Page: |
Home > Technical Chat > VEs AFRs and Widebands | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
7th Dec, 2008 at 12:53:48pm
I'm puzzled by the data from the dual wideband trials on my engine.
7th Dec, 2008 at 12:58:01pm
remember to fully read the questions before answering, and do the easy ones first to build up confidence.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
7th Dec, 2008 at 01:03:19pm
Give me a few more hours and I may have an initial reading....
Edited by Rod S on 7th Dec, 2008. Schrödinger's cat - so which one am I ??? |
7th Dec, 2008 at 01:28:15pm
gotta mind that fuel is heavier than air, so if it isnt atomised amasingly well, it will be harder for it to change direction than the air, resulting in different afr's / cylinder, which your question assumes doesnt change :) turbo 16v k-series 11.9@118.9 :)
7th Dec, 2008 at 01:30:41pm
On 7th Dec, 2008 evolotion said:
gotta mind that fuel is heavier than air, so if it isnt atomised amasingly well, it will be harder for it to change direction than the air, resulting in different afr's / cylinder, which your question assumes doesnt change :) That is part of Round 3 ![]() Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Dec, 2008 at 03:00:46pm
7th Dec, 2008 at 03:16:49pm
On 7th Dec, 2008 Bat said:
Has there been a conclusion on whether inner and outer do have different VEs or is it due to wall wetting or some other witchcraft? Cheers, Gavin :) Definately witchcraft. Thanks for the proper answers Gavin. I'm not sure that you are correct about 3. But then you might be. I'm about to cut a fresh head with bigger valves on the inner cylinders to test that it is the VE and not something else. Let's have some more real answers, then we can start Round 2 ![]() Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Dec, 2008 at 04:35:30pm
Q1 lambda will be in or around 14:1 depending on load,air density ect
On 17th Feb, 2009 Rob H said:
7th Dec, 2008 at 04:53:03pm
Q3 - is that not basically EGR. so on modern engines that utalise EGR for better emmissions EGR would surely creater a leaner burn, as there will be less oxygen in the cylinder compared to a completely scavanged/fresh charge.
7th Dec, 2008 at 04:54:59pm
Hi
7th Dec, 2008 at 05:58:09pm
I agree with Gavin that it will all show stoic. However as James_H mentions, Q3 is similar to EGR but your question mentions that the cylinder is fed with a stoic mixture. If it instead said that it was fed with fuel corresponding to stoic for a 90% VE air volume then is would be richer than stoic.
7th Dec, 2008 at 06:03:07pm
I'm thinking carburetor for Round 1, rather than injection. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Dec, 2008 at 06:42:29pm
Well I just got mine to start on a carb (and dizzy)....
8th Dec, 2008 at 09:52:42am
So, do we conclude that the answer is 14.7:1 for all three?
8th Dec, 2008 at 11:34:18am
Ok,
8th Dec, 2008 at 11:43:47am
On 8th Dec, 2008 mini13 said:
Ok, assuming the inner and outer cylinders have a different VE they will have different compression ratios giving different burn characteristics. I did not think that the CR would affect the wideband reading, but a good point to consider. On 8th Dec, 2008 mini13 said:
I don't thing the different afrs between the centre and outer pairs are due to mixture distribution, as the outers are the leaner ones, which seems backwards to me. I can see the logic that the fuel will be pushed to the outer cylinders in the manifold bend. However, I think that it is a little more complex. As the fuel is pushed to the outside of the bend, it gains velocity. So in the bend, the air is travelling slower than the fuel. At the exit of the bend the fuel is still travelling faster than the air. The only way it can do this is to flow in a spiral pattern. So the air moves down the centre of the port and the fuel spirals around the outside. So instead of a straight laminar flow in the port, it is actually spiralling and could favour either inlet valve. On 8th Dec, 2008 mini13 said:
say it is a VE issue could it be down to the siamesed ex ports? I dont think so with the full 360 degree phasing. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Dec, 2008 at 02:19:54pm
CR will effect your ignition timing and obviously BMEP but not your AFRs. AlexF |
8th Dec, 2008 at 06:00:38pm
While ignition timing will not affect AFR it may affect the reading from a wideband O2 sensor. I'm not entirely clear on why that is but I assume it has to do with the sensor position and how much of the combustion happens in the exhaust.
