Home > For Sale > 5 Port EFI Kits - Gauging Interest
I'm about to start on another EFi project and need to put together a load of parts.
Whilst I am at it, I thought it may be worthwhile making a kit of parts available. Most of it will be bought in except the inlet manifold and some other odds and ends.
This will utilise the Megasquirt ECU including the TM developed Siamese Code options.
It will not be cheap - £2k plus I would think, but what you will get will be proven and have a base setup which with a little tweaking should be ready to go. Help with the final setup would be available.
The sort of contents of the kit would be as follows:
Main Hardware:
ECU - MSII with two injector outputs, two coil outputs, cam sensor and dual O2 sensor input. Numerous add-on extras available.
Throttle Body/Bodies - Dual Jenvey for NA or single for charged version.
Inlet Manifold - Fabricated to take two or three injectors per port. Simple NA version for dual TBs or charged version with plenum for single TB.
Sensors:
Throttle Position Sensor
Coolant Temperature Sensor
Inlet Air Temperature Sensor
Crank Position Sensor
Phase Sensor (modded Dizzy or hall sensor for cam drive wheel)
Dual Oxygen Sensors with gauges
Fuel System:
Injectors - 2/4/6
Fuel Rails
Fuel Pump
Fuel Filter
Fuel Pressure Regulator
Ignition:
Coil Pack or Coil On/Near Plug or Logic Level Coils
Miscelaneous:
Trigger Wheel
Idle Air Control Valve
Looms
It will be priced up as packages with options. All parts would be new, nothing ex-scrappy.
Would this be of interest to anyone?
boostjunkie
Member #: 9117
Northampton
Sounds great but not got that sort of cash this year, maybe next *wink*
Nial
Member #: 9073
Edinburgh
Yes possibly but I've got a few bits I wouldn't need.
And £2K would need 'management' approval.
Nial.
160+ views and a couple of maybes.
I think I'll park that idea for now.
ministef1
Member #: 1791
Cranleigh, surrey
think its the cost, its a brilliant product but not many people would want to spend £2k when still the most powerfull turbo 5 port a-series are on carb? just thinking out loud.......
"Cars are a lifetime of pain"
I wouldn't give up on the idea Paul.
If you are going to build another cost it up and offer it out, you never know.
Nial
Member #: 9073
Edinburgh
As John says don't give up just yet (specially if it'll save you money?).
You could do with publicising this a bit more, there is a good chance that you'll get people on Minifinity or The Mini Forum who are interested.
Nial
I think that once we have a few more cars using the Siamese code then people will take more interest.
I need to get the 1293 Turbo Miglia running and producing the goods, then there may be an indication of the benefits in peak horsepower terms over a carburetor.
TBH "peak" horsepower doesn't interest me. I want the mid range and part throttle driveability that a mapped injection system can offer.
If I can't accomplish this with the 5-port then the 7-port beckons *wink*
EDIT: Consider this me registering interest in this package, however if a 7-port injected solution can be had for the same sort of money then this may be the way to go.
Edited by John on 20th Oct, 2010.
jbelanger
Member #: 831
Montreal, Canada
The advantage with a correctly designed EFI system is that you don't have to compromise on one to get the other.
Jean
http://www.jbperf.com/
Nial
Member #: 9073
Edinburgh
Me too!
(And [whisper]better fuel consumption![/whisper])
Nial.
Edited by Nial on 20th Oct, 2010.
This is considerably cheaper than a 7 Port option. You will still need all of the above, plus the cylinder head.
As for mid-range torque and driveability, my 998Ti has bags of it. It is very smooth to drive and has the feel of a modern car.
The other thing to consider is that the EFi opens up the options of boost control, launch control, traction control, data logging etc. Plus you will only need a rolling road to establish the optimum ignition timing.
welshdan
Member #: 1111
s wales
its a good idea. it hink what you are up against is the lack of spare cash most people have at the moment
dan
MarkGTT
Member #: 1194
Shropshire.
i think 2k for this is a bargain, great work Paul.
For what it's worth, I think you summed it up yourself....
In the UK I'm only aware of three of us who are actually running it at the moment which covers you (turbo 998 on the road for over a year), Graham (std 998 on the road but experimenting with sequential injection) and myself (turbo, but just running it for testing in the garage at the moment as the car isn't finished).
Not really a good advert at the moment despite our progress.
Anyone with an SU can beat us easily so far :)
The other point is we've all done it different ways - your second version for the Miglia is significantly different to your first version, just as my second version will be different to my first. Graham's is different too - and so on.... there won't be five the same soon.
So, you're right, we need more people to give it a try.
The code Jean wrote is now superb in its flexibility to set the injection sequence however we want (you, me and Graham are all doing it differently) but there is no standard yet - ether in the physical hardware or the way to use the code.
That's the problem in trying to progress it at the moment, no obvious best way and R&D comes expensive.
BTW, this is not intended to be negative - I've spent too much for that, just to try to put some perspective on the issue.
Make that 6 as this latest one is NA 1380. The intention is to get some comparible data with a Weber carb.
That is if I can keep Sturgeo on track. He keeps drifting off towards Skylines at the moment :(
Ive honestly never been interested but if youre doing a 1380 NA Ill be watching the progress.
What spec would it be?
Paul
i think 2k is cheap
Paul
This thread:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=380668
Ah, ofcourse - silly me
just logging my interest, i dont intend on having efi straight away but definitely in the future, i am planning a 7port head to make it simpler but i have eyes on your mig :)
The idea with building a high spec NA 1380 is that the available power from a 296 cam, 36/31 head and a Weber carb is well understood. This will give us a direct comparison.
The problem with any turbo engine is that it is difficult to make any direct comparisons due to too many variations.
Although I am building a high spec 998 Turbo that should be comparable with the TT2 or Graham Harveys car.
The 5 port EFi is not as simple as a 7/8 port, but the only additional feature that you have to set up is the injection timing table. This only takes a few hours on the road.
I am yet to be convinced that you need any more than two inlet ports to make real power with a turbo. On a 7/8 port head, you have twice the port, but they are only working for half the time. I know there is the issue of charge robbing, but with a long LCA cam and minimal overlap, that can be mimimised.
This is starting to sound like a sales pitch. That was not the intention but there seems to be a consensus that if you use injection you must have 4 inlet ports.
for what it offers, i think this is cheap too
think about it, £2k for a bolt on package that will give optimum running conditions for your engine, and further more any engine you ever buy
if i had the money at present i would be a definate yes, but one day i will and this is definately the route ill go down
but remember its not just the parts you will be getting, but the valuable time all these guys have put into the r&d to get it to this stage
I've been doing a bit of research and this is looking more attractive. I think further reading is in order. *smiley*
