| Home > 998cc > 998 +60 turbo expected output? | |||||||
32 Posts Member #: 5055 Member leicester |
20th Jul, 2011 at 10:00:04pm
Heloooo I'm starting my turbo build this weekend and was just wondering how much power you think it'll produce. It's going to be used on the road/ track days and eventually a road trip to France :)
20th Jul, 2011 at 10:10:17pm
Seems reasonably well thought through, but you won't get 20psi from a T2. Much over 12psi and you will be just generating heat.
http://www.twin-turbo.co.uk
20th Jul, 2011 at 10:21:26pm
Thanks for the reply Ben, 20psi would've been an absoloute max incase I saw an r1 up my arse haha.
21st Jul, 2011 at 08:09:02am
When I say it will generate heat what i mean is that much over 12psi and the T2 is outside of its efficient range. The inlet air temperature just rises massively so although your boost gauge might tell you you are running higher boosts you probably won't be running much more power and probably risking detonation. No amount of cooling of the turbo will fix this.
21st Jul, 2011 at 08:25:47am
+60 is about 1046cc
21st Jul, 2011 at 09:00:25am
^ Listen to these two they know what they are on about. If something is worth doing, it's worth doing half of. |
![]() 774 Posts Member #: 6724 Post Whore Wootton Bassett |
21st Jul, 2011 at 12:18:21pm
On 21st Jul, 2011 John said:
^ Listen to these two they know what they are on about. They certainly do. See my build thread below. I'm at 110 bhp with a T2 on my 998 so with the 4% cc increase you have you'll get approx 115 bhp |
21st Jul, 2011 at 12:29:58pm
Thanks, But I'm just guessing as much as anyone. If it dosen't work I don't tell you!!
^ Listen to these two they know what they are on about. They certainly do. See my build thread below. I'm at 110 bhp with a T2 on my 998 so with the 4% cc increase you have you'll get approx 115 bhp Fastest 998 mini in the world? 13.05 1/4 mile 106mph
21st Jul, 2011 at 12:37:09pm
Any thoughts what turbo he should use if he wanted 20psi on a 998 wil? Is there anything that will spool at a reasonable threshold? If something is worth doing, it's worth doing half of. |
21st Jul, 2011 at 12:57:15pm
Well the GT17 will easily make that, but it's not something that I'd want to live with every day.
![]() 6752 Posts Member #: 828 Post Whore uranus |
21st Jul, 2011 at 05:14:01pm
T2 50 TRIM still above 65% EFF up to 22 PSI... at 140 to 150 bhp.
21st Jul, 2011 at 05:49:19pm
The map may well say that, but our real life experience with the T2 on a 998 was not the same. We managed about 135 bananas, but were always on the limit of det.
Edited by Ben H on 21st Jul, 2011. http://www.twin-turbo.co.uk
21st Jul, 2011 at 07:17:24pm
minispeed.co.uk/content/camshaft-kent-turbo
21st Jul, 2011 at 07:55:43pm
Thanks for all the replies guys
21st Jul, 2011 at 08:25:10pm
You don't need a billet cam, the md500 is fine Fastest 998 mini in the world? 13.05 1/4 mile 106mph
21st Jul, 2011 at 09:31:00pm
Thanks will I've just ordered the cam, ill be getting new cam bearings,
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
21st Jul, 2011 at 09:44:43pm
If your still in the machining phase would it not advantagous to pocket the block for a 1275 head or is this not necessary on a turbo motor with the esstimated bananarage?
Edited by zerocool_jj2000 on 21st Jul, 2011. |
21st Jul, 2011 at 10:00:03pm
The 295 head makes a good road engine. For 150+ a 940 would be my choice, but in this case a well modified 295 will be the best choice. http://www.twin-turbo.co.uk
21st Jul, 2011 at 10:08:49pm
Bananarage lol!
26th Jul, 2011 at 01:06:08am
Right then some progress or should i say a start has been made! I stripped the engine down tonight afterwork. Was loads of funn and only took a few hours. the block Is being sent for machining on Saturday :)
26th Jul, 2011 at 01:15:28am
One from behind |
26th Jul, 2011 at 08:14:23am
The fastest engines are black On 11th Feb, 2015 robert said:
26th Jul, 2011 at 09:31:02am
Mine'll be going black.... Only because it looks good next to blue and it hides the oil stains better On 7th Nov, 2011 apbellamy said:
26th Jul, 2011 at 10:44:59am
Phew, thank god for that. Saves me some work.
On 26th Jul, 2011 apbellamy said:
The fastest engines are black ![]() |
26th Jul, 2011 at 01:25:04pm
The fastest engines are black ![]() Prove it! What colour is the Don's and the Twinnie's?
