Home > Show Us Yours! > My K100 Build
Picked up my 850 crank frm MED this morning.
Wedged, re-ground, nitro-carbusrised etc.
Only took them 3 weeks and it looks good workmanship, so I've given them the con-rods to lighten etc.
ill be using MED i think
although i am not in any rush have not even stripped this yet
[/quote]
go on then , how much did they relieve you in £££ for that . was it exchange.
carl
Nosey Bugger - £150 and it was my crank.
MadMatt
Member #: 105
Brisbane ,Australia
Wolfie,,, i just love that pic *smiley* Now that should be the opening page pic for a Bimmer Twinky forum for sure *smiley*
Maybe would be better pic with it stuffed into the back of a mini van but still, dam good *smiley*
Edited by MadMatt on 25th Jan, 2008.
www.miniman.com.au
lol,
it looks abit like the lights still on on the bike.
Theres a guy who works for us who owns one of those bikes, i might nick it! *wink*
Star Mag
Member #: 375
Leicestershire
How did you find Meds customer service, when trying to ask questions etc?
I get on OK, but i can imagine that they do not suffer fools gladly.
I measured the combustion chambers this afternoon on the K100 8v head.
They came out at 21cc.
That's good news as I only have to take 2.5mm of the block deck to get 10:1 with the 0.6mm gasket. If I change the gasket to the 1.6mm one, I then get 9:1, so easy to try diffrent CRs.
Also no valve pockets if I re-profile the cams.
Edited by Paul S on 7th Feb, 2008.
miniboo
Member #: 2253
Las Vegas, Brit in the States
so you are keeping it NA for now?
what are you looking to reprofile the cams to?
Edited by miniboo on 9th Feb, 2008.
NA to start with, then turbo.
I'm going get Piper to reprofile the cams to around 260 degrees duration and set them at 110-112 degrees LSA.
miniboo
Member #: 2253
i take it that is still enough oomph for NA?
just thinking about my build and whether it could be worth me doing it aswell
Depends what you are aiming for.
I'm looking for 60mpg.
miniboo
Member #: 2253
well i will be using mine as a cruiser so maybe i should look into it more.
60 mpg is what i was thinking about aswell after reading your thread!!
Latest aquisition:
Lightened, balanced and shot-peened rods. Hopefully good for 8000rpm.
Feels like a cheque book build at the moment.
sturgeo
Member #: 1778
Northants
where did they come from?
Came in the post this morning from MED.
Glad to here you got to work OK this morning. I told you there was nothing wrong with it.
Pistons from Minisport Aus:
They are 998 +0.120", so a lot bigger than the standard piston. The piston and pin weigh around 300 gram which is OK considering the size. About 25 gram heavier than the original P20950.
They have 9.5mm from the top down to the first ring which is supposed to be beneficial for a turbo application.
This is a comparison with standard pistons.
Edited by Paul S on 25th Mar, 2008.
TurboDave16V
That looks pretty good!
Can we have a piccie of the underside?
Underside:
I was worried that they may have made them larger on the outside and kept the standard inside dimensions which would have made a heavy piston. However the skirts are same thickness as standard.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
nice! but whats the pistons in the background?
Minisport Aus version of a 1293 piston. There is another post somewhere with a better picture.
Started the dry decking today.
Milled a couple of millimeters off the deck to start with. It will need a bit more to get the deck height right for the 850 crank and 10:1 compression.
Left the engine number boss at normal height for reference purposes.
Had to turn it round to mill the whole length. Working at the limits of my Chester lathe/mill here.
I can just get colletts and cutters in and out without moving the head or workpiece, so using the SC template should be a doddle. That is once I've relocated the 3 studs that normally stay in place.
Opened up the push rod holes ready for tapping 3/8" BSPT.
Using these taper threaded iron plugs to block the holes.
Edited by Paul S on 21st Apr, 2008.
Cool, where did you get the plugs from? also I assume that you're going to get a machine shop to do a final pass on the block with a fly cutter.
Users viewing this thread: none. (+ 4 Guests)   Next ->
