Home > Show Us Yours! > K1100 turbo track car build
adcyork
Member #: 6807
York
Well, where to start, bit of history:
I've owned this car for the past 7 years, since I was 16 and it's been through two rebuilds in that time. It was the typical 56K mile 90's mini with a very tired gearbox that had been tarted up and left to rust underneath.
The first rebuild was a reasonably short affair with the bogo 998 stg1. Didn't delve too deeply into the bodywork and such but it was a reasonably solid car.
The second saw major bodywork to replace the multitude of sins that I hadn't uncovered in the first build and this resulted in no less than me replacing the full scuttle, wings, front panel, complete inner wings, full front floor pans, A panels, door skins, you name it. Painted in surf blue with a fresh build 1330 engine plonked in. All carried out under an ebay special wedding marquee in winter in the back garden!
Now it's time for build 3!
The intended engine/'box spec will be:
NA 1380
K1200rs head
Full works on the crank, wedged, bladed, etc
Worked rods
SC ex manifold - Can anyone suggest alternatives?
bmw throttle bodies
Swifty ATB
minispares sccr gearset
straight cut drops
The build started around November and first things first was to stick a beam up in the garage and get a block and tackle rigged up to get the engine out.
Since then I've been busy with numerous parts of the car but primarily the front end and dash area. I've replaced the bottom dash rail with a piece of 38mm cds tube and triangulated this to the bulkhead. This gave me a good solid base with which to fabricate a steering column mount from.
(The paving slab in the footwell was just to see what height i'm looking at for foot rests)
The plan is to turbo this engine at a later date and so to preempt that move I also fitted a bulkhead box today. I had some 1.2 sheet kicking about and I was quite chuffed with how well all the folds formed with me only have two pieces of angle iron in the vice to bend it with
It wasn't until i put the head on the block and had it in front of me that i realized quite how neatly it sits on there.
Oh and something further of note is the wheels arrived today! Paul R's set he had for sale on here. With a bonus chocolate freddo in the box that Carl Austin must have left in there when they sent them to him...
I'll take some more pics tomorrow and keep up to date with this from now on, I hope.
One question for all in the know. I was concerned upon dismantling the head that the cam bearing caps only have one locating dowel on the end bearings. While the rest have only the bolts to locate upon. There is no relief around the bolt hole to suggest it should be there. I assume this is the same with them all?
Andy
Edited by adcyork on 13th Nov, 2021.
nice bit of fab work there.
I am tempted with the K head conversion....
looking good, you could make your own manifold but i doubt its worth it
adcyork
Member #: 6807
York
I'm not really in the game for making one. I don't have a tig welder for one. I'm sure I saw that sprocket had got a maniflow manifold?
adrian
Member #: 2726
wakefield
I keep been tempted to do a k head. Wot kit u gonna use?
Adrian
Billus89
Member #: 8931
Looks like a great project
Edited by Billus89 on 29th Mar, 2013.
adcyork
Member #: 6807
York
Adrian
I've got the force racing kit ready to go on. It all looks lovely and the anodising on the parts seems top notch.
Edited by adcyork on 31st Mar, 2013.
Its worth doing a little more to that bulkhead box and chop off the right hand corner to allow more room around the actuator
Image of Toms car
I belive he is running it in N/A form not turbo, plus with the khead you dont need a bhb, one like that would be perfect for an external wastegate and down pipe.
Btw wheel are looking good *smiley*
Cables69
Member #: 10196
iirc i think maniflow do list a k head manifold on there site
yep 249 quid for a steel one
Aye, Maniflow. I had them make one with the downpipes 3/8" shorter. whether it was or not I'll never know since I don't have another to compare lol. It's in Mild steel though, but at the very least it has everything in the right place and it's the right shape *wink*
adcyork
Member #: 6807
York
I am running it NA yes, at first anyway.
I was aware that you could get away without a bhb with the k conversion but i thought it best to stick one in while i was there incase any complications with packaging arise later
adcyork
Member #: 6807
York
What made you go for the 3/8" shorter pipe? To get it up higher in the tunnel?
