Home > For Sale > SumpNut's Breaking Thread (final price drop before ebay)
SumpNut
Member #: 28
All prices are open to negotiation, if you think I am asking too much feel free to make an offer, but don’t get the ass if I tell you where to go, remember I do not need to sell this stuff nor am I in any sort of rush for money.
Also don’t tell me you will pay cash like it’s a big incentive – I do not accept magic beans, so yes you’ll be paying cash!!
I will upload some photographs when I get home tonight and others next weekend as I a split apart the block/gearbox etc.
Anyway from the top:
MED Gold 1.5 ratio roller rockers - £125
Shortblock - Rebored to +20 about 3000 miles ago and comprises of 15cc forged omega pistons on
MED lightened, balanced and shot peened con rods and a CAM6581 (gen metro turbo??) crank still on standard grind. There is also a strap fitted to the center bearing. One piston has two tiny valve marks in, there is also slight scratching on the skirts and a little bit of pitting on the ringland, none of this is anything to be concerned about, I'm only mentioning it out of total honesty - £600
T25 turbocharger removed from a s13 200sx. Same exhaust fitment as the smaller R5 t2, but with a larger compressor and larger exhaust housing A/R ratio. The turbo has been rebuilt by turbo dynamics and if memory serves correctly the rebuild included a 360thrust bearing. I'll also chuck in a small tig welded oil return pipe and compressor outlet pipe I had made - £125
T25 Braided oil feed with aluminium t-piece and a banjo bolt - £15
Plenum chamber with dump valve attachment, missing the rubber blocking plug, also comes with an optional alloy intercooler adaptor - £35
Fuel pressure regulator, good working order - £25
Nearly new fuel pump supplied by Avonbar, has only ever sucked filtered fuel from my swirl pot, looks, sold as an FSE pump but looks to be made by Walbro in the USA - £75
Tom Fenton Machined pully to match bracket - £35
Pre-verto starter motor – bought as brand new old stock from MITP a few years back £25
Rebuilt 3.44 differential, has new planet gears, new copper and fiber shims and a minispares heavy duty pin - £50
Tran-X SC Drop Gears (A+), 1:1 ratio - £125
TurboDave Ally Front Plate, never used, includes countersunk bolts - £10
Edited by SumpNut on 8th Oct, 2013.
Mike-998
Member #: 9774
Buckinghamshire
Hi, do you have the connector plug for the alternator? I'm also after the vernier timing chain.
smit360
Member #: 9845
Staffordshire
Pm'd
998 t2 ongoing project.
Can i have the
Lightweight/small jap alternator ??
I'll take the ARP head studs if the price inc postage ? :)
SumpNut
Member #: 28
MadMk1 - it's yours, are you collecting
Phil - deal on the arp's inc postage as I like your sister...
SumpNut
Member #: 28
Mike there are no plugs, i simply used two spades and a ring terminal
Billus89
Member #: 8931
Pm'ed about trigger wheel and bracket
Pinhead
Member #: 4411
brighton, east sussex
please put me down for first on mirage manifold, already pm'd you :)
Well is anyone going past you that I could meet in show land??? As I am in no rush..
tempa
Member #: 10376
hereford
Im going to collect something from sumpnut, not sure what shows we will both be at though?
happy to pick it up for you though
Second.
I'll have the inlet manifold please SumpNut. PM on the way.
SumpNut
Member #: 28
Right, I think I have replied to most of peoples PM's with the exception of all of the mirage ones.
These have generated much more interest than I thought they would, I think based on the offers I have recieved I'd like to ask for £400.
SumpNut
Member #: 28
Also I think I have overpriced the turbocharger.
£200 seems a fairer price for that.
smit360
Member #: 9845
Staffordshire
Pmd
Pinhead
Member #: 4411
ouch, i was thinking what they were priced new, you can move on to second in line, i'll make my own, thanks
Tomm
Member #: 1432
Kent
Am tempted by the carb, fuel regulator, oil feed if they are still available?
SumpNut
Member #: 28
I've had two people message me about the carb so it is provisionally sold unless either of these guys don't pay.
But the regulator and oil feed are still available.
Cash has been sent, My pm has stopped working again!
Carb, reg, pump, pulley / bracket alternator fo you still have all of these parts?
SumpNut
Member #: 28
Sorry my reply is vey late,
I have edited my first post and everything listed above is still available.
baker_boy
Member #: 9226
Rushden
Can do anything on the price for the sensor bracket?
i got nothing but time..
SumpNut
Member #: 28
Updated thread:
madonminis
Member #: 9371
East Yorkshire
I'll take the cam
