Page: |
Home > A-Series EFI / Injection > Wideband controllers | |||||||
5th Nov, 2008 at 03:22:26pm
I have an Innovate LC-1 (as yet untested) that I bought (imported from the USA) when I bought the Megasquirt.
5th Nov, 2008 at 03:37:49pm
hmmm,
1849 Posts Member #: 672 The oversills police Oslo, Norway |
5th Nov, 2008 at 03:38:30pm
when I did some research back in the day techedge was supposed to be better then the inovate stuff, but this is 2-3 years ago. |
5th Nov, 2008 at 03:38:47pm
When I faced the same dilemma, I bought an LM-1 and AuxBox in addition to the LC-1.
Edited by Paul S on 5th Nov, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5th Nov, 2008 at 04:03:18pm
Hmmm, hadn't thought to look at the handheld devices (LM-2) but it's pricey even for a single channel.
5th Nov, 2008 at 04:19:07pm
fAIR COMMENT ABOUT THE WIRING OOPS CAPS.....
5th Nov, 2008 at 04:46:05pm
This thread details my setup.
1745 Posts Member #: 375 Post Whore Leicestershire |
5th Nov, 2008 at 05:43:47pm
I have been using a techedge kit for about 3 years with heavy use this year and its still going strong! It is a diy 2ao that i think is no longer available. But if the other kits are of the same quality then they will be good! I lso have a lc1 that has been sent back for repair!!
5th Nov, 2008 at 07:21:48pm
If I was doing this again, I would seriously consider buying a couple of TechEdge 2Y DIY kits and sensors and then eanbling the second wideband input on the Megasquirt.
520 Posts Member #: 2093 Post Whore Grenoble, France |
5th Nov, 2008 at 07:43:59pm
I have the old TechEdge one channel kit with digital square screen. Works well, an open architecture that you can use in DIY projects. Good stuff. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
1425 Posts Member #: 690 Post Whore Norfolk |
5th Nov, 2008 at 08:45:33pm
If you fancy a go with one (cheap enough)- go to Trigger Wheels.com - they are UK importers of them
If Carling made Mini engines
5th Nov, 2008 at 08:51:43pm
Yes JK, I've seen that triggerwheels dot whatever are the TechEdge "approved" supplier in the UK but their mark-up is a little high considering the current AUS$ exchange rate. Also the dual channel one is "special order".....
6th Nov, 2008 at 09:48:25am
One for Paul......
6th Nov, 2008 at 10:10:35am
Rod,
6th Nov, 2008 at 10:25:58am
On 6th Nov, 2008 Paul S said:
I also have a TC-4 in the daisy chain to log 2xEGTs and 2XCHTs.. Even more bits !!! On 6th Nov, 2008 Paul S said:
I was referring to logging through MS. Understood, but I think I would rather do the logging through "LogWorks" (although obviously TechEdge's equivilant) rather than MS anyway. On 6th Nov, 2008 Paul S said:
I am not sure if you can daisy chain two TechEdge units. Yes, you're right - after my previous post I started reading the TechEdge manual in more detail and it certainly looks like that is a significant limitation. When I've finished reading I'm going to email them to see if there is a way around it but, even so, with a 1Meg chip added they can store up to a hour's data to download later. Schrödinger's cat - so which one am I ??? |
6th Nov, 2008 at 10:32:16am
Logging to read later is OK but you want a live display to help with setup. Preferably a rolling display so that you can see the effect of changes.
6th Nov, 2008 at 10:44:51am
We think alike.... before reading your post, I managed to download it (it's called TEWBLOG) and I managed to get two seperate windows running...
Edited by Rod S on 6th Nov, 2008. Schrödinger's cat - so which one am I ??? |
9th Nov, 2008 at 08:33:08am
Well, I got my second USB/serial cable, couldn't get it to work on the laptop but it was fine on my desktop.
9th Nov, 2008 at 09:58:14am
Good work Rod.
9th Nov, 2008 at 05:12:35pm
I bought the TechEdge direct from them despite the european agent, that was much cheaper. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
9th Nov, 2008 at 05:48:21pm
Oh well,
3692 Posts Member #: 1833 Formally mini_majic Auckland, New Zealand |
9th Nov, 2008 at 06:37:01pm
do you want to put some money on it for me? because i just calculated mt engine build costs and i feel i am going to need either a better job or someone elses credit card!! Edited by James_H on 9th Nov, 2008. |
10th Nov, 2008 at 11:40:35am
o/t a bit but spotted this last night.
10th Nov, 2008 at 01:29:31pm
Interesting but quite pricey for one chip and 5 SM resistors/capacitors. It will obviously only handle one TC as well and I've used up all my spare inputs/outputs on the MS....
Edited by Rod S on 10th Nov, 2008. Schrödinger's cat - so which one am I ??? |
10th Nov, 2008 at 03:42:19pm
On 9th Nov, 2008 Rod S said:
After a few beers/wine/whisky to justify it, I just put AU$ 699.30 on my credit card... That's about £300 isn't it? Bargain. I spent about £800 on Innovate kit Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
