Page: |
Home > 998cc > 12g295 valve sizes. | |||||||
7th Feb, 2010 at 09:20:35pm
Hi all, a quick question can you fit 29mm exhaust valves into a 295 head and run on standard 998 (no overbore) without having to pocket the block?
7th Feb, 2010 at 09:30:13pm
No you cannot, but that doesn't matter, DON'T do it. The port wont flow that much, and you'll ruin the head. On 13th Jul, 2012 Ben H said:
7th Feb, 2010 at 10:01:49pm
so whats the largest you can run 26.5mm??
8th Feb, 2010 at 07:33:20am
On 7th Feb, 2010 gr4h4m said:
so whats the largest you can run 26.5mm?? I was thinking that when boosted a better exhaust flow would help get all those gasses out. Yes, but the valve size is not the restriction. The port and valve throat are. 26,5mm is a good choice, or even Paul Ivey 27mm. If these valve sizes aren't big enough for you, fit a 940 head. On 13th Jul, 2012 Ben H said:
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
8th Feb, 2010 at 09:30:23am
I have Grahams head here & it already has ex valves over 27mm fitted. But whoever fitted the unleaded inserts originally has cut them stupidly wide and the valve is sitting very low in the seat. The idea of fitting the 29mm valve was to allow the valve to sit up properly in the seat and so the seat could be radiused nicely into the throat. |
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
8th Feb, 2010 at 10:07:33am
I have 29mm exhaust valves, and 33mm inlets in one of my 12G295 heads:
Edited by Paul S on 8th Feb, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Feb, 2010 at 10:20:56am
Just measure the ex again & the appear to be 27.9mm. Maybe they were sunk into the head on purpose, to allow clearence from the block ? |
8th Feb, 2010 at 05:02:37pm
I'd fit new seats in that case. I REALLY don't like the 940 valves fitted in 295s. On 13th Jul, 2012 Ben H said:
8th Feb, 2010 at 09:27:50pm
morspeed strike again. I originally purchased this head as a fully recon'd 295 head. Looks like the jammed any valves in they had lying around... worst thing is the exhaust valves are actually inlet valves...
8th Feb, 2010 at 10:39:11pm
I've used A+ inlets ground down as exhausts. It depends on the quality of the valve.
520 Posts Member #: 2093 Post Whore Grenoble, France |
11th Feb, 2010 at 11:51:16am
I'm lost again.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Feb, 2010 at 01:48:44pm
The seats in the 295 wear like mad because of shit alloy. The cheapest way to fix this is to fit OS valves. The cheapest OS valves are 940 ones.
11th Feb, 2010 at 03:59:21pm
That's right. On both 295 I bought intake seats are 0.5mm below the initial level, while exhaust ones are just fine.
Edited by alpa on 11th Feb, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Feb, 2010 at 04:32:16pm
So which valves to use ?
11th Feb, 2010 at 07:01:45pm
On 11th Feb, 2010 alpa said:
So which valves to use ? Are C-AEG569 1.311" (33.3mm) the good ones ? This one is a big bore valve. Too long. Get these from Minispares: http://www.minispares.com/Product.aspx?ty=...367&title=VALVE EXHAUST 1.040 http://www.minispares.com/Product.aspx?ty=...781&title=INLET SMALLBORE rimflow 3... If these are too small Pual Ivey do some small bore race valves which are bigger, but I would consider seats before this. Very helpful guy, a On 13th Jul, 2012 Ben H said:
11th Feb, 2010 at 07:32:44pm
Paul Ivey still does 295 valves largest 33.3 inlet and 26.5 or .9 I can't remember but you can only send a cheque or postal order. They were a good price at about £11.00 each I think
11th Feb, 2010 at 07:33:31pm
oh the rim flow valves off of Paul direct are a fair bit cheaper. I run a supercharger and I don't care the TB is on the wrong side.
11th Feb, 2010 at 08:36:11pm
On 11th Feb, 2010 Vegard said:
http://www.minispares.com/Product.aspx?ty=...781&title=INLET SMALLBORE rimflow 3... If these are too small Pual Ivey do some small bore race valves which are bigger, but I would consider seats before this. Very helpful guy, a The SMALLBORE rimflow is just 0.9mm bigger than C-AEG588. On the other hand are you sure this sharp rimflow border won't create hot spots under 1bar boost ? std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
11th Feb, 2010 at 09:24:47pm
27 mm ex valve is OK but 29 will hit the block ???
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
11th Feb, 2010 at 10:29:31pm
I know I have them both in my hand and hey look very close... I run a supercharger and I don't care the TB is on the wrong side.
12th Feb, 2010 at 11:31:36am
On 11th Feb, 2010 Advantage said:
27 mm ex valve is OK but 29 will hit the block ??? that is just 1 mm on radius, is it that close ? As far as I know, a 27mm will also hit the block on a standard bore, but this is only if you skim the head rather much. The cambers are so deep on the 295 so it'll take loads of lift to hit the block. A 33,3mm inlet is not much use really as the valve size ratio should be retained. A 0.9mm bigger inlet is often what's needed to get a shitty valve seat decent. On 13th Jul, 2012 Ben H said:
12th Feb, 2010 at 12:25:34pm
Vegard, supercharged my head made very good power with 33.3 and 27.8 with a std cam. In fact I think this is why it was so good, (61ATW) as it shocked us at the time, however I didn't know the valve size then.
Edited by gr4h4m on 12th Feb, 2010. I run a supercharger and I don't care the TB is on the wrong side.
12th Feb, 2010 at 12:32:48pm
Well thinking about it I would have to get a pic of Turbo phils sister and well it on here to fund a new engine or block pocketing... :) I run a supercharger and I don't care the TB is on the wrong side.
12th Feb, 2010 at 01:04:54pm
You'll be lucky ! She's just a figment of everybody's imagination. Edited by Turbo Phil on 12th Feb, 2010. |
12th Feb, 2010 at 01:12:08pm
What about Phil in a Dress...
Page: |
