Page: |
Home > Track, Drag & Race > Mod Prod hillclimb regs queries | |||||||
539 Posts Member #: 6807 Post Whore York |
11th Dec, 2012 at 11:01:53pm
I'm looking to enter the Mod prod class in some hillclimb events and after looking at the MSA regs I've got some questions for you guys in the know (Wil H i'm looking at you..)
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
12th Dec, 2012 at 08:22:08am
Firstly we need to know what class you are intending to run in. Road going or non roadgoing?
On 11th Dec, 2012 adcyork said:
I'm looking to enter the Mod prod class in some hillclimb events and after looking at the MSA regs I've got some questions for you guys in the know (Wil H i'm looking at you..) The question are three fold. Can I: replace the side and rear glass with poly? cut vent holes in the front valance? Add a brace between the rear damper top mounts? Thanks Andy http://www.twin-turbo.co.uk
12th Dec, 2012 at 08:37:47am
I'm planning on entering the road going class to start with. |
12th Dec, 2012 at 08:49:59am
For roadgoing
12th Dec, 2012 at 09:37:00am
What mods are you aloud? |
12th Dec, 2012 at 09:50:16am
See here sections 10 an 11
12th Dec, 2012 at 10:02:53am
So with those mods, what class would I be placed in? Sports libre? |
12th Dec, 2012 at 10:16:00am
Thanks :] |
12th Dec, 2012 at 10:43:00am
On 12th Dec, 2012 adcyork said:
So with those mods, what class would I be placed in? Sports libre? http://www.twin-turbo.co.uk
12th Dec, 2012 at 11:16:25am
Was being a bit thick, I didn't notice Mod Prod in the original thread.
296 Posts Member #: 9117 Senior Member Northampton |
10th Jan, 2013 at 01:46:35pm
are the dates for 2013 hillclimbs out Wil? Confessed addiction to everything mini |
Forum Mod 1927 Posts Member #: 1761 Stalker Bristol |
10th Jan, 2013 at 01:56:07pm
684 Posts Member #: 9590 Post Whore Derby |
10th Jan, 2013 at 03:22:47pm
im really pushing for time to get mine finished Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
10th Jan, 2013 at 03:37:40pm
Lots of championships are listing events and some clubs have also listed them.
23rd Jan, 2013 at 12:51:48pm
#Hijack# Also thinking of running a few hillclimbs this season 1293 turbo thinking of running in non road going (even tho its road legal) can you run std mini fuel tank or is it fully internal like track regs? And advice on class to run in and good events near Northamptonshire ? Any and all advice welcome!! Will Confessed addiction to everything mini |
23rd Jan, 2013 at 06:47:57pm
What is the spec of your car? got any photos?
24th Jan, 2013 at 12:56:15pm
you have mail
On 23rd Jan, 2013 wil_h said:
What is the spec of your car? got any photos? Fuel tank will not be an issue. Nowt round northamptonshire See here for some tracks. http://www.hillclimbandsprint.co.uk/event-map.asp Confessed addiction to everything mini |
4304 Posts Member #: 1321 Post Whore Wiltshire |
24th Jan, 2013 at 05:54:26pm
Regarding the rollcage policy are they likely to get peculiar with non-standard rollcages. Mine is a bolt in safety devices jobbie, that has been welded in, and the sticker is now missing. Is this likely to be an issue?
25th Jan, 2013 at 10:30:30am
If you are hillclimbing/sprinting in mod-prod you will need an MSA logbook. The roll cage without a sticker should be ok at the moment, but in the future this is likely to change. http://www.twin-turbo.co.uk
26th Jan, 2013 at 08:19:43am
What's the best setup for the double springs on std turbo su carb? Confessed addiction to everything mini |
26th Jan, 2013 at 08:40:12am
They come as standard. One spring on each side of the spindle. You should not need to add anything. http://www.twin-turbo.co.uk
26th Jan, 2013 at 06:00:55pm
On 25th Jan, 2013 Ben H said:
If you are hillclimbing/sprinting in mod-prod you will need an MSA logbook. The roll cage without a sticker should be ok at the moment, but in the future this is likely to change. Hmm, this could get fun trying to remove the rear half to replace with a stickered one! On 7th Oct, 2010 5haneJ said:
27th Jan, 2013 at 10:21:38am
Once you have a logbook you will not need to change the cage. But if the rules change you will need a sticker to get a logbook. Well that is the easiest way. Otherwise you need to prove the materials you have used, etc. http://www.twin-turbo.co.uk
16th Mar, 2013 at 10:15:19am
I have a quick question.
16th Mar, 2013 at 09:37:30pm
I would say that would be fine. http://www.twin-turbo.co.uk
Page: |
