Home > General Chat > Janspeed Turbo
Soton1310Turbo
Member #: 265
Southampton
I can't remeber who's got the Janspeed turbo but here's a quick question
Where does the oil drain to?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Turbophil has it...
I bet it goes to the sump!
alex
AlexF
minster
Member #: 198
The oil drain runs round the back of the block and into the old petrol pump outlet, same as the metro turbo. The bracket also mounts the clutch slave cylinder, there are pictures of it on here somewhere, cant remember where though
Yep that's right !
Phil. *smiley*
Soton1310Turbo
Member #: 265
Southampton
cheers
I wasn't sure if it drained to some other location
JC T ONE
Member #: 2974
Yes its right that the oil went back in the engine trough the petrol pump bracket on some JANSPEED A series TURBO engines, but look in the Vizard book, there is a pic where you can see a breather connected to this, on this version the oil went back trough the breather hole in the transfer gear house.
JC T ONE
Member #: 2974
Heres another, but if you see the Vizard book they made different setups of this, on one of the engines in the book it draines back through the clutch housing vent.
rob620
Member #: 10537
Im looking to make up a manfiold abit like the janspeed turbo conversion to mount my gt17 turbo on. Has anyone done this? Im struggling to see how I can mount it with the brake master cylinder and servo and also the clutch slave cylinder, ive found a decent place for the turbo to sit but worried about the pipework making it all too hot ?.
have a look through this link,
I reckon with a verto setup it could work easier if the turbo was a bit higher.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=327942
I think if you have a servo this setup is a no go area. You could move to a front mount rad and have it over the other side.
ah didnt see the bit about servo,
deffo not going to happen.
rob620
Member #: 10537
Gutted :( do you not think it would be possible if wrapped the exhaust piping and mounted some heart gaurds round the servo and slave cylinder? Really did think I was onto something thst would save fitting it tight agaist the bulkhead :( how hard is it to fit a front mounted radiator? Surely the dizzy and starter get in the way?
theres next to bugger all room with the servo,
best thing would to be converting to non servo, or remote servo in the foot well.
rob620
Member #: 10537
Just looked ito getting rid of the servo but it seems I would need to change the pedal box to accomedate :( im guessing fitting a remote servo isnt straight forward either, ivwme figures a place for the turbo sit but worried about the heat from the piping heating the servo.. though im not sure how much heat would actually be effecting the servo?
Any excess heat in the brake fluid is a no-no as you'll end up with a much higher chance of fluid boiling and brake fade
rob620
Member #: 10537
Yh I was thinking the exact same thing, I was more thinking how much heat would actually get to the servo and cylinders to effect them if I fitted heat shields and wrapped the exhaust piping? Thanks
Tupers
Member #: 9441
South Devon
Fitting a remote servo really isn't that hard.
If you can mange to make a remote manifold you should be able to relocate a servo easily.
Rammie2000
Member #: 10190
belgium
I am making one like that. Stuck the turbo halfway into the side wing only to realise its still to close to the servo. So now i am looking into removing it.
rob620
Member #: 10537
Ok thanks guys. Is there any how to guids on how to fit a remote servo? Could do with some more reading before going any further down this route, if its too much hassel it might be easier at seeing how people fit it down the back of the engine under the carb...
It's a lot simpler to fit it down the back.
Every time we work on wintersurfers car we end up swearing at it and saying "should've got a Mirage/Matty manifold".
If you're able to fabricate parts yourself or are able to get bits made, give it a go. If not, use off the shelf stuff to keep it simple.
Rammie2000
Member #: 10190
belgium
Second on that. Took me about 4 hours to make a downpipe that more or les fits... still not happy with it. And then there is the other problems tgat come up like the exhaust getting in the way of engine mounts.
rob620
Member #: 10537
Ok getting some good advice now :) ive stripped the manifolds off my 998 ready to take the engine out so was having about of a play trying to get the turbo to fit down the back of the engine. I cant see how its done though, it seems so tight back there? Ive heard of people rotating the cold side turbine housing, but then id have to find a way to remount the actuator?
Rammie2000
Member #: 10190
belgium
Im far from a specialist but You can turn the cold and hot side so oil waste is still on the lowest side. ( maybe someone can explain better) i have cut of the fixing on the housing and made a new one for it.
You will need to rotate (clock) the housings to get it working.
This will result in having to make a new actuator bracket, which isn't too difficult.
Make sure oil feed it at the top and drain points down. Then get the exhaust and compressor housings where you want them.
There's lots of pics on here showing examples of how others have done it. Look at my build, Roberts, etc.
What turbo you got? A T2 should fit but anything bigger requires modifications to the bulkhead
