2013.
Banging price, good luck with the sale
One note its 11 stud not 12 *wink* head
Graham Marlow
Member #: 7262
West Midlands
Thanks Paul, so it is
Graham Marlow
Member #: 7262
West Midlands
Price reduced to £2,600 o.n.o. More photos available
You say it can be driven home in the metro. Does this mean you are selling a metro turbo with this motor for £2600? If so you may get takers on the MOC.
WRLondon
Member #: 8636
Surrey
Cant seem to find the specs on MED T5 cam
Ive got the T3 cam
so im guessing its a similar to the profile of the Avonbar phase 3 cam?
Reading up on RTS Clutches
Graham Marlow
Member #: 7262
West Midlands
WRLondon - the T5 cam is listed as "the ultimate turbo cam with 300 degrees of exhaust duration and .400” lift" on the MED website.
John - I am planning on advertising on the MOC website too, but I think the engine/gearbox/ancillaries maybe of specific interest to TM users
Edited by Graham Marlow on 3rd Jun, 2013.
custodia
Member #: 9675
coventry
hi Graham
Do you know if the chambers have been enlarged in the head and what compression ratio the car is running? i'm assuming from the exhaust and downpipe that its running a t3, is that a standard item?
very interested in this.
Tim
stancemods
Member #: 10019
Manchester
Block is prepped for a Group A head gasket - can you still buy these anywhere?
Graham Marlow
Member #: 7262
West Midlands
Hi Tim, the standard turbo head doesn't have enlarged chambers, only the ports have been enlarged. Unfortunately I never got round to working out the compression ratio, but it will be lower than standard because of the pistons.
Yes its running the standard turbo.
PM me if you want some more photos
Graham Marlow
Member #: 7262
West Midlands
Hi Stancemods, I think MED still stock these gaskets.
Graham Marlow
Member #: 7262
West Midlands
I will also be including various standard MG Metro Turbo components such as plenum, turbo exhaust elbow, exhaust manifold, dizzy and a complete gearbox
No, they are NLA I'm afraid. Phill took months to find one and eventually got one from Portugal iirc. and that was a jammy find from a post on here.
Graham Marlow
Member #: 7262
West Midlands
Still available
Do you have any more pics of the metro? It's about time I had another....
if that pic is of the engine at tdc, it looks like the Group A cutt outs could be removed with a hefty skim
That is what I was thinking too Brett. Would require some correction of the rocker geometry though.
If I remember right the cutouts are about 0.040" deep into the block, so would need a decent skim.
Graham Marlow
Member #: 7262
West Midlands
*smiley* Bump
TurboDave16V
The cut-outs would be easily fixed with a single sheet of 1mm stainless laser/water jet cut to the shape of the combined recesses (kinda like the outside of the audi emblem).
Certainly no reason to not purchase this great spec powertrain!
I've been tempted before to cut a recess just like that into a block and wire ring the head with a dry deck and have a copper fire ring water jet cut. who really needs a full face gasket when you dry deck anyway? Formula one engines don't even use a fire ring, just the wire ring!
Graham Marlow
Member #: 7262
West Midlands
Price reduced to £2,500
Edited by Graham Marlow on 21st Jun, 2013.
reminds me of the vw air cooled engines
Graham Marlow
Member #: 7262
West Midlands
New pics uploaded :)
Graham Marlow
Member #: 7262
West Midlands
MG Metro and powertrain still available
