Home > Show Us Yours! > O/T- Ford DMF (Dual Mass Flywheel)
I've mentioned it before, the DMF. especially the Mondeo TDCi one is crap.
I've actually got one in my hands now, I did most of the dis-assembly but gave it to my local garage for the final bit (didn't have the facilities/room in my garage to get the car high enough to drop the gearbox) and here is the result.
The pictures don't really show it but about 10mm movement on the outside of the flywheel without hitting the springs.
And nearly 1.5mm axial play.
Self adjusting clutch springs at their limit.
And all this from 65k miles.
The new flywheel/clutch I bought was from Eurocarparts... dot
When I picked it up they said the Mondeo TDCi was their best selling flywheel bar none (the VW/Audi was a very poor second best seller).
Edited by Rod S on 29th Nov, 2011.
Do you mind me asking the price? Wouldnt be surprised if I need one soon
Star Mag
Member #: 375
Leicestershire
My old mans mondeos starter motor just packed up. It turned out the flywheel had broken up and killed the starter. It had new clutch, flywheel and starter at the cost of £1200 from Ford.
Fortunately it's a company car. This was at 132k though. The power steering is starting to go now!
tadge44
Member #: 2500
Buckinghamshire
Manufacturers are now apparently turning away from DMF,s and I know of someone close to me who managed to replace his failed DMF with a "solid" one quite easily.
It was in an Audi rather than a Ford but it seems to me there is an opening for some enterprising young man to make a business out of this.
The only problem that I see is that the biggest cost of replacement is the labour.
I think it is ridiculous that to get to a clutch and flywheel it is necessary to drop a front subframe and suspension and then remove engine and gearbox.
OOPs thats we what we used to do to minis wasn,t it ?.
JT
Member #: 637
Hertfordshire
got mine done about 2 months ago!!
i got the bits off ebay and gave it to my dads mate who is a mechanic. he charged me £160 to fit it then i needed a new starter which was £90.
its back at his now to have 2 injectors and a new ecu fitted and programmed! not sure on the price for this yet!! apart from its cost £200 for the injectors and £60 for the ecu!!
when you get your new flywheel kit make sure its a duel mass one and not a single mass one. the single mass one is for the transit vans.
apparently if you fit them to the mondeos, the clutch just slips. i read this on a ford forum.
mine went at 140k but i think it was going before then as the previous owner had a new starter and clutch fitted, but not the flywheel!!
My build thread..
The genuine LUK kit was £405 from my local Eurocarparts centre collected in person. That's flywheel, clutch and concentric realese cylinder. The internet price from Eurocarparts is a lot more. But all genuine LUK parts from Europarts non-internet depots.
That's just parts, doing it yourself is a total pain, I did half of the job myself then gave it to my local garge to do the hard parts where a two post lift is required.
Just got the car back today so I have to re-assemble the rest to see how effective the replacemant is.
Yes, starter moter failure is the inevitable sign of the DMS failing....
Mine was early at 65k miles but the symptoms are well recorded :)
Yes, I tried a single mass flywheel but what i was sold was crap.
Luckily I found out before I fitted it (suitable for transit vans only, not the 130HP Mondeo....)
Got a full refund off eBay the bought the proper LUK dual mass kit.
Yes, David, but dropping the subframe in a Mini is a hell of a lot easier than dropping the subframe on something "modern".
There seem to be as many problems with the "new" single mass flywheels as the DMFs.
But you are right, labour is the major cost.
I did most myself but left the difficult bits (ie, where I didn't have the ramps/lifts/etc) to my local garage.
wez
Member #: 9271
Stoke on Trent
They did a clutch around the garage where my mini is stored the other day and it was completely twisted, they had to cut the middle out with gas bottles as the holes for the flywheel bolts no longer lined up. And they drove the car in with a bit of a judder :-S
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
I did Lisa's V50 DMF at 105k its got the ford tdci engine and 105k is actually reasonable mileage, its a fair old job to do so i put in a genuine LUK unit as we have had some problems with the cheaper SACH's unit from memory i paid about £380 trade for the lot i also changed the slave cylinder as its inside the box on the ford engines and there is no way that box is coming off the car again.
