Page: |
Home > Technical Chat > Crankcase evacuation systems? | |||||||
243 Posts Member #: 1261 Senior Member Droitwich |
5th May, 2010 at 11:33:21am
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
5th May, 2010 at 11:43:15am
I have been thinking of fitting one of these to mine, that kit looks like decent little kit! I could fit one to the tangerine and one to the cooper s! good find dan. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
5th May, 2010 at 11:45:52am
how.where would you fit it on ana A series? On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
5th May, 2010 at 11:51:50am
What ya mean? Easy, Plumb it to a breather tank? Edited by MikeRace on 5th May, 2010. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
5th May, 2010 at 11:56:02am
There is a topic somewere discussing this exact same subject, lol, do a search as im too lazy to find it On 26th Oct, 2004 TurboDave16v said:
5th May, 2010 at 12:02:26pm
I know, i asked what they did lol. Cant find it mind. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
509 Posts Member #: 1027 Post Whore Germini, black forrest |
5th May, 2010 at 12:05:32pm
This one? http://www.turbominis.co.uk/forums/index.php?p=vt&tid=336282 [X] nail here for new monitor |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
5th May, 2010 at 01:43:24pm
If anyone wants to share a kit like the one above with me, I,m on for it. |
5th May, 2010 at 03:01:19pm
6th May, 2010 at 10:51:32am
I bought one yesterday, got here mega quick, considering i didnt order it till about 4-5pm and its arrived this morning!
1183 Posts Member #: 6926 Post Whore Accrington |
6th May, 2010 at 01:38:30pm
so what does it do?
6th May, 2010 at 01:46:45pm
Yeah
6th May, 2010 at 02:31:39pm
awesome, i might buy a kit then and run one from my oil catch tank :) Cheers! |
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
6th May, 2010 at 02:37:39pm
Thats what I was thinking about. Wonder if this would work ok on a turbo motor?
On 6th May, 2010 Johnny said:
awesome, i might buy a kit then and run one from my oil catch tank :) Cheers! If something is worth doing, it's worth doing half of. |
6th May, 2010 at 02:40:57pm
quite a few modern cars have an electric vac pump. On 28th Aug, 2011 Kean said:
6th May, 2010 at 02:43:19pm
what would get in the way of it not working on a turbo? |
6th May, 2010 at 02:48:33pm
On 6th May, 2010 John said:
Thats what I was thinking about. Wonder if this would work ok on a turbo motor? On 6th May, 2010 Johnny said: awesome, i might buy a kit then and run one from my oil catch tank :) Cheers! I'll go halfs with you John boy. On 11th Feb, 2015 robert said:
6th May, 2010 at 02:53:36pm
ok ap, whats the plan then? do you want me to buy it then send you half of it? |
6th May, 2010 at 02:56:00pm
6th May, 2010 at 02:59:43pm
ah easy mistake |
6th May, 2010 at 05:39:38pm
There is no issue with using this system on a turbo, as long as the tapping on the exhaust is down stream of the turbo. The system works on the Venturi Effect, so even a little pressure in the exhaust, 2 or 3 psi shouldn't matter much as long as the exhaust gas velocity is reasonably high.
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
6th May, 2010 at 07:36:44pm
Im just in the middle of fitting this to mine system, haven't got the valve yet though. I believe Dave is using this on his A35. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th May, 2010 at 07:48:07pm
that's interesting,
On 6th May, 2010 Sprocket said:
There is no issue with using this system on a turbo, as long as the tapping on the exhaust is down stream of the turbo. The system works on the Venturi Effect, so even a little pressure in the exhaust, 2 or 3 psi shouldn't matter much as long as the exhaust gas velocity is reasonably high. Just using this exhaust evacuation system on its own will only work as you give the beans and unlikely to work at low throttle openings or idle. On 28th Aug, 2011 Kean said:
6th May, 2010 at 07:54:19pm
6th May, 2010 at 07:57:53pm
Page: |
