Page: |
Home > FAQ / Knowledge > Maximum Compression Ratio | |||||||
20th Nov, 2006 at 02:27:09pm
Every week there is a question about compresion ratio.
Edited by Paul S on 21st Nov, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
807 Posts Member #: 224 Post Whore Katy TEXAS |
20th Nov, 2006 at 02:32:03pm
Well done that man
Edited by Brocky on 20th Nov, 2006. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
20th Nov, 2006 at 02:35:27pm
Edited to clarify octane.
Edited by Paul S on 20th Nov, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Nov, 2006 at 02:50:44pm
Great stuff. I can't comment on the accuracy, but it looks pretty realistic for 95RON assuming all other things are equal.
20th Nov, 2006 at 02:54:17pm
Could you produce it in 3-D and add in the effect of octane level ?
20th Nov, 2006 at 02:56:31pm
On 20th of Nov, 2006 at 02:54pm Brocky said:
Could you produce it in 3-D and add in the effect of octane level ? I think that would look cool as... Cheers Brocky Dito about putting your name on it Yes, but I have work to do! Do you have the data??? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Nov, 2006 at 03:07:30pm
In short no...
20th Nov, 2006 at 03:37:42pm
As far as intercooler efficiency is concerned, it would be pointless stating a value as no one ever measures it.
20th Nov, 2006 at 04:25:43pm
is it me being thick or does that chart show that on hot days with the same comp ratio you can actually run more boost?! |
20th Nov, 2006 at 04:28:36pm
The degrees is for the cam inlet opening angle ...
Forum Mod 4828 Posts Member #: 154 Post Whore Midlands |
20th Nov, 2006 at 04:46:51pm
so does anyone know the inlet opening angle for the phase 2 cam then?
20th Nov, 2006 at 04:50:52pm
It's actually 62deg for the phase 2.
20th Nov, 2006 at 04:52:39pm
You should see if nice uncle Axel will plot it on his graph for you ! BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
20th Nov, 2006 at 04:59:50pm
HA HA i was just going to ask for 60 degree's. On 28th Aug, 2011 Kean said:
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
20th Nov, 2006 at 10:02:41pm
Very useful! good work |
6745 Posts Member #: 828 Post Whore uranus |
20th Nov, 2006 at 10:26:05pm
axel where did the data for this come from? ,also how many data inputs did you have ?
6274 Posts Member #: 509 Post Whore Isle of Man |
20th Nov, 2006 at 10:51:05pm
so...........ill need about 5:1 then.....LOL
21st Nov, 2006 at 06:33:45am
So how does the RON affect it? Obviously all the lines will move up, but by how much. I use 101RON
Edited by wil_h on 21st Nov, 2006. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
21st Nov, 2006 at 09:15:25am
On 20th of Nov, 2006 at 10:26pm robert said:
axel where did the data for this come from? ,also how many data inputs did you have ? nice idea this well done regards robert. The data came from about 3 well sorted cars on this site. I started to try and be very scientific and work out the pressure/temperature at combustion etc but it all fell apart when I realised that detonation ocurrs after ignition. Because you retard ignition with boost it is then very difficult to calculate. I then look at the data I had and fed it into one of these web based dynamic compression ratio calculators. The answers all came out at about 15.0 to 15.5. We therefore had a trend, although it only seemed to work above 10 psi. Maximum comp ratios for N/A are well documented. Then I used the dynamic compression ratio calculator for above 10 psi for a range of boost and inlet closing angles to achieve approx 15.25:1. The idea is that if anyone feels that it should be shifted around, let me know. I will add that it is conservative. The last thing we want is someone destroying their engine because of this. Edited by Paul S on 21st Nov, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Nov, 2006 at 09:20:31am
On 21st of Nov, 2006 at 06:33am wil_h said:
So how does the RON affect it? Obviously all the lines will move up, but by how much. I use 101RON As an example, I run 8.3:1 and 15psi with an MG cam (I have easy run 18psi with the T3). that graph puts me at my limit, but I'd be interested to know how 'safe' I am. On the basis that hoggy ran 12psi on pump gas on 9.4:1, you could go a ratio higher, but i would not advise it for a car running WOT for sustained periods. As the inlet temp rises the closer you get to detonation. Ok for a road car and short bursts but not a race car. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Nov, 2006 at 09:23:35am
On 20th of Nov, 2006 at 10:51pm joeybaby83 said:
so...........ill need about 5:1 then.....LOL Great idea, takes alot of the guess work out. Now, all we need is some handy so and so to post up a list of inlet opening angles for the usual suspects (could we include a std A+ 998 cam please :) ) It all here: http://www.mlmotorsport.com/index.php?opti...d=26&topic=11.0 Edited by Paul S on 4th Jan, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Nov, 2006 at 09:34:39am
I've corrected an error above.
4th Jan, 2007 at 05:49:47pm
so...........ill need about 5:1 then.....LOL Great idea, takes alot of the guess work out. Now, all we need is some handy so and so to post up a list of inlet opening angles for the usual suspects (could we include a std A+ 998 cam please :) ) It all here: http://www.mlmotorsport.com/forums/viewtopic.php?t=11 just letting you know the link doent work for me buddy *edit* http://www.mlmotorsport.com/index.php?opti...d=26&topic=11.0 Edited by joeybaby83 on 4th Jan, 2007. "Turbo's make torque, and torque makes fun"
13th Sep, 2007 at 03:54:39pm
this is a bit of an old post but very interesting.
13th Sep, 2007 at 04:09:59pm
i've had a similar experience recently too thats confusing me.
Page: |