I have looked at the mass market manifolds and they do seem to hang down low for very low road car. not an issue if your running sightly lowered but could be for a very low car.
I was going to make a manifold if staying Na, but have to anyway as I have decided to turbo.
adcyork
Member #: 6807
York
Progress is slow with doing overtime at work, frustrating!
I did get round to cutting the boot floor out in the rough form needed for the 'glass boot floor so i could try it up though. Mandatory thumbs up
adcyork
Member #: 6807
York
Bit more progress this eve.
Managed to get the 'glass boot floor in after some tidying and repair work to the remaining boot floor.
Just needs bolting and bonding now
Also began tubbing the rear arches. My next question though, how do you remove the sound deadening material from the inner side of the rear quarter? Is it a case of softening it with a heat gun and scraping?
Edited by adcyork on 18th Apr, 2013.
philc
Member #: 1346
bromsgrove
keep up the good work.
Kean
Member #: 341
aka T2clubby
South Staffs
Heat gun and scraper does the job
adcyork
Member #: 6807
York
Well, the ATB turned up yesterday, thanks again to John, top job!
I also went to pick my ali verto flywheel up from A&R precision. They seem a very decent couple of blokes down there, both ex Farndon Engineering apprentices. After discussion with Darren I spotted a familiar looking batch of conrods on the racking. It seems they manufacture mini speeds conrods for them. And I believe Swiftune are looking to resource to them. They do all of their own machining and shot peening in house with the heat treatment carried out locally by a firm on the same industrial estate. They're very reasonably priced too at £85 a rod.
The machining on the flywheel looks top notch
adcyork
Member #: 6807
York
It's been a while...
Since I last posted progress has been slow to say the least. A house move has given me a nice new cave to play in with much more useful space and no damp problems unlike the last place. Some new toys found their way in to the new place in the form of a machine mart special pillar drill and a Boxford CUD lathe. (I wish there was a nice looking alternative to that horrible looking halogen work light which was just as cheap)
So on with the shell; I decided that the toe board wasn't in good enough shape due to some previously repaired accident damage and needed replacing and so that was next on the agenda. So I did the decent thing to get at it all easier and make a spit:
A new cross member was also seam welded in while I was there as it was messy and I'd made a U turn on my opinion of the appearance of the speed holes drilled in the current item
Next job is turreting the rear arches. Quick question; the damper mount face stays in the same location in the Z axis when turreting doesn't it?
Also some progress with the head, all welded up and ready to be skimmed. I did happen to loose one of the spring seats though during disassembly, has anyone got a spare before I chase BMW for one? (2nd pic for reference)
There has also been a change of plan and this will now be turbo'd. So I picked myself up a standard ebay GT1752 turbo to find it had more radial play than the sellers description stated which I believe is standard these days... The compressor and turbines are both clean though so a rebuild is due and all is not lost.
Revised engine spec:
1330
K1200rs head
Worked rods
Single throttle body (size to be determined)
Swifty ATB
Minispares sccr gearset
Straight cut drops
Bespoke ducted side mounted intercooler in side mounted rad position
I'm currently a little stuck on which piston to use. I wanted to keep to an offset bored +0.060" so that I at least have the option to go to 73.5mm should necessity force it.
Looking at these: Does anyone know how much extra dish you can machine out of these?
http://www.med-engineering.co.uk/catalogue...ons-020-040-060
Edited by adcyork on 19th Aug, 2014.
nky_84
Member #: 9213
Scotland
looking good! all looks very familiar *smiley*. i've been racing in mod prod for last 2 years with a broadly similar setup
Did you do the alloy welding or get it done professionally? How much did it cost?
slater
Member #: 1291
Suffolk / Birmingham
Do motorworks not have any spring seats?
adcyork
Member #: 6807
York
Sounds good, what running gear set up are you running in that class?
I don't have an AC tig set so I got a mate to do it at M-sport on his dinner because he was able to preheat it aswell. £30. It seems that there are plenty of places that will do it for only slightly more though.
Slater - motorworks is the same price as new from bmw and I need to buy my new followers from them anyway. I do need to tap them up about a set of LT cams soon though.