8th Dec, 2008 at 07:34:55pm
On 8th Dec, 2008 jbelanger said:
So with the upcoming siamese code able to fuel cylinders independently, I'm intruiged as to how you are going to do this with just the two injector drivers, but I can't wait to resume testing. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Dec, 2008 at 07:46:36pm
with a lower VE on the inner two cylinders would you tend to get a less effective scavange? so more exhaust gass left in the cylinder after the exhaust stroke?
8th Dec, 2008 at 07:47:53pm
Me too, well start testing, not "resume", but I think I understand what Jean is trying to do for us.
8th Dec, 2008 at 08:14:20pm
On 8th Dec, 2008 James_H said:
with a lower VE on the inner two cylinders would you tend to get a less effective scavange? so more exhaust gass left in the cylinder after the exhaust stroke? There are two possible causes of a low VE. Firstly, poor scavenging of the exhaust gases. Secondly, even with good scavenging, the air cannot get into the cylinder. On 8th Dec, 2008 James_H said:
if you would then this could cause the inner cylinder to run richer as the exhaust gasses would contaminate the fresh charge. meaning that less oxgen is in the mixture so the feul isnt being used effectivly so giving you a richer mixture? I don't think so because you are taking in the correct proportion of air and fuel. On 8th Dec, 2008 James_H said:
do you have EGT readings? or cylinder temps? EGT reading would be abit hard i suppose because of the siamesed center cylinders...uhmm if the cylinders run a reasonable amount cooler could you assume that there is EGR taking place in the cylinder? I'm logging EGTs & CHTs, but the results do not make much sense with the AFRs so far apart. I don't think that the centre cylinders will run hotter because of the siamesed port. There may be twice as much heat passing through the port but it is at the same temperature. On 8th Dec, 2008 James_H said:
uhmm just thinking about this abit further..as its carb readings the mixture is already set by the carb by the time its in the inlet manifold. so theoretically EGR isnt going to make any difference as the exhaust gasses will be taking place of MIXTURE rather just air. Correct. On 8th Dec, 2008 James_H said:
this would point to the fact that your correct and this is down to mixture distribution. Thank you. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Dec, 2008 at 09:27:18pm
so all in one post i taught myself what you were thinkin! :S not bad going! hahah! |
8th Dec, 2008 at 10:17:34pm
So with the upcoming siamese code able to fuel cylinders independently, I'm intruiged as to how you are going to do this with just the two injector drivers, but I can't wait to resume testing. The injectors will not be wired the same way and you lose staging (but I have a solution). You have one injector in the first port on one driver (cylinders 1 and 2) and one injector on the other port on the second driver (cylinders 3 and 4). Then even if you fire both ports at the same time in the semi-sequential manner, using the cam sensor, you know which cylinders you're fueling: 1 and 3 in one engine rev and 4 and 2 in the other engine rev. When you fire 1 and 3, the first driver will have a longer pulse than the second driver, and when you fire 4 and 2, the second driver will have the longer pulse. Now the solution to get back staging is to have 4 drivers. This will be done by making a small modification to the MS2 card to wire the CPU pins used for PWM to unused pins on the card. It will also require the addition of 2 more injector driver circuits. And of course, it will need the code to do it. The drawback will be the loss of PWM so low impedance injectors will require some specific drivers. Fortunately, I already have a board that has 4 injector drivers that are made for such a purpose: see here. I you have high impedance injectors then using 4 simple TO-220 drivers such as the VNP5N07 will suffice (see here). I won't have the code for the 4 injector drivers in the first upcoming release but it should not take too long to have it. It shouldn't be needed for the first tests anyway because I don't think you'll be using staging right from the start. When I have the code for the 4 drivers, I'll post pictures showing the needed modifications and wiring. Jean |
9th Dec, 2008 at 10:39:20am
Exxxcerlunt Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
