Page: |
Home > General Chat > Aluminium welding rod.. | |||||||
![]() 1060 Posts Member #: 588 Post Whore Delaware, USA |
18th Jan, 2009 at 03:12:15am
18th Jan, 2009 at 08:20:17am
this stuff?
Edited by Brett on 18th Jan, 2009. Yes i moved to the darkside |
18th Jan, 2009 at 09:16:51am
Nice one mate, will look out for it. Best 1/4 mile 13.2 seconds @116 mph
18th Jan, 2009 at 09:18:21am
surely if its melting at a lower temperature (especially by that much) then its not really going to be a very strong join?
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
18th Jan, 2009 at 09:33:52am
like brazing, just sticks to the surface |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
18th Jan, 2009 at 09:58:03am
there was a bloke at autosport selling this stuff, he demonstrated it to us. he welded 2 squares together with the stuff and you can see it penatrated well. i couldnent even break the weld with pliers, just broke the aluminum. he warmed a bit up on a sheet of alum and it actually burned a hole through.. amazing stuff. |
18th Jan, 2009 at 10:47:14am
My dad had some of this from a show in the summer, he rates it quite highly. I have tried to break the joint with pliers and the ally sheet breaks first! |
![]() 8215 Posts Member #: 90 Post Whore Somewhere around Swindon |
18th Jan, 2009 at 11:38:04am
frost sell it, it looks shit by the way as i have tried it Crystal Sound Audio said:
18th Jan, 2009 at 11:41:59am
I've used that stuff a few times before before with good results, great for repairing cracks in castings if you don't have access to a tig.
18th Jan, 2009 at 04:50:41pm
As said above its like brazing I guess, I wouldn't use it for stressed parts. Like a lot of people I saw these things being used to connect coke cans at car shows and didn't rate it but now I have used it I think it has some uses.. As I said above propane is only probably useful on very light alloy, (Coke cans!) for heavier stuff you need something hotter. Like all soldering/brazing the secret is to heat the piece until IT melts the rod, dont just melt the rod with the flame.
Edited by Turbo Tel on 18th Jan, 2009. website:- http://www.terryhunt.co.uk
18th Jan, 2009 at 04:53:59pm
On 18th Jan, 2009 Turbo Tel said:
As said above its like brazing I guess, I wouldn't use it for stressed parts. Like a lot of people I saw these things being used to connect coke cans at car shows and didn't rate it but now I have used it I think it has some uses.. As I said above propane is only probably useful on very light alloy, (Coke cans!) for heavier stuff you need something hotter. Like all soldering/brazing the secret is to heat the piece until IT melts the rod, dont just melt the rod with the flame. Here was my first attempts, not bad.. but I must say better than my first MIG experiments.. ![]() thats quite tastey actually .. how much finishing was involved or did they flow that clean? turbo 16v k-series 11.9@118.9 :)
18th Jan, 2009 at 05:04:30pm
2490 Posts Member #: 1954 Post Whore Luton Bedfordshire |
18th Jan, 2009 at 06:41:35pm
That sounds more like soldering! Brazing and welding require you to localy liquify the parent metals before adding a third to join the two together.
Own the day
18th Jan, 2009 at 06:46:19pm
On 18th Jan, 2009 Mr Joshua said:
That sounds more like soldering! Brazing and welding require you to localy liquify the parent metals before adding a third to join the two together. Not good for anything other than light pipe work I would imagine though I am usually wrong. You dont melt the parent metal to braize, you just get it red hot Paul I seriously doubt it! |
18th Jan, 2009 at 06:46:58pm
Brazing does not liquiefy the parent metal.
18th Jan, 2009 at 06:57:29pm
Oxy acetylene tourch in one hand brazing rod in the other looking for the eutectic point and quickly feeding the rod into the moulten pool working ones way along the joint.
Own the day
18th Jan, 2009 at 08:43:03pm
very tide indeed! Tel, nice one! Best 1/4 mile 13.2 seconds @116 mph
18th Jan, 2009 at 09:37:27pm
the moulten pool Of which material are you thinking? parent metal or filler material Paul I seriously doubt it! |
18th Jan, 2009 at 09:42:39pm
Oxy acetylene tourch in one hand brazing rod in the other looking for the eutectic point and quickly feeding the rod into the moulten pool working ones way along the joint. My explanation earlier may have been overly simplified. Except for the brazing rod, what you describe sounds like oxy-acetylene welding (which would require a welding rod). Parent metal would not be melted in brazing. Jean Edited by jbelanger on 18th Jan, 2009. |
18th Jan, 2009 at 11:12:48pm
Oxy acetylene tourch in one hand brazing rod in the other looking for the eutectic point and quickly feeding the rod into the moulten pool working ones way along the joint. My explanation earlier may have been overly simplified. Except for the brazing rod, what you describe sounds like oxy-acetylene welding (which would require a welding rod). Parent metal would not be melted in brazing. Jean Well the last time I did either was back in 91 so like I said sometimes I do get it wrong. Own the day
18th Jan, 2009 at 11:54:49pm
To braze you just heat the joint til its red then add the rod, it should just flow itself then
25th Jan, 2009 at 06:12:47pm
If I was looking to re-join an alloy grill (clubman style) that I had chopped up. Would this be OK with a crappy gas torch?
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
25th Jan, 2009 at 09:28:15pm
i would say this would be perfect!
25th Jan, 2009 at 09:35:26pm
i've used this. its good! |
25th Jan, 2009 at 09:46:27pm
Page: |
