Page: |
Home > 998cc > 998 Twinky Turbo - Advice Needed | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
15th May, 2010 at 12:14:25am
After having bought the kit of john a couple of years back for doing a K Head conversion ive finally got round to welding it up and prepping a block, I was going to build a 998 supercharged engine for the marcos but after a couple of mates having issues with there kits from a reputable specialist I thought about going 998 K Head, then I thought what about a 998 turbo twinky.
15th May, 2010 at 08:09:25am
What head do you have 8v or 16v?
15th May, 2010 at 08:01:28pm
Alrigh Wil, Ive got a 8v but ive also got a 16v sat in the workshop but the 8v is all welded up and ready for machining.
15th May, 2010 at 08:22:36pm
audi 80 tdi's use t2's Drives
16th May, 2010 at 11:59:51am
theres a few t2s on ebay at the mo, which all need rebuilds which isnt surprising, so will try and get one cheapish and rebuild it at work unless someone has one to sell? |
13th Jun, 2010 at 07:35:46pm
Quick update, i got a free T25 from a lad at work which is in very good condition with very little float in the shaft and the usual crack in hte housing :) I was going to use this to mock up the manifold but i now have a suitable T2 from a Renault 5 which i will use.
14th Jun, 2010 at 08:08:17am
I use the Mega pistons from Minispares, been quite reliable. The Oz hypertecs have slotted oil groves, which may not prove relaiable in a higher revving twinky engine. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
14th Jun, 2010 at 09:25:38am
On 14th Jun, 2010 wil_h said:
The Oz hypertecs have slotted oil groves, which may not prove relaiable in a higher revving twinky engine. The +0.080", +0.100" & +0.120" Oz pistons have oil holes. They are effectively the same as the Mega pistons, but half the price. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Jun, 2010 at 09:57:16am
Well that's better news then. why have they slotted the smaller ones I wonder? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
14th Jun, 2010 at 10:04:19am
Well that's better news then. why have they slotted the smaller ones I wonder? Don't know but the same has been asked about the 1275 ones - the "normal" +020,040,060 have slots and only the larger 73mm and 73.5mm have the "better" holes. Schrödinger's cat - so which one am I ??? |
14th Jun, 2010 at 05:30:05pm
I will have to figure out what oversize to go for, it seems as though the 80 thou is good but may need to have deeper cutouts for the valves, got a bit of calc and dry building before order them. |
14th Jun, 2010 at 06:15:37pm
I decided to go for +0.120" in the end.
14th Jun, 2010 at 07:46:24pm
alright paul, with the 120thou overbore how much wall thickness is between 2/3 cylinders?
14th Jun, 2010 at 09:02:58pm
On 14th Jun, 2010 pickmeup said:
alright paul, with the 120thou overbore how much wall thickness is between 2/3 cylinders? Can you also send me a copy of the cad file? cheers It's about 6mm from memory. In the end I instructed MED to offset each bore by 0.010". That's outers out and inners in. There's an article in the latest MiniMag about someone who put a K100 head on a 998 bored +0.080". They ended up modifying the crank and rods as they had to offset the bores so much to match the head. PM me your email address and I'll send over the CAD file of the bore spacing. I've decided not to finish my K100 build as there were too many issues. Now the Efi 5 port option is proven on boost, I felt that there was little point Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Jun, 2010 at 07:49:49pm
Thanks for the file mate, Ive copied it into catia and will start measuring up, after looking at the pistons i realised robh was selling a set! and luckily i won them on ebay, so all i need now is a crank, rods and jackshaft and i cant start doing the maths! :) |
145 Posts Member #: 4373 Advanced Member Yeovil, Somerset land |
20th Jun, 2010 at 11:44:24pm
Hey gaz, you finaly joining the 998 turbo gang......told you at imm 2008 that was the way to go......guessing for the pick up? ;o) Just starting to build mine for next year, liked the turbo way to much last year ;o) Tho mine isnt going to be 8v tho ;-( |
28th Jun, 2010 at 10:42:35am
hey mart, no its going in the marcos :) once its restored! got the maguire running so taking it to avon in a couple of weeks. |
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
28th Jun, 2010 at 11:15:34am
Edited by Cooper1999 on 28th Jun, 2010. |
29th Jun, 2010 at 07:06:13pm
alright mate, im using bowdens in bristol, propper little machine shop and hes ex rolls royce and a mini fan, i think he races in historics. |
13th May, 2011 at 12:10:10pm
nearly a year since ive done anything with this :( ive had a kick up the arse after looking at my mate nicks homemade K1100 engine, hes running it on honda carbs and a dizzy and it seems to run well.
13th May, 2011 at 12:25:49pm
Everyone is really busy, well anyone that's anygood that is!
13th May, 2011 at 08:58:07pm
yeah thats the plan, but if i can have a chat with them and get an idea of the money to do the machining i can buy a few of the other bits like the SC box and drop gears as well as spending the important time finding a suitable turbo |
14th May, 2011 at 07:32:27am
Turbo is easy, buy one and get it rebuilt. You can't take a risk on an engine like that, I know I wouldn't. There are plenty of scrappies by Craig and myself, if you want to come for a ride. I personally wouldn't bother with an sc box for the power your aiming at, drops maybe bit still not a requirement. People on here are running 200bhp plus with almost standard internals. Diff is the main thing. Save yourself money and get it on the road quicker... On 7th Nov, 2011 apbellamy said:
95 Posts Member #: 9314 Advanced Member Chippenham, Wilts |
14th May, 2011 at 09:49:17am
I recommend Brett for engine build (contact details below), he built Gooony's new engine. But like everyone else he's really busy right now
Edited by Ratty on 14th May, 2011. |
16th May, 2011 at 09:32:24am
alright ratty! good to hear from you, hows tricks?
Page: |
