Page: |
Home > General Chat > Carl Austin's Twin Engined Nitrous Mini | |||||||
24th Jun, 2004 at 01:18:40pm
I've got a few pics uploaded, but am only going to post one of them - such is the time to uplad that 56K people may get annoyed!!! On 17th Nov, 2014 Tom Fenton said:
24th Jun, 2004 at 01:27:40pm
I think I'd make the exhaust pipes a bit longer if I had no windscreen! nutter
24th Jun, 2004 at 02:12:19pm
anyone got a tissue? On 20th Oct, 2015 Tom Fenton said:
24th Jun, 2004 at 02:15:21pm
I think he normally does run a screen!
AlexF |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
24th Jun, 2004 at 03:43:17pm
the no screen was a management decision!!! Everyone knows that instructions only have to be read if the thing doesn't work....
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
24th Jun, 2004 at 03:53:13pm
Has Carl, ever done a comparison run, with the air dam off the car, I cant imagine downforce is important and it would certainly affect Cd ???
Edited by PaulM on 24th Jun, 2004. 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
24th Jun, 2004 at 03:57:05pm
Hmmm.
24th Jun, 2004 at 03:58:31pm
screen out helps CD?
AlexF |
24th Jun, 2004 at 04:02:15pm
might as aswell keep the pic , dave , cos it ain`t gonna look that next time out. Everyone knows that instructions only have to be read if the thing doesn't work....
24th Jun, 2004 at 04:14:49pm
So what planned then?
AlexF |
24th Jun, 2004 at 04:21:52pm
if carl wants to tell people what he`s planning , i`m certain he`ll post it on MC , but i would be rude of me to post on here what he planning before he tells people , don`t think its any big secert , just not my place to talk about other peoples plans. if u understand. Everyone knows that instructions only have to be read if the thing doesn't work....
![]() 8215 Posts Member #: 90 Post Whore Somewhere around Swindon |
24th Jun, 2004 at 05:01:58pm
hairy muff Crystal Sound Audio said:
24th Jun, 2004 at 07:20:05pm
Hell, what a machine! Just look at the seat for hells sake !!!!!!!!!!!!!!!!!!!!!! :o Best 1/4 mile 13.2 seconds @116 mph
24th Jun, 2004 at 10:42:32pm
Alex, cos if theres no glass to form a frontal area, (ie the air goes straight through), then it aint going to go into a frontal area caculation 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
24th Jun, 2004 at 10:44:28pm
Dave,
25th Jun, 2004 at 08:34:14am
What the f**k ever...
Edited by TurboDave16V on 25th Jun, 2004. On 17th Nov, 2014 Tom Fenton said:
25th Jun, 2004 at 09:39:04am
Thats why I asked the question in the first place! 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
25th Jun, 2004 at 10:05:05am
Mark, all I ment was you know all the goings on!! Almost a gossip king, but you dont goppsih, just know the scene :)
AlexF |
25th Jun, 2004 at 12:03:52pm
That why I asked the question alex, as a comparison run would give an indication of effect. Did my bit on fluid mechanics at uni. all of 15 years ago, so dont remember didly squat :) 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
![]() 105 Posts Member #: 133 Advanced Member Jamaica |
25th Jun, 2004 at 04:24:31pm
GOOD GOD!! 'I swear to use the Boost, The whole Boost'
25th Jun, 2004 at 11:04:39pm
12. something , no gas , 2nd gear one engine start 0/60ft 1.59 !!!!!!!!!!!!!!!11 Everyone knows that instructions only have to be read if the thing doesn't work....
![]() 1750 Posts Member #: 10190 Post Whore belgium |
26th Aug, 2015 at 08:37:42pm
in my intrest in twin engined cars and not wanting to start a new tread on this i do a smaal hack on this one. i was wondering... im always been said power output on both engine's needs to be equal but in fact does it? the les stronger engine gets helped by the stronger engin right? or vice versa... the stronger engine needs to take some more of the work... i do mean with 2 engines seperated each driving an axle. you can do anything if you set your mind to it...
26th Aug, 2015 at 09:29:08pm
AWD cars don't always have a 50-50 torque split between front and rear so why would you need it with 2 engines? Edited by jbelanger on 26th Aug, 2015. |
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
26th Aug, 2015 at 09:54:43pm
On 26th Aug, 2015 Rammie2000 said: True. There are also a few hybrid cars around now that drive one set of wheels with the main engine and the other axle with a much smaller electric motor for a boost.
the les stronger engine gets helped by the stronger engin right? Not so relevant for a drag car, but if both axles are driven with significant power and each engine has different torque curves, then it would make the car unpredictable in the corners. If the torque split is a constant ratio (or closely controlled by an ECU) then this is fine, but much trickier to do with two unconnected engines. Edited by PhilR on 26th Aug, 2015. |
27th Aug, 2015 at 09:04:31pm
a yes. like the back end would like to pull faster then the front end or vice versa. so nothing to do with a road car you can do anything if you set your mind to it...
Page: |
