Home > Show Us Yours! > My White Turbo Mini
m_brady15
Member #: 8011
Hello there everyone.
This has been my first project I have ever taken on and its defiantly had it's ups and downs. But I have enjoyed every second if it so far.
I have been working on my mini for about a year or so now.
Just thought it was about time I posted up some photo's of how the project is going so far.
I hope that you all like it and I would very much appreciate any comments or constructive criticism.
Miles
Edited by m_brady15 on 4th Dec, 2011.
lots more hard work and you will get there
m_brady15
Member #: 8011
There are so many more photos and its a lot more complete than that. I'm just having a bit of trouble uploading all the photo's.
I will get the photo's on soon i hope
m_brady15
Member #: 8011
IMG]http://i1234.photobucket.com/albums/ff414/m_brady15/11.jpg[/IMG]
m_brady15
Member #: 8011
m_brady15
Member #: 8011
m_brady15
Member #: 8011
hazpalmer
Member #: 9038
Carlisle, Cumbria
Awesome project! I love black and white minis, should check out mine. So what engines going into this?
m_brady15
Member #: 8011
Thank you very much, yea I will check your's out mate.
I'll need to take some photo's of the engine as it's in now but not running yet.
The engine spec is as follows:
New metro turbo block, re bored to 1293 painted red
Forged Omega pistons 18cc for high boost, new rings
Balanced turbo con rods
Turbo balanced crank
Phase 2 Avon bar cam
All new bearings
Metro turbo head. New exhaust and inlet valve’s, stem seals, custom double valve springs, MED yellow 1:5 rocker set and push rods, polished, ported and gas flowed head, massive chambers for high boost
Alloy finned rocker cover
Drilled 11 stud
ARP studs and nuts
New exhaust studs and copper nuts
Custom laser cut one piece copper exhaust gasket
3 layer cosmetic steel head gasket
Skimmed manifold and inlet
2” turbo down pipe
Straight through exhaust with centre exit DTM back box
Modified plenum for front mount intercooler and dump valve
Custom intercooler pipe work with blue silicone
Rover turbo intercooler
Thermex motorsport oil cooler
T3 base turbo with 38mm compressor, 360 thrust bearing, new core, adjustable -31 actuator, only covered about 2-3000 miles 250bhp
New silicone turbo oil drain
1” ¾ turbo carb, re built with new float spring and high boost needle
High flow Bosch fuel pump
New sender
Jack Knight straight gear box, newly re built with all new bearings
4 pin differential
Paddle clutch
Road/race release plate
Lightened fly wheel
Megajolt
2 core radiator/super flow
4 fin metal fan
High pressure radiator cap
Should be producing a few horses
Miles
Great work!
Looks like you have good taste in colours. *wink*
m_brady15
Member #: 8011
Thanks Matty
looks cracking. I like how you have done the cage the same colour as the car :)
dig-mini
Member #: 9269
Rotherham
yes I like the way you painted the cage the same colour as the car too. did you get much dust in the black roof?
Craig
m_brady15
Member #: 8011
Thanks dig-mini & miniwilliams
Yea I wanted to cage to blend into the interior as much as it could, hence the same colour as the mini.
The black roof didn't get much dust into it as I made the spray area as sealed as possible but I did get a few scratches come through from sanding in the prep work :(
G13B
Member #: 1376
yea top work, looks real tidy*wink*
is that a painless, ez type of universal harness?
m_brady15
Member #: 8011
Yes G13B its a universal harness.
Because i've modified quite a few things i though there would be no point in paying for a standard mini loom and then modifying that.
Its turning out not to be so easy to install, just because of my lack of knowledge of electronics. Looking for someone to help me out with it actually.
Once the wiring is done it should be almost ready to mot really.
Miles
G13B
Member #: 1376
cool, i will get one in the near future too for my midget
looking for a basic hot rod one, where did you get yours and how much was it?
cheers
/marcus
I'm building my loom from scratch. I don't think a kit like that will be all that easy to plumb in...
m_brady15
Member #: 8011
Looks good mate,
Just a quick one mate the bolts in the rear half of your roll cage are best with the nuts on the inside of the car. As the wheel could hit the studs that's hanging out.
Simon.
Maybe remove the picture of the car's original log book. *wink*
WRLondon
Member #: 8636
Surrey
this lol
it is a public forum, and maybe do some mk1 style changes like madmk1 did *hehe!*
Reading up on RTS Clutches
What you on about??? My Mk1 is real! it was rebuild in a time when you could not get mk1 floors that's why it don't have a mk1 floor! but I paid £150 for it so who gives a shit.
Only criticism i have for this is don't fit that great big gay DTM exhaust. They look crap on just about anything :/
But the rest of it looks really good so far!
To add to that... oversills...
