Page: |
Home > A-Series EFI / Injection > Rover Mini SPi and MPi Stepper Motors | |||||||
28th Aug, 2006 at 12:47:17pm
I need to re update this at some point, after I recovered from throwing my toys out of the pram Edited by Sprocket on 16th Dec, 2007. On 26th Oct, 2004 TurboDave16v said:
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
28th Aug, 2006 at 12:51:57pm
OOO thats not good news, i hope you sort it mate. |
29th Aug, 2006 at 12:37:16am
... Edited by Sprocket on 13th May, 2007. On 26th Oct, 2004 TurboDave16v said:
29th Aug, 2006 at 08:27:27am
Im not worried... honest.... im trying to find a cheap spi unit to take apart ha ha to get a general understandings of how it works. |
11 Posts Member #: 1219 Member |
29th Aug, 2006 at 01:30:11pm
I threw my stepper in the bin and just made a v small bypass hose. Idles at 1200 but then any slower and it would be a bit lumpy! |
29th Aug, 2006 at 07:59:11pm
never did look into the stepper as i jstu opened it right up and ran a bosch 2 wire IACV. however there was a circuit posted that may be able to controll that type of stepper that translated the PWM signal to a stepper putput.(was designed so that us msns-e'ers could use a stepper) be worth a search on the megasquirt forums Edited by evolotion on 29th Aug, 2006. turbo 16v k-series 11.9@118.9 :)
3rd Sep, 2006 at 10:39:54pm
seen this thread and thought of you :)
Edited by evolotion on 3rd Sep, 2006. turbo 16v k-series 11.9@118.9 :)
3rd Sep, 2006 at 11:58:19pm
4th Sep, 2006 at 07:30:34pm
no probs. iv got my head burrie din other work right now, but i'd also liek my rover unipolar stepper to be controlled by my megasquirt, as the bosch IACV im useing makes a noise like a foghorn when its active :( turbo 16v k-series 11.9@118.9 :)
15th Sep, 2006 at 11:14:04pm
208 Posts Member #: 438 Senior Member London |
16th Sep, 2006 at 12:43:55pm
May be worth having a nose around on CNCzone.com
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
2nd Dec, 2006 at 07:03:42pm
On 15th of Sep, 2006 at 11:14pm Mini Sprocket said:
Its mearly a matter of disconnecting the windings from the center tap and each other, to be able to use these motors with MSII. The only thing I have not checked as of yet i the winding resistances and whether they are within the limits of the MSII stepper driver. Did you ever get this to work? Would it be possible, if the resistance is too high, to split the two centre feeds and just use half the coils. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Dec, 2006 at 07:14:46pm
3rd Dec, 2006 at 03:57:45pm
I've just measured the resistance between the common centre tapping and the other four windings and it is consistantly 9-10 ohms.
3rd Dec, 2006 at 06:46:43pm
So, do we need to add in additional resistance to lower the voltage at the windings?
3rd Dec, 2006 at 07:02:00pm
Well the MSII IAC controller can output 750mA continuously.
Edited by Paul S on 3rd Dec, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Dec, 2006 at 07:32:02pm
3rd Dec, 2006 at 08:05:49pm
iv got a spare motor jsut for this.., jsut not the time, allthough i plan on implementing the PWM to stepper convertoer or mayb even MSII when i rebuild the car over the winter. turbo 16v k-series 11.9@118.9 :)
3rd Dec, 2006 at 08:07:30pm
motor is DEFINATELY 12v. the signle big commmon terminal is connected to a switched +12v alogn wiht the injectors and ignition coil in the standard loom. turbo 16v k-series 11.9@118.9 :)
3rd Dec, 2006 at 08:15:57pm
3rd Dec, 2006 at 09:04:05pm
My MSII arrived yesterday and I'm now waiting for some parts to get the EDIS fitted and working.
3rd Dec, 2006 at 10:12:40pm
Axel,
4th Dec, 2006 at 01:11:33am
Jean,
4th Dec, 2006 at 02:16:38am
Dave,
4th Dec, 2006 at 04:58:24am
months... :(
Page: |
