Home > 998cc > 12G202 head modding
Advantage
Member #: 1450
Near Paris - France
Hi gents,
I started modding a 202 that I bought for the deerest sum of 20£.
Here it is as I bought it :
As the perfect newbie, I worked the chambers before noticing the ports are in pretty bad shape, particularily the centre exhaust port.
At first, I intented to reuse the valves so I cleaned the first set then I noticed one of the exhaust port is shot.
This head is intended for a N/A 998 pepped up on the cheap.
But I can't make up my mind about the exhaust valves, keep the standard size valves or go OS.
OS means I'll have to have the seat recut.
Also, I have no idea if the OS exhaust valve is required on such a low power application ...
Anyway, next pics tomorrow
Edited by Advantage on 2nd Mar, 2011.
Rusty by nature
Depending how bad the valve seats are you may find by the time they are recut that the valves sit very low, & in some extreme cases almost falls through, so you may find you need to go up in valve sizes in order to get a decent seat.
jlay
Member #: 1742
essex
be carefull looking at the exhaust seats most small bore heads i have stripped had burnt-eroded valve seats. If you can get away with just a recut standard valves are cheap oversize ones are quite a jump in price. You could always have hardned seats fitted to runs it happening in the future. This is what i should have done on the 202 i did i just got away with new valves but could do with new seats really which i will do when i next have the head off or prep another head from stock.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
You cannot use std valves at a guess. First of all, they won't clean up the old seat, second they are too small for a performance 998. Minispares 26,5mm ones are perfect, and cheap.
Some 202 pictures here:
http://home.online.no/~lyngset/enginestuff...t=25&pDispType=
Advantage
Member #: 1450
Near Paris - France
Thanks for the comments.
I found out today that I need to go OS anyway as the burned exhaust took a part of the seat with it ...
So here we go : Standart 202 inlet valves and OS exhausts (at 3 times the price, ouch)
Rusty by nature
Advantage
Member #: 1450
Near Paris - France
Ho and day 4 pics by the way :
Shall I mention all the work so far has been carried out in the kitchen ?
And the weight of the head is 12,8 Kgs and I was planning to gain some on that.
We'll see how the seats clears before going any further.
Rusty by nature
jlay
Member #: 1742
essex
yep sounds like another typical small bore head. If your changing the valves bare in mind the guides might be a different fit on the new ones. Also the guides probably wont have the grove for seals so if too loose you will get the usual puff of smoke. Keep up the good work carefull with the kitchen.
Advantage
Member #: 1450
Near Paris - France
The seat :
Freaky combo : valve and seat !
Rusty by nature
Advantage
Member #: 1450
Near Paris - France
It was really really messed up with carbon deposit !
You're saying that what is tight might become too tight or loose with a new valve ?
I have a set of bronze guide, I'll see if they are needed.
Yes but I am not too concerned about that as this head is really a temporary mesure, on a very occasionnal car and on a tight budget
Anybody got a Neway cutting tool ?
I cant figure out what size to buy and which can perform a 3 angles cut.
Comments on standart 1 5/16 inlet and 1,043" OS exhaust (on a 998 with a MD256 and a set of 1275 pressed steel rockers) ?
Rusty by nature
The Neway cutters either have a single angle cutter on one side, or a different angle on on two sides. Either way you'll need either two or three cutter to create a 3 angle seat.
jlay
Member #: 1742
essex
Yep i have a set of neway cutters that vary enough for small bore heads to largest valves for the large bore the only thing i havent got is the cutter guide for the turbo size valve guides and unless im really stuch i wont for arond £50 for a stick and collet. I cant remember the cutter numbers i have but can find out if you want they set me back £350 so you have to know you are gona be playing with heads for along time lol
Advantage
Member #: 1450
Near Paris - France
Ouch, 350£ !
Unless I turn that head addiction to a little business, it's a little steep.
But, in France, machinist are mostly businessmen rather than engineering enthusiasts so it might cost pretty close to that price anyway.
I have been quoted from 200 € (300£) to 800+ (1200£) for a set of BMW motorbike heads, that is 4 valves in total !
So I'll get a quote and see what I choose.
Rusty by nature
Neway is junk. Get the seats done at someone who knows what they are doing. Also, the condition of the guides does not matter as you will be porting it, the guides will need to come out anyway.
jlay
Member #: 1742
essex
neway are junk? I think not i know alot of companys that use them and have used them in work and hobby for 14 years now. Ok they take some time if your going huge valve from small but thats never been a problem.
Advantage
Member #: 1450
Near Paris - France
On 3rd Mar, 2011 Vegard said:
Neway is junk.
Vegard, sometimes you remind me of father Jack from the Father Ted show
But please, would you mind backing up your comment with a little more than emphasis ?
As stated, it is a budget build for a N/A 998. I am not looking for all-out results just wanting to do what can be done "for free" so I'll try to do the ports without altering the guides (and most certainly lose a few HP in the equation)
Rusty by nature
Then there's absolutely no reason to port it whatsoever. It's in the area around the valves that dividends are made. Have it decoked, and use it as it is.
A Neway makes a 3mm wide seat if you're increasing the valve size as there are no 3 angle seats. Also, they do not have the feature of centering the pilot in the guide. Things have moved on since 1937.
jlay
Member #: 1742
essex
wrong the guides i have are collet type so self centreing and also have precision ground guide for mini guides you use a second cutter to narrow the seat once the valve height has been set or if you are not cutting 3 angle you widen the port to narrow the seat.
A job which takes 7 minutes with the proper tool.. I know I couldn't be arsed.
Advantage
Member #: 1450
Near Paris - France
Any home tools falls in the "proper" category ?
Rusty by nature
Nope.
tadge44
Member #: 2500
Buckinghamshire
However, most of us do the best we can with whatever we have and can afford.The results that some get with this approach is pretty impressive IMO.
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Advantage.
I have a Neway set. It is self centering. I can cut 75, 45 and 15 degree angels. Can´t cut 30 degree seat angle YET.
I usually charge 100£ for 8 valves, but for you i´ll do it for free.
*smiley* All you have to do is to drop it off at my place, or go to the post office *smiley*
If i have more toys than you when i die, I WIN
Advantage
Member #: 1450
Near Paris - France
That's very kind of you but carrying an heavy item abroad can prove very expensive as I just checked.
It would be 424 euros to Danemark and back wich shall allow me to buy a neway set or have those done with proper tools ( *wink* )
Rusty by nature
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
I can't see the point into giving any money int this S...
it does ahve the same ports has a std 998 head, just bigger valves, but then these ones are dead
it does have a bigger vlume : need a lot of skim=money
it needs valves , port work, guides, cutting seats...
if you find a proper 295 head I'll understand,
with no money to put thru this why not drop a 33/30 1275 head?
Ozyris
Member #: 9054
Disneyland Near Paris
+1 avec fab
and if you want i have some 998 head in stock
