Home > 998cc > fast n/a 998cc
makie1199
Member #: 7364
Hi everyone,
Just a quick question. this is the plan for my 998cc, first off i want to try fitting all of these parts to make a fast road 998cc n/a (i know n/a sucks) just want to try this first. if this doesnt work then im going to slap a great big monster turbo on it. right first off ill tell you the parts i want to fit.
1*competition valves
2*extra strong double valve springs
3*MED 1.5:1 roller rockers
4*forged crank wedged and bladed
5*adjustable belt drive
6*forged pistons
7*billet ultralight flywheel
mini already has stage 1 kit but might play around with the exhaust and carbs, dunno if twin carbs or bike carbs would be best.
just need some comments if this sound ok or not? i know your all turbo lovers but just want to mix it up a bit. any comments are welcome and would help me loads thanks guys.
Well, with that spec you may get 50hp.
Head, cam and carburation will determine what power you make, not fancy named gimmicks.
Get some books on the subject.
Also, we are getting over 100+hp from standard bottom ends and cast pistons.
Edited by Paul S on 24th Oct, 2009.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I voted!
I recently built a 998 with a Swiftune SW10 cam, 12G940 head and Weber DCD carb. Other than that it was bog standard. It was amazing fun and the best engine I've had in the car so far. The conception that you can't put a wild cam in a 998 is rubbish in my opinion.
I wouldn't bother with any of the fancy kit you have there though. The crank,forged pistons and belt drive are a bit excessive. Just get a nitrocarburised and reground crank and minispares mega pistons. What head casting are you intending on using?
On 30th Apr, 2010 Rod S said:
Gary's description is best
right, firstly none of any of the items you mentioned will actually improve power.
competition valves? in the std crappy head? waste of time, find a 12g295 and stick that on
extra strong double valve springs - why?
1.5 roller rockers - why?
forged crank - why?
adjustble belt drive - why?
forged pistons - why?
u/l f/wheel, yes ok, that might help acceleration a shade
how much power are you wanting? a single hif will be more than pretty much 99% of all na pp8s produce, so again - why?
have a good think, maybe read one of vizards books, it will save you a lot of wonga
Is your 9 key broke joey?
makie1199
Member #: 7364
WOW thanks guys i think i might be a bit over my head here. so all these fancy high costly parts dont really mean high power and speed? im going to get that book a.s.a.p. I will try and find a 12g295 and slap that on. i didnt think the single hif would be enough but if you think it will then why change it hay! cheers guys will bin all my last ideas and start from scratch ha ha
GaryOS
Member #: 2810
Dublin, Ireland
Nothing below piston crowns makes power *wink*
EDIT: Hopefully nobody noticed that :$
Edited by GaryOS on 24th Oct, 2009.
makie1199
Member #: 7364
so its all about the head really?
GaryOS
Member #: 2810
Dublin, Ireland
Head and cam, yes
makie1199
Member #: 7364
kent cams good?
makie1199
Member #: 7364
kent cams good?
makie1199
Member #: 7364
12g295 or 12g940 with kent cams and singlr hif carb should be a good mix for some fun?
GaryOS
Member #: 2810
Dublin, Ireland
Kent make alot of cams.
P.S. you only need one for an A-series
makie1199
Member #: 7364
garyOS can you get a sw10 cam for the 998 or can you only get it for the 1275?
the cams will fit 998 or 1275.
makie1199
Member #: 7364
cool and should i get the swift tune duplex set or mix and macth my own set up?
GaryOS
Member #: 2810
Dublin, Ireland
The swifty duplex kit is great. I bought it with my SW5 for the 1098 but it's not essential. You can just use offset keys with a non-adjustable setup to get the same results if you're on a budget
why bother? if you want to do it on a budget get a 1275, nice cam, mild head work and a single 44 manifolw exhaust system or somthing and this will give a good amount of power when setup, alot cheeper than a 998.
makie1199
Member #: 7364
i wanna stay 998 so if i enter it into a class i want it to stay in the lower class so 1275 is not what i want really. i just want a quick 998 road car that i can take to castle combe and stuff to have a good old laugh on the odd weekend.
bigmini998
Member #: 2830
Costa del Northern Ireland :)
My first engine was a 998 with a few mods Mg metro head with pocketed block Swiftune sw5 cam Minispares stage one kit. 11-1 compression ratio it was rebuilt with new bearings pistons etc and ran the original 1 1/2 inch su carb and airbox with k&n element filter it made 73 bannanas and 65 curlies. It was faster than most tuned 1275 minis but lacked the legs for most trackdays so it now it has a turbo, 110 bannanas and 87 curlies at 7psi all I did was lower the compression the rest of the engine is the same spec. But more boost is to come in the spring along with a new turbo to replace the huge old t3
That mini is determined to Kill me!!!!
makie1199
Member #: 7364
thats a good spec (with out turbo) thats wot im looking at trying to get. just got a 29g295 head and going to work that for a while then im doing the cams on the weekend and the tune up aftert that.
best_stig
Member #: 6449
Brisbane, Australia
Get a shorter final drive, will lower your top speed, but make it accelerate faster. And get it as light as possible.
Or put an k100 on it.
In boost we trust
makie1199
Member #: 7364
yeah final drive change would be a very good option didnt think about at all
makie1199
Member #: 7364
i have 13" depp dish wheels on my mini with miglia arches (wheels 175/50x13) has any one got any pics of this set up so i can see wot minimum height i can get out of these pleas?
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Nothing below the head makes power? Maybe not directly... Better bottom end means you can get more power out of it though. I don't know about the necessity of forged, but definitely having work done is worth it, if you're looking for high figures.
Users viewing this thread: none. (+ 2 Guests)   Next ->