I think have only picked up one VAG car in nearly 5 years of recovery for a failed DMF and only a handfull of fords however i have picked up loads of hyundai 4x4's with failed DMF's
My a4's bighting point was highish when i bought it with 50k ish in it. now approaching 160k and its a little worse. i reckon the dmfw is worn causing the high bite, but not worn enough to slip or drive badly. I'll change it when it causes a problem. my old a4 was the same...
I had mine done on the A4 at 80k as the car was vibrating badly at tick-over - £800 all in; nothing wrong with the clutch performance as such. Apparently the 2.0 tdi vag units are really bad for it too
Yes, that's what the guy at Eurocarparts told me, the 2litre VW/Audi diesel was their second best selling DMF.
But he said nowhere near the numbers of Ford Mondeo ones they sell :)
Flame Red
Member #: 6267
I went to look at an Audi S4 a few years ago, it had had the clutch replaced at 40k miles and had cost just short of £1000, I expect that was DMF failure but the owner didn't know what a DMF was so couldn't tell me! I have a similar engine in my car but without the DMF and it is on 161k miles and still has the original clutch. I'm very pleased I didn't buy the S4 although that's more because of the depreciation than the DMF!
Wintersurfer is still having trouble with his after a garage completed their second attempt at fixing his Mondeo.
Clutch DMF and slave have all been changed, but he still has sporadic gear engagement issues.
mcalvert39
Member #: 442
Manchester
DMF's really arnt the best. I cant see the extra benifit of having one over the huge increase in weight from a standard assembly. Ive changed one on a diesel vectra which was a pain in the arse but much like the rover 75 diesel ones. All i had to do was loosen the subframe mounts enough just to shove the gearbox into the inner wing, leaving just enough gap to get to everything. Not sure you can do this on the mondeo though as ive never worked on one.
metroturbo
Member #: 989
North Yorkshire
The extra benefit is the reduction in NVH which was always a problem with diesels. It also then means the car can be driven at lower revs in higher gears. This reduces the emissions, and helps manufacturers comply with ever reducing emission limits, and get the vehicle into a lower CO2 band.
A very valid, but rather more inetersting point here....
Yes reduce emmissions but, if it's so badly designed (as appears to be the case) that tens of thousands, maybe millions in the total lifespan, are being replaced, what about the carbon emissions from that ???
Carbon cost of making the new ones from all the processes right from extracting the ore to turn into steel, through to workshop power/heating/lighting installing it.
It's a bit like the "renewable" energy equation - it takes a lot of years before the carbon costs expended building them begins to be offset by their low carbon output.
metroturbo
Member #: 989
North Yorkshire
You won't hear any disagreement from me on it. I don't agree with the smoke and mirrors of car CO2 banding where people believe they are saving the world because they pay no car tax on their milk float. Reducing NOX and particulate emissions is a different matter and worth it in my opinion.
I agree entirely on NOX and particulates but CO2 is a con.
People are being told to reduce CO2 but most of the products that use less CO2 make a hell of a lot of CO2 during their production.
But the bottom line is. If you're car has a DMF and the clutch needs replaced. Make sure you get a new flywheel one way or another !!
I just pulled my Combo van to repalce the clutch. Engine ran smooth, no noises, rattles, everything drove perfect apart from the clutch slipping. It's been doing it since about 140k but Ive babied it to 155k now.
SO I stupidly assumed the DMF was ok. Now it's stuck on a ramp and hoping a replacement will arrive tomorrow.
New DMF from dealer was around £450+vat. A Local clutch specialist says they can supply for £160+vat.
I hope they can. There are no solid conversions available for this. Some gearboxes can safely revert to a normal flywheel, others are designed to be used with the DMF and cannot be altered.
Bloody pain in the hole now, as no van, no work !!
coleman262
Member #: 8904
Bexhill, South East
The point to dmf as i understand is because of the torque that engines produce they save the gearbox... some people have had problems with gearboxes after doing the solid conversion. but from what i hear they are going back to solid and using the ecu to control the torque instead.
what do they actually do?
Fail in a very expensive way :)
Seriously, they act as a very large torsional damper between the engine and the gearbox/drivetrain.
Diesel engines, especially the electronically injected ones, produce a very spikey torque output which can allegedly destroy gearboxes. Although I say "allegedly", they obviously do produce this spikey output, as they destroy the flywheel instead.
It's strange that the failure is more prevelant on certain engines which does question the original design (per engine).
