Page: |
Home > General Chat > clutch biting point | |||||||
28th Apr, 2012 at 06:20:13pm
i have lengthened the push rod from the slave cyl to the clutch arm and that has moved the piston up in to the slave more but not given me any more travel at the plunger,
Yes i moved to the darkside |
28th Apr, 2012 at 07:14:17pm
what clutch are you running? |
![]() 6748 Posts Member #: 828 Post Whore uranus |
28th Apr, 2012 at 07:22:34pm
check the pin that connects the clutch pedal to the master rod for wear , in fact ,check all the pins . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Apr, 2012 at 07:26:58pm
yeah,
28th Apr, 2012 at 07:42:27pm
Im running an AP-RTS with a 1275 and turbo spring. the 2 clutch arm pins have noticable wear the pedal to master pin is new. The clutch arm ball has very little wear on it i will try these 2 first Yes i moved to the darkside |
28th Apr, 2012 at 08:02:42pm
its not the plate that the slave bolts to flexing is it? On 28th Aug, 2011 Kean said:
28th Apr, 2012 at 08:21:57pm
i dont think so, Yes i moved to the darkside |
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
28th Apr, 2012 at 08:36:41pm
leaky master?, |
28th Apr, 2012 at 08:42:58pm
did you set the throwout stop for 6.5mm and does the throwout stop bottom out at full pedal travel? Any more than 6.5mm can cause the fingers of the spring to bind on clutch center boss.. If you did set the throwout at 6.5mm and the stop does bottom out at full pedal travel, your problem is nothing to do with the actuating mechanism
28th Apr, 2012 at 08:49:01pm
one other thing, clutch bite with the verto moves as wear takes place. with a new well set up verto the bite is usually at the top of the pedal travel, and as the clutch wears it ends up at the bpttpm pf the pedal travel. standard clutches are designed to slip in normal operation when they are worn and need replacing, this being the indicator to the driver that it needs replacing before the rivets damage the friction faces. This cannot be applied to an RTS since there is a greater clamping capacity to begin with therfore, when its worn, it won't slip. On 26th Oct, 2004 TurboDave16v said:
28th Apr, 2012 at 08:55:27pm
On 28th Apr, 2012 fastcarl said:
leaky master?, its a new one carl so hope not On 28th Apr, 2012 Sprocket said:
did you set the throwout stop for 6.5mm and does the throwout stop bottom out at full pedal travel? Any more than 6.5mm can cause the fingers of the spring to bind on clutch center boss.. If you did set the throwout at 6.5mm and the stop does bottom out at full pedal travel, your problem is nothing to do with the actuating mechanism my gap is possibly less than then and it doesnt bottom out i will re check this over tomorrow On 28th Apr, 2012 Sprocket said:
The problem with lengthening the pushrod on a Verto clutch is that as the frictionsurfaces wear, the slavecylinder piston is pushed further into the cylinder when the clutch is engaged. If there is no room for this to happen IE the push rod has been lengthened to push the piston further into the cylinder, the clutch might not fully engage as wear takes place. i think there is still a few mm of piston travel left for the wear, but the release bearing does press onto the clutch 'fingers' all the time, i was a little concerned with this to begin with but now i think this is normal am i correct? Edited by Brett on 28th Apr, 2012. Yes i moved to the darkside |
29th Apr, 2012 at 07:49:55am
one other thing, clutch bite with the verto moves as wear takes place. with a new well set up verto the bite is usually at the top of the pedal travel, and as the clutch wears it ends up at the bpttpm pf the pedal travel. standard clutches are designed to slip in normal operation when they are worn and need replacing, this being the indicator to the driver that it needs replacing before the rivets damage the friction faces. This cannot be applied to an RTS since there is a greater clamping capacity to begin with therfore, when its worn, it won't slip. so far in my experience i'll have to disagree colin ![]() the plate wear has not caused a change in pedal bite position , also you can definately get a rts to slip.mine slipped so badly, before a redesign of the system, i thought the car had slipped into neutral .this was only above around 230 ft/lbs though . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th Apr, 2012 at 08:11:55am
I've got a spare brand new pin for the arm - wok you can have if you want Brett. Benny is heading over in a bit, so I can give it to him to relay if you like. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
29th Apr, 2012 at 08:20:45am
yeah can do mate, want anything for it? Yes i moved to the darkside |
29th Apr, 2012 at 08:24:02am
29th Apr, 2012 at 09:01:18am
one other thing, clutch bite with the verto moves as wear takes place. with a new well set up verto the bite is usually at the top of the pedal travel, and as the clutch wears it ends up at the bpttpm pf the pedal travel. standard clutches are designed to slip in normal operation when they are worn and need replacing, this being the indicator to the driver that it needs replacing before the rivets damage the friction faces. This cannot be applied to an RTS since there is a greater clamping capacity to begin with therfore, when its worn, it won't slip. so far in my experience i'll have to disagree colin ![]() the plate wear has not caused a change in pedal bite position , also you can definately get a rts to slip.mine slipped so badly, before a redesign of the system, i thought the car had slipped into neutral .this was only above around 230 ft/lbs though . On 26th Oct, 2004 TurboDave16v said:
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
17th Jun, 2018 at 11:43:26am
Anyone know if Brett managed to cure this with just new pins?
17th Jun, 2018 at 07:32:37pm
I’m fighting this EXACT thing right now. If I’m driving along in gear, my clutch seems to be releasing about half way of the “heavy travel” at the pedal (by this, I mean ignoring the first 3/4” to 1” of pedal travel that has little to no resistance), but the FULL disengagement point, is right at the floor. It means I basically have to put the pedal mashed into the carpet and wait three seconds before I can get reverse. If I have a piece of 1/4” board under the pedal, it won’t disengage.
Edited by TurboDave16V on 17th Jun, 2018. On 17th Nov, 2014 Tom Fenton said:
17th Jun, 2018 at 07:37:25pm
As a reference, it looks like you can get almost 1” pushrod travel at the pedal (with the clevis arm of the pedal touching the crossmember box that it sits in) to full compression.
17th Jun, 2018 at 07:42:12pm
Thanks Dave, good to know it's not just me.
17th Jun, 2018 at 07:43:51pm
I’m literally working On this right now, I’ve just come inside to get myself a quick bite to eat, and get out this heat!
17th Jun, 2018 at 07:52:12pm
The other thing I have noticed, is that seems to be something wrong with the stack up of parts installed on my system.
17th Jun, 2018 at 08:31:23pm
Alrighty then!
17th Jun, 2018 at 08:40:04pm
It’s kind of hard to measure the required pedal travel, as it goes through an arc, but measuring between the same points (on the side of the pedal rubber, at the centre of the pedal) between pedal on the floor to pedal fully raised) is now 4.5” on my mini.
17th Jun, 2018 at 09:28:38pm
I will say this; the small (pre 74?) pedal rubbers are a pain to use with the twin spring clutch. It’s not my leg that hurts after continuous pushing; it’s the ball of my foot that is throbbing from the pressure point of the small pedal. Given my typical shoe is 3x wider than the pedal rubber means there is room for improvement - but I kind of like the factory look of the small pedal.
Page: |
