Page: |
Home > Show Us Yours! > My GT17 powered 998 | |||||||
392 Posts Member #: 5702 Senior Member Cornwall |
4th Feb, 2010 at 09:05:52pm
Well here is my mini which i bought as a 998 1986 mayfair with 6 months mot.
Edited by haimesyboi on 15th May, 2012. |
6274 Posts Member #: 509 Post Whore Isle of Man |
4th Feb, 2010 at 09:21:29pm
sounds like a neat basis bud, good luck "Turbo's make torque, and torque makes fun"
481 Posts Member #: 7893 Senior Member Portsmouth |
4th Feb, 2010 at 10:07:16pm
Not seen Sump and Clutch housing black before, looks great in black, Engine is looking pucka !
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
5th Feb, 2010 at 08:12:46am
Very good, you would have thought that the number of minis with that sort of body bodge would be small these days as they should have all rotted away. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
5th Feb, 2010 at 11:11:45am
On 5th Feb, 2010 apbellamy said:
Very good, you would have thought that the number of minis with that sort of body bodge would be small these days as they should have all rotted away. yes i thought i was playing safe buying a 86 with 30,000 on the clock and it looked solid because of the high quality bodging Looking back i wish i took a magnet with me. |
5th Feb, 2010 at 11:17:33am
Most of the rear of my mini was made of filler. Even the structural bits On 11th Feb, 2015 robert said:
5th Feb, 2010 at 11:31:37am
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
5th Feb, 2010 at 11:59:06am
Nice work!
22nd Feb, 2010 at 09:29:56pm
Some Progress :
68 Posts Member #: 7711 Advanced Member Beek, The netherlands |
23rd Feb, 2010 at 11:50:08am
From witch fiat is your radiator?
23rd Feb, 2010 at 07:47:27pm
Its from a cinqucento, i couldnt believe how light it was! |
26th Feb, 2010 at 10:56:33am
Did you modify your bulkhead where the header tank is (the triangle bit) or is it just the picture? |
27th Feb, 2010 at 07:05:51pm
No its bolted straight onto the inner wing brace, as high up as i could get it. |
99 Posts Member #: 8439 Advanced Member Romiley |
1st Mar, 2010 at 07:24:52pm
Any updates?
On 27th Apr, 2010 wolfie said:
and some chav will nick it to fit on there rat look saxo |
216 Posts Member #: 5647 Senior Member swindon wiltshire |
2nd Mar, 2010 at 10:13:43pm
ive got alot of tiem for home build projects ..espcially to this standard.. ive got a soft spot for a clubby aswell..what i wouldnt give for a garage haha |
7th Mar, 2010 at 04:23:03pm
Unfortunatly ive been stuck working on my daily recently so i havent been able to get much done. :(
15th Mar, 2010 at 10:50:26pm
Ive made the bracket to mount the intercooler to the rad just need to tie back to the brace bars.
16th Mar, 2010 at 01:38:33pm
Some more pics
16th Mar, 2010 at 04:49:35pm
that looks smart as, i absolutely love clubmans "Turbo's make torque, and torque makes fun"
17th Mar, 2010 at 10:10:50am
"you have a T2 mounted on a metro manifold.
17th Mar, 2010 at 01:00:44pm
Removed the rear valence, what a nightmare! One closing panel needs replacing but the other is fine
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
17th Mar, 2010 at 01:10:44pm
how about using a square plate, and locate it off to one side |
17th Mar, 2010 at 01:25:46pm
What about behind the rad? |
18th Mar, 2010 at 10:16:09am
Ive got the starter and alternator just behind the rad, it will fit at the front with a bit more trimming.
18th Mar, 2010 at 10:26:06am
Page: |
